Home » Eclipse Projects » Plugin Development Environment (PDE) » HELP: Adding files to RCP product root.
| Re: HELP: Adding files to RCP product root. [message #42094 is a reply to message #42002] |
Fri, 23 January 2009 10:57   |
DJ,
You need to have a product which is based on features, not on plug-ins
(and this is what is explained in the first link of your list).
Then, you'll simply need to have one of your features declaring a
build.properties containing "root" entries.
For example, here is the build.properties of a features my.jre.feature
(for example) that you could add to the lists of features of your
product, to ship the right JRE according to the platform. The jre will
end up in a "./jre" folder of your RCP app.
root.win32.win32.x86.folder.jre=absolute:/path/to/a/windows_ jre
root.linux.gtk.x86.folder.jre=absolute:/path/to/a/linux_x86_ jre
root.linux.gtk.x86_64.folder.jre=absolute:/path/to/a/linux_x 86_64_jre
HTH,
Ben
Dushyanth a écrit :
> Hi
> I am newbie - spent almost 5 days to learn on how to add files/folders
> to an RCP product root ? but not successful.
> All I am trying to do is ?> ==> Create an RCP product using "Hello RCP
> application with a view" example plug-in
> ==> Then add few html files and a folder to the RCP product root.
> I have been through the below articles ? but it was really very
> complicated for me to understand at this level.
> http://help.eclipse.org/stable/index.jsp?topic=/org.eclipse. pde.doc.user/tasks/pde_rootfiles.htm
> http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. pde.doc.user/reference/pde_feature_generating_build.htm
> http://help.eclipse.org/stable/index.jsp?topic=/org.eclipse. pde.doc.user/tasks/pde_feature_generating_antcommandline.htm
> http://wiki.eclipse.org/index.php/PDEBuild#Including_files_i n_the_root_of_my_build
> I have created a ?product configuration? file [.product], choose the
> option ?product configuration is based on: to ?plug-ins??. Finally,
> exported the plug-in as ?Eclipse product? using ?.product? file
> configuration. The final product created following files and folders:
> Configuration [Folder]
> plugins [Folder]
> .eclipseproduct
> eclipse.exe
> All I want to learn know is how can I add a new folder, just like
> plugins or configuration folders and few html files to the final product
> build.
> CAN SOMEONE PLEASE PROVIDE ME HELP, EXPLAINING IN SIMPLE STEPS
> Thanks
> DJ
| Re: HELP: Adding files to RCP product root. [message #42270 is a reply to message #42094] |
Fri, 23 January 2009 17:49   |
Ben is correct, to add root files when exporting from the UI, you must
use feature based products.
It is possible to add root files to plugin based products, but only when
you are running headless builds, not when exporting from the UI.
(This is done by adding the rootfile properties to the generated
org.eclipse.pde.build.container.feature that productBuild.xml generates)
-Andrew
Benjamin CABE wrote:
> DJ,
> HTH,
> Ben
> Dushyanth a écrit :
>> Hi
>> plugins [Folder]
>> .eclipseproduct
>> eclipse.exe
>> product build. CAN SOMEONE PLEASE PROVIDE ME HELP, EXPLAINING IN
>> SIMPLE STEPS
>> Thanks
>> DJ
| Re: HELP: Adding files to RCP product root. [message #42677 is a reply to message #42270] |
Mon, 26 January 2009 18:38  |
Thanks Ben and Andrew for your help.
Finally I am able to add files and folders to my RCP product root.
I thought I would share the process in simple steps, so that it will be
helpful to newbies like me in future. Please comment and post your
corrections, in case my process is wrong.
Objective 1 : Buld a RCP product [Hello world with a view] based on
"Features"
Objective 2 : Then add few files or folders to the RCP product root
Step 1 :
Create a feature [say: org.eclipse.core] that will holds all necessary
core [ or basic] plugins [such as
org.eclipse.rcp;org.eclipse.core.runtime,etc] required to run helloworld
RCP. After ading these basic plugins using PDEs "plug-ins and fragments"
tab, click on "Versions" button and choose second option:
"Copy versions from plug-in and fragment manifests"
By doing this, PDE adds version numers to each plug-in we included.
