| org.eclipse.rap.w4t Dependency [message #42600] |
Tue, 21 August 2007 08:16  |
why does the org.eclipse.rap.w4t depend on the plugin javax.servlet? It also
imports the requiered packagaes. Depending on the plugin javax.servlet cause
errors in my tomcat environment.
Markus
| Re: org.eclipse.rap.w4t Dependency [message #43033 is a reply to message #42725] |
Wed, 22 August 2007 16:12  |
Originally posted by: rherrmann.innoopract.com
thanks for the hint, Markus. The changes are committed to CVS HEAD.
org.eclipse.rap.w4t no longer depends on the javax.servlet bundle.
Rüdiger
Markus Krüger wrote:
> Thanks Frank,
> I had an old feature that included it. So now everything is fine.
> Markus
> "Frank Appel" <fappel@innoopract.com> schrieb im Newsbeitrag
> news:faf4m3$eeg$1@build.eclipse.org...
>> with the latest version of RAP, there should be no need for the
>> org.eclipse.rap.w4t plug-in anymore, since all core functionality has been
>> moved to the org.eclipse.rap.rwt plug-in. So whether w4t depends on
>> javax.servlet or not should be of no interest, as you should be able to
>> remove the w4t plug-in completly. But still you are right, I also think
>> that there should be no need for the the servlet-plug-in dependency.
>> Ciao
>> Frank
>> "Markus Krüger" <krueger@ion.ag> schrieb im Newsbeitrag
>> news:faekte$feb$1@build.eclipse.org...
>>> Hello,
>>> also imports the requiered packagaes. Depending on the plugin
>>> javax.servlet cause errors in my tomcat environment.
>>> Regards,
>>> Markus
FUDForum. Page generated in 0.03317 seconds
