| Problems copying an XSDSchema [message #42314] |
Tue, 27 April 2004 18:13  |
For the purpose of performing a "save as" type operation on an XSDResource I
create a new resource instance and then attempt to copy the root EObjects
and then add the copies to the new resource's contents. When executing the
copy on a XSDResource composed of XSDSimpleTypeDefinition instances I
encounter an IllegalArgumentException. It appears that the
XSDSimpleTypeDefinition.patch code is attempting to set a member type
definition that already exists in the list. My question is should I be able
to copy a XSDSchema instance and paste it into a new XSDResource ? Are
there special considerations that need to be taken into account when copying
an XSDSchema instance?
Thread [main] (Suspended (exception IllegalArgumentException))
EObjectEList(BasicEList).set(int, Object) line: 543
BasicEList$EListIterator.set(Object) line: 1398
XSDSimpleTypeDefinitionImpl.patch() line: 680
XSDSchemaImpl(XSDConcreteComponentImpl).patch() line: 513
XSDSchemaImpl.patch() line: 1494
XSDSchemaImpl.traverseToRootForPatching() line: 1468
XSDSchemaImpl.adoptContent(EReference, XSDConcreteComponent) line: 1767
XSDSchemaImpl(XSDConcreteComponentImpl).eNotify(Notification ) line: 1133
NotificationChainImpl.dispatch(Notification) line: 115
NotificationChainImpl.dispatch() line: 103
EObjectContainmentEList(NotifyingListImpl).addAllUnique(int, Collection)
line: 342
EObjectContainmentEList(NotifyingListImpl).addAllUnique(Coll ection) line:
294
EObjectContainmentEList(BasicEList).addAll(Collection) line: 675
EcoreUtil$Copier.copyContainment(EReference, EObject, EObject) line: 387
EcoreUtil$Copier.copy(EObject) line: 365
EcoreUtil$Copier.copyAll(Collection) line: 336
EcoreUtil.copyAll(Collection) line: 300
Thanks in advance,
Dennis Fuglsang
| Re: Problems copying an XSDSchema [message #42345 is a reply to message #42314] |
Tue, 27 April 2004 18:34  |
Dennis,
The XSD model doesn't have all the right features set to be derived to avoid
generically copying things that should not be copied because they are computed.
Use cloneConcreteComponent if you need to do a copy. But you probably want to
copy the DOM itself anyway. And why not use Resource.save with an output stream
for where you want to save?
> line: 342
> 294
> Thanks in advance,
> Dennis Fuglsang
| Re: Problems copying an XSDSchema [message #586101 is a reply to message #42314] |
Dennis,
> line: 342
> 294
> Thanks in advance,
> Dennis Fuglsang
FUDForum. Page generated in 0.04701 seconds
