Home » Archived » IAM (Eclipse Integration for Apache Maven) » Workaround for getting maven to work with wtp
Workaround for getting maven to work with wtp [message #3588] Mon, 03 December 2007 01:07 Go to next message
Originally posted by: yeechut.gmail.com
As I see - the thing that is missing with deploying a maven project with
wtp is that the WEB-INF/lib is empty - i.e. wtp doesn't know how to
extract maven's dependencies.
I tested with the following workaround - and it seems to work:
- get maven to generate the war file.
- extract the WEB-INF/lib folder from the war file and copy to
src/main/webapp/WEB-INF/lib.
- repeat the above if proejct dependencies changes (which is not too
often).
I am new to maven. Can someone comment whether this approach works?
Many thanks
Yee
Re: Workaround for getting maven to work with wtp [message #3620 is a reply to message #3588] Mon, 03 December 2007 11:18 Go to previous messageGo to next message
you could try war:inplace, still a workaround, but easier
> often).
> Many thanks
> Yee
Re: Workaround for getting maven to work with wtp [message #3651 is a reply to message #3620] Mon, 03 December 2007 23:58 Go to previous messageGo to next message
Thanks. That's a good enough workaround for now.
Keep up with the good work for Q4E. I find it very remarkable that there
is no proper integration of mavan and Eclipse yet. I wanted to get started
on maven very much - but took me one whole week of trying all sorts of
things to get to this point. I almost gave up on Eclipse.
Yee
Re: Workaround for getting maven to work with wtp [message #3684 is a reply to message #3588] Tue, 04 December 2007 02:31 Go to previous message
WTP provides a "hook" for other plug-ins to contribute classpath entries
that need to be deployed.
This can be made manually (in the project preferences) or automatically
(the plug-in enables wtp deployment for its managed classpath entries).
q4e/iam is not very far away of being able to do this and m2eclipse has
some support too.
Re: Workaround for getting maven to work with wtp [message #564666 is a reply to message #3588] Mon, 03 December 2007 11:18 Go to previous message
> often).
> Many thanks
> Yee
Re: Workaround for getting maven to work with wtp [message #564683 is a reply to message #3620] Mon, 03 December 2007 23:58 Go to previous message
Yee
Re: Workaround for getting maven to work with wtp [message #564704 is a reply to message #3588] Tue, 04 December 2007 02:31 Go to previous message
some support too.
Previous Topic:Workaround for getting maven to work with wtp
Next Topic:Feedback
Current Time: Sat Nov 22 06:21:18 EST 2025
Powered by FUDForum. Page generated in 0.04296 seconds
