Home » Language IDEs » ServerTools (WTP) » NPE when creating web service
NPE when creating web service [message #42629] Fri, 10 September 2004 10:52 Go to next message
Originally posted by: csconnea.us.ibm.com
I'm following the instructions in Getting Started section 3.2 verbatim with
one exception. I'm trying to use tomcat 5.0 instead of 4.1. When I click
finish on the new Web Service wizard, I get the following exception. Any
ideas?
com.ibm.etools.webservice.consumption.common.WebServiceStart ServerRegistry.g
etServerStartByTypeId(WebServiceStartServerRegistry.java:85)
com.ibm.etools.webservice.consumption.command.common.CreateW ebProjectCommand
..stopServer(CreateWebProjectCommand.java:344)
..execute(CreateWebProjectCommand.java:143)
com.ibm.etools.webservice.consumption.command.common.CreateS erviceProjectCom
mand.execute(CreateServiceProjectCommand.java:81)
com.ibm.env.command.fragment.CommandFragmentEngine.runComman d(CommandFragmen
tEngine.java:312)
com.ibm.env.command.fragment.CommandFragmentEngine.visitTop( CommandFragmentE
ngine.java:278)
com.ibm.env.command.fragment.CommandFragmentEngine.moveForwa rdToNextStop(Com
mandFragmentEngine.java:198)
com.ibm.env.widgets.SimpleCommandEngineManager$4.run(SimpleC ommandEngineMana
ger.java:196)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.jav
a:303)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:253)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 752)
com.ibm.env.widgets.SimpleCommandEngineManager.runForwardToN extStop(SimpleCo
mmandEngineManager.java:165)
com.ibm.env.internal.widgets.WizardPageManager.runForwardToN extStop(WizardPa
geManager.java:59)
com.ibm.env.internal.widgets.WizardPageManager.performFinish (WizardPageManag
er.java:147)
com.ibm.env.widgets.DynamicWizard.performFinish(DynamicWizar d.java:319)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:609)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:305)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:506)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java(Compile
d Code))
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java (Compiled
Code))
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java(Inlined Compiled
Code))
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va(Compiled
Code))
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java (Compiled
Code))
at org.eclipse.jface.window.Window.runEventLoop(Window.java(Com piled
Code))
at org.eclipse.jface.window.Window.open(Window.java:648)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:163)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:915)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionI
tem.java:866)
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContribu
tionItem.java:785)
Code))
Code))
Code))
Code))
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a(Compiled
Code))
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:85
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:58
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:60)
at java.lang.reflect.Method.invoke(Method.java:391)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Re: NPE when creating web service [message #43111 is a reply to message #42629] Sat, 11 September 2004 14:47 Go to previous message
Tomcat 5.0 is not yet supported in the initial code contribution, but it
will be in the next code drop. In any case, the wizard should display a
proper error message instead of a NPE, I will get this fixed.
Jeff
"Colleen" <csconnea@us.ibm.com> wrote in message
news:chset8$thp$1@eclipse.org...
with
> ideas?
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> tEngine.java:312)
> at
> ngine.java:278)
> at
> at
> ger.java:196)
> at
> a:303)
> at
> at
> geManager.java:59)
> at
> er.java:147)
> at
> at
> at
> at
> d Code))
> at
> Code))
Compiled
> Code))
> at
> Code))
> at
> Code))
> Code))
> at
> at
> at
> tem.java:866)
> at
> tionItem.java:785)
> at
> Code))
Compiled
> Code))
> at
> Code))
> at
> Code))
> at
> Code))
> at
> at
> at
> at
> java:335)
> at
> at
> at
> at
> at
> .java:60)
Previous Topic:Running Tomcat
Next Topic:[LOMBOZ] - Initial Contribution
Current Time: Sat Nov 08 21:35:38 EST 2025
Powered by FUDForum. Page generated in 0.03260 seconds
