| Commenttext VE - Eclipse3Rc2 [message #41950] |
Wed, 16 June 2004 07:02  |
I have download the new VE-SDK Version with EMF, GEF.
I have used it on a fresh installed Eclipse3RC2SDK and all seems good.
But when I put a bean into a frame the commenttext look like this:
* This method initializes jJMenuBar
* @return javax.swing.JMenuBar
Is there a configuration for that (I mean the space between the lines) ??
Thanks ...
| Re: Commenttext VE - Eclipse3Rc2 [message #592042 is a reply to message #41950] |
Fri, 18 June 2004 09:13  |
Michael Kroll wrote:
> Hello,
> Thanks ...
This is a bug; which platform are you running on?
Was the file created on this platform? please open a bug... be helpful
if you attach the file, or instruction on how to recreate this.
| Re: Commenttext VE - Eclipse3Rc2 [message #592096 is a reply to message #42286] |
Sat, 19 June 2004 10:10  |
Same bug appearing here on Windows 2000...
(Well, a bug that kept me from using VE at the moment ...)
- Benjamin
>> Hello,
>> Thanks ...
| Re: Commenttext VE - Eclipse3Rc2 [message #592112 is a reply to message #42462] |
Sat, 19 June 2004 12:30  |
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Looking at the generation code, we generate:
(tab)/**
(tab)* This ...
There is one possibility. We are using the
System.getProperties().getProperty("line.separator")
to determine the line separator to use. If this is returning CRLF or
something else and your system is expecting only LF, maybe that could
cause this.
Thanks, Rich Kulp
FUDForum. Page generated in 0.04237 seconds
