| Help on SWT Standalone Examples Setup [message #42190] |
Sat, 18 January 2003 19:50  |
Originally posted by: bbyu.hotmail.com
I tried to run these examples by following "SWT Standalone Examples Setup"
found in the Eclipse Help. Every time when I ran the examples, I got the
following error message:
java.lang.NoClassDefFoundError:
Djava/library/path=D:\eclipse\plugins\org/eclipse/swt/win32_ 2/0/2\os\win32\x86
Exception in thread "main"
I did not check anything in the sample code files and I am running Eclipse
and these examples on Win 2000. Could not figure out why ...
Thanks.
| Re: Help on SWT Standalone Examples Setup [message #42450 is a reply to message #42190] |
Tue, 21 January 2003 04:14  |
Looks like you've omitted a hyphen from the command line. The java
launcher is interpreting what should be a parameter to the VM as the name
of the class to load and run.
Try something like:
java -Dparameter=value name.of.class.to.Load
instead of
java Dparameter=value name.of.class.to.Load
and see what happens.
Hope this helps,
Ian.
#ifndef __COMMON_SENSE__ | Ian Phillips
#include <std_disclaimer> | TIBCO Software Inc.
#endif | www.tibco.com
| Re: Help on SWT Standalone Examples Setup [message #588887 is a reply to message #42190] |
Mon, 20 January 2003 09:06  |
Check the FAQs, and if that doesn't help, ask on eclipse.tools.
"BYU" <bbyu@hotmail.com> wrote in message news:b0csnp$sd4$1@rogue.oti.com...
86
> Thanks.
| Re: Help on SWT Standalone Examples Setup [message #588936 is a reply to message #42190] |
Try something like:
instead of
Hope this helps,
Ian.
FUDForum. Page generated in 0.04994 seconds
