| help with swing / rcp application testing [message #42349] |
Wed, 08 July 2009 12:27  |
I have a swing/rcp application. The application when launched brings up a
login swing dialog. After entering the login details and clicking on the
login button, the rcp view comes up.
I want get hold of this swing dialog and simulate the click event, so that
the application comes up and then I can test the rcp view with swtbot.
Thanks for your help
L.
| Re: help with swing / rcp application testing [message #42589 is a reply to message #42559] |
Thu, 09 July 2009 07:51  |
Lalitha,
I've no experience with either, from what I've seen FEST has a nicer
dsl-ish api for doing things. I do not know much about jemmy.
As far as the albireo bridge bridge is concerned, swtbot currently has
no plans for supporting swing (or even integrating with other tools
which do so). This does not mean that swtbot will not support them, it
just means there's not people asking for this support and certainly no
patches yet.
Please open a bug against swtbot for discussion around integration with
other swing testing tools.
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
On 9/7/09 17:00, lalitha wrote:
> Ketan,
> I had another question. Earlier on you had suggested using FEST for
> testing the swing portion of the RCP/Swing application. Any perticular
> reason for suggesting FEST? Would you recommend FEST over Jemmy?
> L.
FUDForum. Page generated in 0.05813 seconds
