Home » Eclipse Projects » Eclipse Platform » /links directory
/links directory [message #41321] Wed, 21 May 2003 04:17 Go to next message
Where can I find information on how the /links directory is used?
I saw that MyEclipse used it for including it as a plugin in
I wanted to do the same thing with my common plugins to minimize the hazzle of
upgrading Eclipse.
Jimisola
Re: /links directory [message #41609 is a reply to message #41321] Wed, 21 May 2003 08:21 Go to previous messageGo to next message
I think this is the information you are looking for.
http://eclipsewiki.swiki.net/131#four
Andreas
> upgrading Eclipse.
> Jimisola
Re: /links directory [message #41720 is a reply to message #41321] Wed, 21 May 2003 08:51 Go to previous messageGo to next message
> upgrading Eclipse.
links/<name>.links:
a java property file with content:
path=<absolute path to a dir>
The dir needs to contains a subdir eclipse with two subdirs
plugins and features, which contain the actual content.
You can also do a
path=[r |rw ]<absolute path>
where 'r ' stands for read only acces and 'rw ' (or nothing) for read
write access to this site.
<advertising>
See http://bugs.eclipse.org/bugs/show_bug.cgi?id=36101 for a patch
to add a site via comandline option.
Jan
Re: /links directory [message #45874 is a reply to message #41720] Fri, 23 May 2003 10:30 Go to previous messageGo to next message
Originally posted by: dominic.nospam.com
why the heck is it supposed to contain eclipse subdir ? was it not possible
to point directly to it ?
"Jan Schulz" <muelleimer@usenet.katzien.de> wrote in message
news:slrnbcmtj8.23u.muelleimer@snoopy.katzien.de...
hazzle of
> > upgrading Eclipse.
> links/<name>.links:
> You can also do a
> <advertising>
> Jan
Re: /links directory [message #46370 is a reply to message #45874] Fri, 23 May 2003 11:27 Go to previous messageGo to next message
Not really sure, but there are several 'Plan Items', which are related
to platform configuration. Have a look at them and add you
comments...
Jan
Association of a class with a corresponding java source [message #56847 is a reply to message #46370] Fri, 30 May 2003 17:00 Go to previous message
Originally posted by: agodin.denovis.com
I wonder whether anybody knows how to associate a class ( or a folder
containing a bunch of classes) with a Java file ( or a folder containing
java files).
When I debug and step in ( via F5) into a method from another package I see
the class ( rather than Java file) and decompiled source ( rather than
original Java file). This makes it impossible to determine at what line I am
actually experiencing a problem. In other words the real debugging process
gets totally broken.
I am sure it's a trivial issue for experienced Eclipse IDE users, but for
the novice user, like myself, I couldn't figure out the key words to use to
get into the proper explanation in a HELP.
Thanks in advance,
Arkady Godin
Previous Topic:Using Different Project Files
Next Topic:hyperlinks in source code
Current Time: Sat Nov 08 11:56:00 EST 2025
Powered by FUDForum. Page generated in 0.06036 seconds
