Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Domain model validation in batch mode
Domain model validation in batch mode [message #42577] Mon, 31 July 2006 07:35 Go to next message
I wonder if it is possible to validate a domain model outside an OSGI
platform.
I created an EMF Domain model and I am using it outside eclipse (eg: EMF
batch mode only).
Is it possible to run a validation without loading EMFT plugins and just
reusing jars at runtime (as EMF does)?
regards,
Re: Domain model validation in batch mode [message #42644 is a reply to message #42577] Mon, 31 July 2006 09:38 Go to previous messageGo to next message
Hello Lucas,
The EMFT validation framework is tightly integrated into eclipse and
OSGI at the moment. For example, constraints have to be contributed
through an extension point.
To "batch" validate your domain models you could try EMF's own
validation framework. I don't believe that it requires eclipse.
I hope this helps,
Chris McGee
lucas bigeardel wrote:
> Hello,
> platform.
> batch mode only).
> regards,
Re: Domain model validation in batch mode [message #42673 is a reply to message #42644] Mon, 31 July 2006 10:42 Go to previous message
Chris,
I reached the same conclusion.
I'll try to work with annotations and EMF validation mechanism.
regards,
- Lucas
"Chris McGee" <cbmcgee@ca.ibm.com> wrote in message
news:eal14o$862$1@utils.eclipse.org...
> Hello Lucas,
> The EMFT validation framework is tightly integrated into eclipse and OSGI
> at the moment. For example, constraints have to be contributed through an
> extension point.
> To "batch" validate your domain models you could try EMF's own validation
> I hope this helps,
> Chris McGee
>> Hello,
>> platform.
>> batch mode only).
>> regards,
Re: Domain model validation in batch mode [message #584027 is a reply to message #42577] Mon, 31 July 2006 09:38 Go to previous message
Hello Lucas,
I hope this helps,
Chris McGee
> Hello,
> platform.
> batch mode only).
> regards,
Re: Domain model validation in batch mode [message #584044 is a reply to message #42644] Mon, 31 July 2006 10:42 Go to previous message
Chris,
regards,
- Lucas
> Hello Lucas,
> extension point.
> I hope this helps,
> Chris McGee
>> Hello,
>> platform.
>> batch mode only).
>> regards,
Previous Topic:Domain model validation in batch mode
Next Topic:Can't set an attribute with an enumeration type
Current Time: Sat Nov 08 11:07:07 EST 2025
Powered by FUDForum. Page generated in 0.03324 seconds
