Home » Archived » BIRT » Problems with return in fetch of Scripted Data Set
Problems with return in fetch of Scripted Data Set [message #42019] Wed, 01 June 2005 10:30 Go to next message
I am using the following code of the example from Scott Rosenbaum, in a
Data Set of a Scripted Data Source. The code is used in the fetch method.
if (count < 10 ) {
count++;
row.columnAny = count;
row["columnString"] = "String nummer" + count;
row[3] = count * count;
return true;
return false;
when I try to preview the results the following exception occurs:
org.eclipse.birt.data.engine.core.DataException occurred
Error Code:DATA_EXCEPTION_SCRIPT_EVAL_ERROR
Error Message:Error evaluating script (source:DataSet:data.fetch,
line:5): invalid return (DataSet:data.fetch#5).
Has anyone an idea what is wrong here?
Re: Problems with return in fetch of Scripted Data Set [message #42051 is a reply to message #42019] Wed, 01 June 2005 12:48 Go to previous message
Johannes,
I believe that the problem is in the versions of BIRT. In versions of
BIRT prior to the 5/25/2005 (includes the M3 build) the BIRT methods
were not true 'methods'. Instead they were expressions that were
evaluated in the Reporting engine, the value returned by the expression
was equal to the last assignment made in the method (see code below).
On 5/25/2005 BIRT changed the engine to evaluate the JavaScript methods
using a defined return value.
So you have two choices, either a) update to a more recent version of
BIRT or b) change your code as follows:
if (count < 10 ) {
count++;
true;
false;
Hope this helps,
Scott Rosenbaum
BIRT PMC
> a Data Set of a Scripted Data Source. The code is used in the fetch
> method.
> if (count < 10 ) {
> count++;
> return true;
> return false;
Previous Topic:Dynamics hyperlinks ?
Next Topic:2 Columns Report
Current Time: Sat Nov 08 20:01:51 EST 2025
Powered by FUDForum. Page generated in 0.03251 seconds
