| external compare editor failed [message #42032] |
Sun, 22 February 2009 06:24  |
I'm getting an error when trying to compare two versions of a file. I'm
not actually trying to use an external editor. I was assuming it would use
the internal one.
"External compare was failed.
Cannot run program "C:/Program": CreateProcess error=2, The system cannot
find the file specified"
I guess it can't find the executable compare editor. Can it be set to use
the default eclipse compare editor?
more info
Just as test, if I install tortoiseSVN it finds the tortoise compare
editor.
org.eclipse.team.svn.core.operation.local.RunExternalCompare Operation$ExternalCompareOperationHelper.execute(RunExternal CompareOperation.java:218)
Caused by: java.io.IOException: CreateProcess error=2, The system cannot
FUDForum. Page generated in 0.03993 seconds
