Home » Archived » XML Schema Definition (XSD) » Processing complexTypes derived by extension
Processing complexTypes derived by extension [message #41942] Tue, 20 April 2004 16:03 Go to next message
Originally posted by: adam.premasys.com
I'm wanting to use the XSD API in building an application that allows a user
to build the messages
for a WSDL operation using a simple wizard-style interface. The initial
version of this application
doesn't need to validate the message created, it just needs to present to
the user text fields for entering
values for elements that have simpleTypes and selection lists for elements
with complexTypes where the
complexType is a base type with extended types. An example of such a base
type is shown below.
<xsd:complexType xmlns:xsd="http://www.w3.org/2001/XMLSchema"
name="Organisation">
<xsd:complexContent>
<xsd:extension base="Party">
<xsd:sequence>
<xsd:element name="numberOfEmployees" type="xsd:double"
minOccurs="0"/>
<xsd:element name="businessOrganisation" type="xsd:string"
minOccurs="0"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
The code below is based upon an example posted to this group previously. I'm
uncertain how I should extend this to handle the
extension case. An example of how to do this would be great.
Adam
public void processType() {
XSDTypeDefinition definition = getTypeDefinition();
if (definition instanceof XSDSimpleTypeDefinition) {
XSDSimpleTypeDefinition xsdSimpleTypeDefinition =
(XSDSimpleTypeDefinition) definition;
// create element
} else {
XSDComplexTypeDefinition xsdComplexTypeDefinition =
(XSDComplexTypeDefinition) definition;
// create element
switch (xsdComplexTypeDefinition.getContentTypeCategory().getValue( )) {
case XSDContentTypeCategory.EMPTY :
break;
case XSDContentTypeCategory.SIMPLE :
xsdComplexTypeDefinition.getContentType();
// create data
break;
case XSDContentTypeCategory.ELEMENT_ONLY :
case XSDContentTypeCategory.MIXED :
XSDParticle xsdParticle = (XSDParticle)
XSDTerm xsdTerm = xsdParticle.getTerm();
if (xsdTerm instanceof XSDModelGroup) {
XSDModelGroup xsdModelGroup = (XSDModelGroup) xsdTerm;
for (Iterator i = xsdModelGroup.getParticles().iterator();
i.hasNext();) {
XSDParticle childXSDParticle = (XSDParticle) i.next();
XSDTerm childTerm = childXSDParticle.getTerm();
if (childTerm instanceof XSDElementDeclaration) {
XSDElementDeclaration elDeclaration =
(XSDElementDeclaration) childTerm;
// create element, call back into function
} else if (xsdTerm instanceof XSDElementDeclaration) {
XSDElementDeclaration elDeclaration = (XSDElementDeclaration)
xsdTerm;
} else if (xsdTerm instanceof XSDWildcard) {
break;
// process attributes
EList attrs = xsdComplexTypeDefinition.getAttributeUses();
Iterator it = attrs.iterator();
while(it.hasNext()) {
XSDAttributeUse attrUse = (XSDAttributeUse)it.next();
XSDAttributeDeclaration attr = attrUse.getAttributeDeclaration()
// create attribute
Re: Processing complexTypes derived by extension [message #41973 is a reply to message #41942] Tue, 20 April 2004 16:14 Go to previous message
Adam,
You shouldn't need to extend the code below to handle complex types with
extensions because getting the content type of a complex type will yield a
particle tree that already includes that of the base type. The code for handling
particles should be recursive though, because model groups can refer to model
groups, which can refer to model groups...
FYI, If you follow the EMF tutorial for generating a model from an XML Schema:
http://download.eclipse.org/tools/emf/scripts/docs.php?doc=t utorials/xlibmod/xlibmod.html
using your own schema, you'll generate a Eclipse-based editor that does exactly
what you say you are building...
Adam Ratcliffe wrote:
> <xsd:sequence>
> minOccurs="0"/>
> minOccurs="0"/>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> Adam
> // create element
> } else {
> // create element
> break;
> // create data
> break;
> i.hasNext();) {
> xsdTerm;
> break;
> // create attribute
Re: Processing complexTypes derived by extension [message #585887 is a reply to message #41942] Tue, 20 April 2004 16:14 Go to previous message
Adam,
> <xsd:sequence>
> minOccurs="0"/>
> minOccurs="0"/>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> Adam
> // create element
> } else {
> // create element
> break;
> // create data
> break;
> i.hasNext();) {
> xsdTerm;
> break;
> // create attribute
Previous Topic:Processing complexTypes derived by extension
Next Topic:short question on minOccurs and maxOccurs on XSDElementDeclaration
Current Time: Wed Dec 03 04:18:20 EST 2025
Powered by FUDForum. Page generated in 0.04394 seconds
