| Run-time Workbench instance [message #42262] | Mon, 28 March 2005 15:20  |  |
| Eclipse User  |  |  |  |  | Hi all,
 I am trying to use the plug-in tutorials from ECESIS step by
 step with Eclipse 3.0.
 In one of the slides it says:
 There are two different instances of Workbench that can run:
 * Host, the instance used for developing plug-ins
 * Run-time, the instance used for running, i.e. testing
 developed plug-ins
 Run-time Workbench instance is launched from the host instance
 * It will contain all plug-ins of the host instance as well as
 the ones just developed in the host instance
 * It is launched by choosing: Window -> New Window
 Now, I am trying to launch a "Run-time Workbench instance" by
 using Window -> New Window and I am getting an exact clone of
 the host instance (i.e., the plug-in that I am working on is not
 there) - any suggestion?
 Thanks a lot for your time,
 Adrian.
| Re: Run-time Workbench instance [message #42301 is a reply to message #42262] | Mon, 28 March 2005 17:12   |  |
| Eclipse User  |  |  |  |  | Originally posted by: jaredburns.no.spam.acm.org
 Window -> New Window just opens a new window. It has nothing to do with
 the idea of a "Runtime Workbench". To launch a Runtime Workbench, open
 the launch configuration dialog (click "Run..." or "Debug..."), select
 "Runtime Workbench", and click "New". Then click Run or Debug to launch it.
 - Jared
 Adrian Herscu wrote:
 > Hi all,
 > I am trying to use the plug-in tutorials from ECESIS step by step with
 > Eclipse 3.0.
 > * Run-time, the instance used for running, i.e. testing developed plug-ins
 > * It will contain all plug-ins of the host instance as well as the ones
 > Now, I am trying to launch a "Run-time Workbench instance" by using
 > Window -> New Window and I am getting an exact clone of the host
 > instance (i.e., the plug-in that I am working on is not there) - any
 > suggestion?
 > Adrian.
| Re: Run-time Workbench instance [message #42625 is a reply to message #42301] | Mon, 28 March 2005 23:49  |  |
| Eclipse User  |  |  |  |  | I was almost sure about the answer... Thanks Jared.
 > - Jared
 >> Hi all,
 >> Eclipse 3.0.
 >> plug-ins
 >> suggestion?
 >> Adrian.
FUDForum. Page generated in 0.13316 seconds
