Home » Eclipse Projects » DTP » Using DTP components as runtime "Schema Container"?
Using DTP components as runtime "Schema Container"? [message #346] |
Thu, 12 May 2005 18:53  |
given the following problem: Assume we have server side products that should
run on a number of RDBMS:s. Consequently, our product requires a certain
relational schema to be deployed in the RDBMS.
Can I use (the planed) DTP components to iplement the following use case:
1) The relational schema is shipped to the customer as XML files, which are
RDBMS vendor and version neutral.
2) DTP tools provide support for transforming the vendor neutral model into
vendor specific DDL statements, which are applied to the RDBMS. (in case no
schema exists, yet)
3) DTP tools provide support for generating "delta" DDL statements and apply
them to the RDBMS (in case a previous version of the schema has already been
deployed.)
[I guess answer to 1) is certainly "yes", I mention this just to clarify the
use case.]
Some notes:
a) The above functionality is IMHO always required independently of wether
O/R mapping is used or not.
b) I'm not sure if a schema-generic mapping from vendor neutral to vendor
specifc DDL statements is realistic. I might be a bit naive here (datatype
issues amoung 10s of other issues). Some extension points might be required.
Also non-schema related issues like TABLESPACE sizes might be problematic.
c) I would like to point to an existing product that provides similar
support, but unfortunatly I'm not aware of one.
d) I believe e.g.WebSphere supports 2) (but not 3), but only if the database
vendor code has been generated during development of the CMP Entity Bean.
e) A more general statement on what I'm looking for: With J2EE its possible
to create and ship vendor neutral business logic [OK, we all know the
problems in real life, but at least J2EE has this target]. What I'm looking
for is a standard shiping format and related "container" for vendor neutral
RDBMS schemas.
f) Run-Time Mapping support is really needed in my case.
* Stefan
Re: Using DTP components as runtime "Schema Container"? [message #351 is a reply to message #346] |
Fri, 13 May 2005 10:12   |
Originally posted by: christian.sell.netcologne.de
the data tooling that is provided with the WTP project (and will become
part of DTP in some way) already does the conversion from generic to
vendor-specific schema, extensible (for non-supported DBMS) via eclipse
mechanisms. I dont think they do deltas, however.
What do you mean by run-time mapping? That would be the job of an O/R
layer IMO.
christian
Stefan Vaillant wrote:
> schema exists, yet)
> deployed.)
> use case.]
> Some notes:
> RDBMS schemas.
> * Stefan
Re: Using DTP components as runtime "Schema Container"? [message #356 is a reply to message #351] |
Fri, 13 May 2005 16:03   |
> layer IMO.
That means that it should be possible to do the mapping RDB-EMF-Model to
vendor specific DDL statements during runtime (and not during development
time only).
Maybe mapping is the term to use, "SQL code generation" might be better.
Thanks for the info!
* Stefan
"Christian Sell" <christian.sell@netcologne.de> wrote in message
news:d62d5l$62g$1@news.eclipse.org...
> layer IMO.
> christian
> > Hi,
should
case:
are
into
no
> > schema exists, yet)
apply
been
> > deployed.)
the
> > use case.]
> > Some notes:
wether
vendor
(datatype
required.
problematic.
database
Bean.
possible
looking
neutral
> > RDBMS schemas.
> > * Stefan
Re: Using DTP components as runtime "Schema Container"? [message #366 is a reply to message #346] |
Sat, 28 May 2005 20:46   |
Originally posted by: eclipse.ambysoft.com
On Fri, 13 May 2005 00:53:30 +0200, "Stefan Vaillant"
<Stefan.Vaillant@nokia.com> wrote:
>Hi,
Is this an XML schema definition being shipped or an XML containing
meta data describing a schema?
>schema exists, yet)
It's pretty straight forward to generate table schema, given
sufficient meta data describing what you want. Do you also expect
triggers to support RI to be generated too? If so, then you'd need to
include meta data within the XML file to define the RI rules.
>deployed.)
This is a pretty ugly can of worms once you start to look into it.
Are you assuming mere additions and substractions to the schema? What
happens if a column is renamed?
What should happen to the data, if any?
By asking to handle the delta, you're really asking to refactor the
database schema. I've described the issues for doing so at
www.agiledata.org/essays/databaseRefactoring.html and am currently
working with Pramod Sadalage on www.databaserefactoring.com which will
contain material from our upcoming DB refactoring book.
>use case.]
>Some notes:
Yes, it's important to decouple various aspects of DTP.
Tools such as ER/Win have been dealing with this for many, many years.
>RDBMS schemas.
There are several data modeling CASE tools which do exactly this.
ERWin is my preferred one, but there are several others.
At www.ambysoft.com/persistenceLayer.html you'll find some links to
mapping products, many of which work in a Java environment. This
list isn't complete, but it's a pretty good start.
- Scott
>* Stefan
Re: Using DTP components as runtime "Schema Container"? [message #397 is a reply to message #361] |
Mon, 13 June 2005 14:44  |
Stefan,
Our API for WTP rdb generic DDL generation is under rdb.core plugin, under
org.eclipse.wst.rdb.internal.core.rte.fe package.
Just to let you know that the supporting ui wizard for DDL generation will
be in WTP M5 this Thursday's integration build. Too, we will have a
complete customized DDL generation to support Derby database. By default
all these will roll over to DTP this summer.
Der Ping
Re: Using DTP components as runtime "Schema Container"? [message #565403 is a reply to message #346] |
layer IMO.
christian
> schema exists, yet)
> deployed.)
> use case.]
> Some notes:
> RDBMS schemas.
> * Stefan
Re: Using DTP components as runtime "Schema Container"? [message #565428 is a reply to message #351] |
> layer IMO.
time only).
* Stefan
> layer IMO.
> christian
> > Hi,
should
case:
are
into
no
> > schema exists, yet)
apply
been
> > deployed.)
the
> > use case.]
> > Some notes:
wether
vendor
(datatype
required.
problematic.
database
Bean.
possible
looking
neutral
> > RDBMS schemas.
> > * Stefan
Re: Using DTP components as runtime "Schema Container"? [message #565475 is a reply to message #346] |
>Hi,
>schema exists, yet)
>deployed.)
>use case.]
>Some notes:
>RDBMS schemas.
- Scott
>* Stefan
Re: Using DTP components as runtime "Schema Container"? [message #565643 is a reply to message #361] |
Stefan,
Der Ping
Current Time: Thu Jul 17 19:44:00 EDT 2025
Powered by FUDForum. Page generated in 0.25254 seconds
