Home » Eclipse Projects » Remote Application Platform (RAP) » org.eclipse.rap.w4t Dependency
org.eclipse.rap.w4t Dependency [message #42600] Tue, 21 August 2007 08:16 Go to next message
why does the org.eclipse.rap.w4t depend on the plugin javax.servlet? It also
imports the requiered packagaes. Depending on the plugin javax.servlet cause
errors in my tomcat environment.
Markus
Re: org.eclipse.rap.w4t Dependency [message #42662 is a reply to message #42600] Tue, 21 August 2007 12:42 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
with the latest version of RAP, there should be no need for the
org.eclipse.rap.w4t plug-in anymore, since all core functionality has been
moved to the org.eclipse.rap.rwt plug-in. So whether w4t depends on
javax.servlet or not should be of no interest, as you should be able to
remove the w4t plug-in completly. But still you are right, I also think that
there should be no need for the the servlet-plug-in dependency.
Ciao
Frank
"Markus Kr
Re: org.eclipse.rap.w4t Dependency [message #42725 is a reply to message #42662] Wed, 22 August 2007 05:53 Go to previous messageGo to next message
Thanks Frank,
I had an old feature that included it. So now everything is fine.
Markus
"Frank Appel" <fappel@innoopract.com> schrieb im Newsbeitrag
news:faf4m3$eeg$1@build.eclipse.org...
> that there should be no need for the the servlet-plug-in dependency.
> Ciao
> Frank
> "Markus Kr
Re: org.eclipse.rap.w4t Dependency [message #43033 is a reply to message #42725] Wed, 22 August 2007 16:12 Go to previous message
Originally posted by: rherrmann.innoopract.com
thanks for the hint, Markus. The changes are committed to CVS HEAD.
org.eclipse.rap.w4t no longer depends on the javax.servlet bundle.
Rüdiger
Markus Krüger wrote:
> Thanks Frank,
> Markus
>> Ciao
>> Frank
>> "Markus Krüger" <krueger@ion.ag> schrieb im Newsbeitrag
>> news:faekte$feb$1@build.eclipse.org...
>>> Hello,
>>> also imports the requiered packagaes. Depending on the plugin
>>> javax.servlet cause errors in my tomcat environment.
>>> Regards,
>>> Markus
Previous Topic:static methods from image
Next Topic:big images in Tree
Current Time: Tue Nov 18 12:41:40 EST 2025
Powered by FUDForum. Page generated in 0.04237 seconds
