Re: unable to run patched version of org.eclipse.pde.build [message #344] |
Fri, 04 April 2008 15:12 |
This would be due to p2. To do this properly you would need a feature patch for
the feature in the ide product that includes pde.build. I don't know if this is
completely implemented yet or not.
As for 224098, I had forgotten about that bug, it is now fixed and will be in
the next IBuild.
-Andrew
Francis Upton wrote:
> Fixed the problem by exporting the pde.build plugin with the same
> qualifier that's used in the existing plugin and copying the plugin
> directory to the installation.
>> My batch build started failing when I upgraded to 3.4, so I filed this
>> bug and made a patch to fix it:
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=224098
>> Prior to M6 I was able to run the PDE build by simply replacing the
>> plugin with my patched version.
>> However with M6 (since it's using p2) I tried to put my patched plugin
>> into dropins and it would use the released plugin instead (as if my
>> patched plugin was not there). So I copied my patched plugin into the
>> same directory (as if it were the released plugin). The build script
>> runs, but the ${eclipse.pdebuild.scripts} variable is not set (I
>> verified that it is set correctly when using the non-patched version)
>> -- so something is going wrong here.
>> Maybe this is more of a p2 issue, but I thought I would check here first.
>> Thanks,
>> Francis
FUDForum. Page generated in 0.28056 seconds