Now try export this feature using PDE overview page's "Export wizard". If
everything goes well, this will creats two folders :
A "features" folder and a "Plugins" folder
One problem you may expect here is "Wrong Plug-in version number" - This
can be solved by correcting the plug-in's version number or adding the
latest plugin versions with in your Eclipse plugin directory
[As a simple guide - i have included my feature.xml file below, which had
some core plugins included]
Step 2 :
Create an example [Hello world with a view] RCP plugin. [say name:
org.me.helloworld.product]
At this level, this plugin is completely independent, and we can launch it
with out any problem.
Step 3 :
In this step we create a new feature [say org.me.helloworld.feature] for
"org.me.helloworld.product" plugin.
In the PDE "Overview page" we add "org.me.helloworld.product" plug-in as
"Branding Plug-in" name.
In the PDE "plug-ins and fragments" tab, we add our
"org.me.helloworld.product" plug-in.
Then in the "Dependencies" tab, we click "Compute" button, which will add
few dependency plugins.
At this point we bundled our "org.me.helloworld.product" plug-in into
"org.me.helloworld.feature" feature. [in Step 3]
And all other necessary plugins requried by "org.me.helloworld.product"
plug-in are bundled into "org.eclipse.core" [in Step 1]
Step 4:
Create an RCP product: to do this we create a new product file under
Choose "The product configuration is based on to : features" in PDE
product configuration overview page.
Then add features: "org.me.helloworld.feature" and "org.eclipse.core"
using "Configuration" tab.
At this point, by using "Export->Eclipse product" facility, we can create
an executable RCP product. Thats our Object 1 is done.
Step 5 : Objective 2
Create a new feature [say org.me.helloworld.files.feature]
Under the new feature, we create a file called "hi.html" and a folder
called "myfiles"
In the "build.properties" page remove "bin.includes = feature.xml" line,
then add "root=file:hi.html,myfiles"
Finally, we go back to our Step 4 to add "org.me.helloworld.files.feature"
feature to the product file using "Configuration" tab.
Then Export the RCP product, now we can see "hi.html and myfiles folder"
under RCP product root directory.That our Object 2 is done.
FURTHER READING:
http://help.eclipse.org/stable/index.jsp?topic=/org.eclipse. pde.doc.user/tasks/pde_feature_generating_antcommandline.htm http://wiki.eclipse.org/index.php/PDEBuild#Including_files_i n_the_root_of_my_build
Sorry for my english and rough guidlines
I may be completely wrong, but this works for me, and this is what I
understand at this level.. Please feel free to correct me.
DJ
"org.eclipse.core" - feature.cml
<feature
id="org.eclipse.core.feature"
label="Core Feature"
version="1.0.0"
provider-name="Eclipse foundation">
<description url="http://www.example.com/description">
[Enter Feature Description here.]
</description>
<copyright url="http://www.example.com/copyright">
[Enter Copyright Description here.]
</copyright>
<license url="http://www.example.com/license">
[Enter License Description here.]
