Home » Modeling » OCL » setContext doesn't find RuleAction
setContext doesn't find RuleAction [message #41873] Tue, 30 October 2007 08:49 Go to next message
I'm pretty new to OCL, so I tried to set up a quick test. I created a
new EMF based model, generated model, edit, editor, and test plugins
and now I'm trying to add some OCL expressions.
This is my test code:
01 // using package org.eclipse.ocl.ecore
02 EcoreEnvironmentFactory envfac = new
EcoreEnvironmentFactory(resourceSet.getPackageRegistry());
03 OCL ocl = OCL.newInstance(envfac);
04 OCL.Helper helper = ocl.createOCLHelper();
05 EObject instanceContext = resource.getContents().get(0);
06 helper.setInstanceContext(instanceContext);
07 try {
08 OCLExpression query = helper.createQuery("self.vertices->size()");
09 Object result = ocl.createQuery(query).evaluate();
10 System.out.println(result);
11 } catch (ParserException ex) {
12 ex.printStackTrace();
13 }
In line 6, the following exception is thrown:
Exception in thread "main" java.lang.NoClassDefFoundError:
lpg/lpgjavaruntime/RuleAction
org.eclipse.ocl.AbstractEnvironment.lookupLocal(AbstractEnvi ronment.java:482)
org.eclipse.ocl.AbstractEnvironment.addElement(AbstractEnvir onment.java:249)
org.eclipse.ocl.AbstractEnvironmentFactory.createClassifierC ontext(AbstractEnvironmentFactory.java:132)
org.eclipse.ocl.AbstractEnvironmentFactory.createInstanceCon text(AbstractEnvironmentFactory.java:144)
org.eclipse.ocl.internal.helper.OCLHelperImpl.setInstanceCon text(OCLHelperImpl.java:131)
org.eclipse.ocl.ecore.OCLHelperImpl.setInstanceContext(OCLHe lperImpl.java:130)
= line 6
de.feu.SimpleModel.tests.SimpleModelExample.main(SimpleModel Example.java:114)
I
also modified the ocl.examples.interpreter to plugin into my model
editor instead of the library example, and this is working pretty well.
With the (modified) interpreter example, I can query the model.
What is wrong with my code? Do I have to add a dependency? Where do I
find lpg.lpgjavaruntime.RuleAction?
Jens
Re: setContext doesn't find RuleAction [message #41914 is a reply to message #41873] Tue, 30 October 2007 11:42 Go to previous messageGo to next message
Hi, Jens,
How did you install the OCL SDK? The SDK download and update-manager site
both include the plug-in that defines the RuleAction class:
- net.sourceforge.lpg.lpgjavaruntime (version 1.1.0)
If you're consuming the OCL source from CVS, then you can get the LPG Java
Runtime from the Orbit CVS repository. The easiest way to do that is to
load the ocl.psf file in the org.eclipse.ocl.releng project, or download it
from the Orbit downloads page:
http://download.eclipse.org/tools/orbit/downloads/
HTH,
Christian
Jens v.P. wrote:
> 07 try {
> 13 }
> at
> at
> at
> at
> at
> at
> = line 6
> at
> I
> Jens
Re: setContext doesn't find RuleAction [message #41976 is a reply to message #41914] Tue, 30 October 2007 14:13 Go to previous message
On 2007-10-30 16:42:14 +0100, "Christian W. Damus" <cdamus@ca.ibm.com> said:
I have used the update site, and the plugin was installed. I simply
didn't added it to the dependencies. Thank you very much!
Jens
Previous Topic:Re: Generating code for OCL annotations in OCL 1.0.1/EMF 2.2
Next Topic:Adding variable-value bindings to queries
Current Time: Sun Nov 09 22:36:11 EST 2025
Powered by FUDForum. Page generated in 0.04183 seconds
