Home » Language IDEs » PHP Development Tools (PDT) » Cannot open *.module file in php editor
Cannot open *.module file in php editor [message #41382] Tue, 07 August 2007 13:35 Go to next message
Originally posted by: c_fahrengruber.yahoo.de
When I try to open a *.module file from the Drupal module "htmlarea" I
always get a NullpointerException.
I use Eclipse 3.3 with PDT 1.0.0.v20070802-79--E7QYGHEHNGY.
The Stacktrace is:
!ENTRY org.eclipse.ui 4 0 2007-08-07 19:25:27.562
!MESSAGE Unable to create editor ID org.eclipse.php.editor: An exception
was thrown during initialization
!STACK 0
org.eclipse.wst.sse.ui.StructuredTextEditor.getModel(Structu redTextEditor.java:2403)
org.eclipse.php.internal.ui.editor.PHPStructuredEditor.getFi le(Unknown
Source)
org.eclipse.php.internal.ui.editor.PHPStructuredEditor$1.get Project(Unknown
Source)
org.eclipse.php.internal.core.project.properties.handlers.Ph pVersionChangedHandler.addPhpVersionChangedListener(Unknown
Source)
at org.eclipse.php.internal.ui.editor.PHPStructuredEditor.init( Unknown
Source)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:794)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:263)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2721)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2633)
at org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2625)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2577)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2572)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2556)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2547)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:644)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:603)
at org.eclipse.php.internal.ui.util.EditorUtility.openInEditor( Unknown
Source)
Source)
at org.eclipse.php.internal.ui.actions.OpenActionUtil.open(Unkn own Source)
at org.eclipse.php.internal.ui.actions.OpenAction.run(Unknown Source)
org.eclipse.php.internal.ui.actions.SelectionDispatchAction. dispatchRun(Unknown
Source)
org.eclipse.php.internal.ui.actions.SelectionDispatchAction. run(Unknown
Source)
org.eclipse.php.internal.ui.explorer.ExplorerActionGroup.han dleOpen(Unknown
Source)
at org.eclipse.php.internal.ui.explorer.ExplorerPart$5.open(Unk nown Source)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 3)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
Re: Cannot open *.module file in php editor [message #41648 is a reply to message #41382] Wed, 08 August 2007 16:45 Go to previous messageGo to next message
Originally posted by: seva-eclipse.zend.com
Please submit a bug report, if possible.
On Tue, 07 Aug 2007 19:35:14 +0200 Claudia Fahrengruber <c_fahrengruber@yahoo.de> wrote:
CF> When I try to open a *.module file from the Drupal module "htmlarea" I
CF> always get a NullpointerException.
CF>
CF> I use Eclipse 3.3 with PDT 1.0.0.v20070802-79--E7QYGHEHNGY.
CF>
CF> The Stacktrace is:
CF>
CF> !ENTRY org.eclipse.ui 4 0 2007-08-07 19:25:27.562
CF> !MESSAGE Unable to create editor ID org.eclipse.php.editor: An exception
CF> was thrown during initialization
CF> !STACK 0
CF> java.lang.NullPointerException
CF> at
CF> org.eclipse.wst.sse.ui.StructuredTextEditor.getModel(Structu redTextEditor.java:2403)
CF> at
CF> org.eclipse.php.internal.ui.editor.PHPStructuredEditor.getFi le(Unknown
CF> Source)
CF> at
CF> org.eclipse.php.internal.ui.editor.PHPStructuredEditor$1.get Project(Unknown
CF> Source)
CF> at
CF> org.eclipse.php.internal.core.project.properties.handlers.Ph pVersionChangedHandler.addPhpVersionChangedListener(Unknown
CF> Source)
CF> at org.eclipse.php.internal.ui.editor.PHPStructuredEditor.init( Unknown
CF> Source)
CF> at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:794)
CF> at
CF> org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
CF> at
CF> org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
CF> at
CF> org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
CF> at
CF> org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:263)
CF> at
CF> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2721)
CF> at
CF> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2633)
CF> at org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2625)
CF> at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2577)
CF> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
CF> at
CF> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2572)
CF> at
CF> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2556)
CF> at
CF> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2547)
CF> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:644)
CF> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:603)
CF> at org.eclipse.php.internal.ui.util.EditorUtility.openInEditor( Unknown
CF> Source)
CF> Source)
CF> at org.eclipse.php.internal.ui.actions.OpenActionUtil.open(Unkn own Source)
CF> at org.eclipse.php.internal.ui.actions.OpenAction.run(Unknown Source)
CF> at
CF> org.eclipse.php.internal.ui.actions.SelectionDispatchAction. dispatchRun(Unknown
CF> Source)
CF> at
CF> org.eclipse.php.internal.ui.actions.SelectionDispatchAction. run(Unknown
CF> Source)
CF> at
CF> org.eclipse.php.internal.ui.explorer.ExplorerActionGroup.han dleOpen(Unknown
CF> Source)
CF> at org.eclipse.php.internal.ui.explorer.ExplorerPart$5.open(Unk nown Source)
CF> at
CF> org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
CF> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
CF> at org.eclipse.core.runtime.Platform.run(Platform.java:857)
CF> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
CF> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 3)
CF> at
CF> org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
CF> at
CF> org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
CF> at
CF> org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
CF> at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
CF> at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
CF> at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
CF> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
CF> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
CF> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
CF> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
CF> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
CF> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
CF> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
CF> at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
CF> at
CF> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
CF> at
CF> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
CF> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
CF> at
CF> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
CF> at
CF> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
CF> at
CF> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
CF> at
CF> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
CF> at
CF> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
CF> at
CF> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
CF> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
CF> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
CF> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
CF> at java.lang.reflect.Method.invoke(Unknown Source)
CF> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
CF> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
CF> at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
Seva Lapsha
[slapsha@dev.eclipse.org]
Zend Eclipse Developer
Re: Cannot open *.module file in php editor [message #41711 is a reply to message #41648] Thu, 09 August 2007 04:42 Go to previous messageGo to next message
Goto Windows -> Preferences -> General -> Content Types -> Text -> PHP ->
add *.module to the list
then try to reopen the documents.
still we need to handle the situation that one opens a non-php file in PHP
editor.
Re: Cannot open *.module file in php editor [message #44622 is a reply to message #41648] Mon, 20 August 2007 13:47 Go to previous message
The last PDT update seems to solve my problem. In addition I followed
Roy's advice and added *.module in the Content Types. Now everything
works fine.
Thanks to you both!
Yours
Claudia
Previous Topic:Problems occoured restoring workbench
Next Topic:Pre built Binary of XDebug Support
Current Time: Sat Sep 06 16:31:07 EDT 2025
Powered by FUDForum. Page generated in 0.02544 seconds