</license>
<plugin
id="org.eclipse.core.databinding.beans"
download-size="0"
install-size="0"
version="1.1.1.M20080827-0800a"
unpack="false"/>
<plugin
id="org.eclipse.core.expressions"
download-size="0"
install-size="0"
version="3.4.0.v20080603-2000"
unpack="false"/>
<plugin
id="org.eclipse.core.jobs"
download-size="0"
install-size="0"
version="3.4.0.v20080512"
unpack="false"/>
<plugin
id="org.eclipse.core.runtime"
download-size="0"
install-size="0"
unpack="false"/>
<plugin
id="org.eclipse.core.runtime.compatibility.auth"
download-size="0"
install-size="0"
version="3.2.100.v20070502"
unpack="false"/>
<plugin
id="org.eclipse.equinox.app"
download-size="0"
install-size="0"
version="1.1.0.v20080421-2006"
unpack="false"/>
<plugin
id="org.eclipse.equinox.common"
download-size="0"
install-size="0"
version="3.4.0.v20080421-2006"
unpack="false"/>
<plugin
id="org.eclipse.equinox.launcher"
download-size="0"
install-size="0"
version="1.0.101.R34x_v20080819"
unpack="false"/>
<plugin
id="org.eclipse.equinox.launcher.carbon.macosx"
os="macosx"
ws="carbon"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"/>
<plugin
id="org.eclipse.equinox.launcher.gtk.linux.ppc"
os="linux"
ws="gtk"
arch="ppc"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"/>
<plugin
id="org.eclipse.equinox.launcher.gtk.linux.x86"
os="linux"
ws="gtk"
arch="x86"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"/>
<plugin
id="org.eclipse.equinox.launcher.gtk.linux.x86_64"
os="linux"
ws="gtk"
arch="x86_64"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"/>
<plugin
id="org.eclipse.equinox.launcher.gtk.solaris.sparc"
os="solaris"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"/>
<plugin
id="org.eclipse.equinox.launcher.motif.aix.ppc"
os="aix"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"/>
<plugin
id="org.eclipse.equinox.launcher.win32.win32.x86"
os="win32"
download-size="0"
install-size="0"
version="1.0.101.R34x_v20080731"
fragment="true"/>
<plugin
id="org.eclipse.equinox.launcher.wpf.win32.x86"
os="win32"
ws="wpf"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"/>
<plugin
id="org.eclipse.equinox.preferences"
download-size="0"
install-size="0"
version="3.2.201.R34x_v20080709"
unpack="false"/>
<plugin
id="org.eclipse.equinox.registry"
download-size="0"
install-size="0"
version="3.4.0.v20080516-0950"
unpack="false"/>
<plugin
id="org.eclipse.help"
download-size="0"
install-size="0"
version="3.3.101.v20080702_34x"
unpack="false"/>
<plugin
id="org.eclipse.jface"
download-size="0"
install-size="0"
version="3.4.1.M20080827-2000"
unpack="false"/>
<plugin
id="org.eclipse.jface.databinding"
download-size="0"
install-size="0"
version="1.2.1.M20080827-0800a"
unpack="false"/>
<plugin
id="org.eclipse.osgi"
download-size="0"
install-size="0"
version="3.4.2.R34x_v20080826-1230"
unpack="false"/>
<plugin
id="org.eclipse.rcp"
download-size="0"
install-size="0"
version="3.4.0.v20080507"
unpack="false"/>
<plugin
id="org.eclipse.swt"
download-size="0"
install-size="0"
version="3.4.1.v3449c"
unpack="false"/>
<plugin
id="org.eclipse.swt.carbon.macosx"
os="macosx"
ws="carbon"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.swt.gtk.linux.ppc"
os="linux"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.swt.gtk.linux.x86"
os="linux"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.swt.gtk.linux.x86_64"
os="linux"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.swt.gtk.solaris.sparc"
os="solaris"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.swt.motif.aix.ppc"
os="aix"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.swt.win32.win32.x86"
os="win32"
ws="win32"
download-size="0"
install-size="0"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.swt.wpf.win32.x86"
os="win32"
ws="wpf"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.ui"
download-size="0"
install-size="0"
version="3.4.1.M20080910-0800"
unpack="false"/>
<plugin
id="org.eclipse.ui.carbon"
os="macosx"
ws="carbon"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.ui.workbench"
download-size="0"
install-size="0"
version="3.4.1.M20080827-0800a"
unpack="false"/>
<plugin
id="org.eclipse.update.configurator"
download-size="0"
install-size="0"
version="3.2.201.R34x_v20080819"
unpack="false"/>
<plugin
id="org.eclipse.core.filesystem"
download-size="0"
install-size="0"
version="1.2.0.v20080604-1400"
unpack="false"/>
<plugin
id="org.eclipse.core.filesystem.linux.ppc"
os="linux"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.core.filesystem.linux.x86"
os="linux"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.core.filesystem.linux.x86_64"
os="linux"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.core.filesystem.macosx"
os="macosx"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.core.filesystem.solaris.sparc"
os="solaris"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.core.filesystem.win32.x86"
os="win32"
download-size="0"
install-size="0"
version="1.1.0.v20080604-1400"
fragment="true"
unpack="false"/>
<plugin
id="javax.servlet"
download-size="0"
install-size="0"
version="2.4.0.v200806031604"
unpack="false"/>
<plugin
id="javax.servlet.jsp"
download-size="0"
install-size="0"
version="2.0.0.v200806031607"
unpack="false"/>
<plugin
id="org.apache.commons.el"
download-size="0"
install-size="0"
version="1.0.0.v200806031608"
unpack="false"/>
<plugin
id="org.apache.commons.logging"
download-size="0"
install-size="0"
version="1.0.4.v20080605-1930"
unpack="false"/>
<plugin
id="org.apache.jasper"
download-size="0"
install-size="0"
version="5.5.17.v200806031609"
unpack="false"/>
<plugin
id="org.apache.lucene"
download-size="0"
install-size="0"
version="1.9.1.v20080530-1600"
unpack="false"/>
<plugin
id="org.apache.lucene.analysis"
download-size="0"
install-size="0"
unpack="false"/>
<plugin
id="org.eclipse.core.net"
download-size="0"
install-size="0"
version="1.1.0.I20080604"
unpack="false"/>
<plugin
id="org.eclipse.core.resources"
download-size="0"
install-size="0"
version="3.4.1.R34x_v20080902"
unpack="false"/>
<plugin
id="org.eclipse.core.resources.compatibility"
download-size="0"
install-size="0"
version="3.4.0.v20080604-1400"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.core.runtime.compatibility.registry"
download-size="0"
install-size="0"
version="3.2.200.v20080610"
fragment="true"/>
<plugin
id="org.eclipse.core.variables"
download-size="0"
install-size="0"
version="3.2.100.v20080529-1300"
unpack="false"/>
<plugin
id="org.eclipse.draw2d"
download-size="0"
install-size="0"
version="3.4.0.v20080529"
unpack="false"/>
<plugin
id="org.eclipse.equinox.http.jetty"
download-size="0"
install-size="0"
version="1.1.0.v20080425"
unpack="false"/>
<plugin
id="org.eclipse.equinox.http.registry"
download-size="0"
install-size="0"
version="1.0.100.v20080427-0830"
unpack="false"/>
<plugin
id="org.eclipse.equinox.http.servlet"
download-size="0"
install-size="0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.jsp.jasper"
download-size="0"
install-size="0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.jsp.jasper.registry"
download-size="0"
install-size="0"
version="1.0.0.v20080427-0830"
unpack="false"/>
<plugin
id="org.eclipse.gef"
download-size="0"
install-size="0"
version="3.4.1.v20080716"
unpack="false"/>
<plugin
id="org.eclipse.help.appserver"
download-size="0"
install-size="0"
version="3.1.300.v20080507"
unpack="false"/>
<plugin
id="org.eclipse.help.base"
download-size="0"
install-size="0"
version="3.3.101.M20080728_34x"
unpack="false"/>
<plugin
id="org.eclipse.help.ui"
download-size="0"
install-size="0"
version="3.3.101.M20080715_34x"
unpack="false"/>
<plugin
id="org.eclipse.help.webapp"
download-size="0"
install-size="0"
version="3.3.101.M20080805_34x"
unpack="false"/>
<plugin
id="org.eclipse.osgi.services"
download-size="0"
install-size="0"
version="3.1.200.v20071203"
unpack="false"/>
<plugin
id="org.eclipse.ui.forms"
download-size="0"
install-size="0"
version="3.3.101.v20080708_34x"
unpack="false"/>
<plugin
id="org.eclipse.ui.views"
download-size="0"
install-size="0"
version="3.3.0.I20080509-2000"
unpack="false"/>
<plugin
id="org.eclipse.ui.workbench.compatibility"
download-size="0"
install-size="0"
version="3.2.0.I20080509-2000"
fragment="true"/>
<plugin
id="org.eclipse.update.core"
download-size="0"
install-size="0"
version="3.2.201.R34x_v20080714"
unpack="false"/>
<plugin
id="org.eclipse.update.core.linux"
os="linux"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.update.core.win32"
download-size="0"
install-size="0"
version="3.2.100.v20080107"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.update.scheduler"
download-size="0"
install-size="0"
version="3.2.100.v20080404"
unpack="false"/>
<plugin
id="org.eclipse.update.ui"
download-size="0"
install-size="0"
version="3.2.100.v20080318"
unpack="false"/>
<plugin
id="org.mortbay.jetty"
download-size="0"
install-size="0"
version="5.1.14.v200806031611"
unpack="false"/>
<plugin
id="com.ibm.icu"
download-size="0"
install-size="0"
version="3.8.1.v20080530"
unpack="false"/>
<plugin
id="org.eclipse.core.commands"
download-size="0"
install-size="0"
version="3.4.0.I20080509-2000"
unpack="false"/>
<plugin
id="org.eclipse.core.contenttype"
download-size="0"
install-size="0"
version="3.3.0.v20080604-1400"
unpack="false"/>
<plugin
id="org.eclipse.core.databinding"
download-size="0"
install-size="0"
version="1.1.1.M20080827-0800b"
unpack="false"/>
<plugin
id="org.eclipse.core.resources.win32.x86"
download-size="0"
install-size="0"
version="3.4.0.v20071204"
fragment="true"
unpack="false"/>
</feature>
| Re: HELP: Adding files to RCP product root. [message #590360 is a reply to message #42002] |
Originally posted by: benjamin.cabe.anyware-tech.com
DJ,
HTH,
Ben
Dushyanth a écrit :
> Hi
> plugins [Folder]
> .eclipseproduct
> eclipse.exe
> build.
> Thanks
> DJ
| Re: HELP: Adding files to RCP product root. [message #590423 is a reply to message #42094] |
-Andrew
> DJ,
> HTH,
> Ben
> Dushyanth a écrit :
>> Hi
>> plugins [Folder]
>> .eclipseproduct
>> eclipse.exe
>> SIMPLE STEPS
>> Thanks
>> DJ
| Re: HELP: Adding files to RCP product root. [message #590602 is a reply to message #42270] |
"Features"
Step 1 :
Step 2 :
Step 3 :
Step 4:
called "myfiles"
FURTHER READING:
DJ
<feature
version="1.0.0"
</description>
</copyright>
</license>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
os="macosx"
ws="carbon"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"/>
<plugin
os="linux"
ws="gtk"
arch="ppc"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"/>
<plugin
os="linux"
ws="gtk"
arch="x86"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"/>
<plugin
os="linux"
ws="gtk"
arch="x86_64"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"/>
<plugin
os="solaris"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"/>
<plugin
os="aix"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"/>
<plugin
os="win32"
download-size="0"
install-size="0"
fragment="true"/>
<plugin
os="win32"
ws="wpf"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
os="macosx"
ws="carbon"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
os="linux"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
os="linux"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
os="linux"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
os="solaris"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
os="aix"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
os="win32"
ws="win32"
download-size="0"
install-size="0"
fragment="true"
unpack="false"/>
<plugin
os="win32"
ws="wpf"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
id="org.eclipse.ui"
download-size="0"
install-size="0"
unpack="false"/>
<plugin
os="macosx"
ws="carbon"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
os="linux"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
os="linux"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
os="linux"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
os="macosx"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
os="solaris"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
os="win32"
download-size="0"
install-size="0"
fragment="true"
unpack="false"/>
<plugin
id="javax.servlet"
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
fragment="true"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
fragment="true"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
fragment="true"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
os="linux"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
fragment="true"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
id="com.ibm.icu"
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
download-size="0"
install-size="0"
fragment="true"
unpack="false"/>
</feature>
Current Time: Fri Nov 14 19:11:52 EST 2025
Powered by FUDForum. Page generated in 0.05490 seconds
