Home » Eclipse Projects » DTP » Installing DTP
Installing DTP [message #3522] Wed, 26 October 2005 01:06 Go to next message
Originally posted by: christopher_brown.engin.com.au
Let me know if I should be using the newcomers' group for this query.
I have just installed DTP but I can't get it to connect to an Informix
database.
I've installed the jdbc drivers. I already have an app that connects to
the database so I've used parameters from here to set up the Eclipse
connection.
I'm using a jdbc url of the form shown below (gleaned from Informix docs)
jdbc:informix-sqli://123.45.67.89:1533/testDB:INFORMIXSERVER =myserver
When I test the connection I get the following error message
java.lang.RuntimeException: Ping failed!
at org.eclipse.datatools.connectivity.ui.PingJob.run(PingJob.ja va:60)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
I'd appreciate any advice on getting DTP working
Chris
Re: Installing DTP [message #3557 is a reply to message #3522] Wed, 26 October 2005 10:49 Go to previous messageGo to next message
Originally posted by: jograham.sybase.com
Chris wrote:
> database.
> connection.
> Thanks
> Chris
Hi Chris:
The DTP iteration build includes the connection framework and sample JDBC
connection profile as you have found. We're working on stabilizing these
components and adding functionality toward our M1 and M2 drops. Currently
I think it is best to consider these particular components as "disclosure"
and "review," since they were added more to give the community a chance to
understand what the framework and a sample connection profile looks like.
Even if you could connect at this time, there's little that could be done
beyond that -- the models are not integrated with the sample connection
profile and the Data Source Explorer is not in place (so you can't inspect
the connection for tables, stored procs, etc.). We are working on getting
this functionality in over the M1 and M2 time frames. Probably this is not
a very satisfying answer to your question, but it does reflect the current
DTP state and plans.
Having said this, however, we are also very interested in your results --
ideally I'd like to see the "Test Connection" succeed. Offhand I'm not
sure why it is failing, but we will take a look to see if there are
problems that can be isolated and fixed in the sort term, so at least that
level of functionality is demonstrable.
John Graham
Eclipse Data Tools Platform PMC
Re: Installing DTP [message #3590 is a reply to message #3557] Wed, 26 October 2005 14:06 Go to previous messageGo to next message
I try it, too, but i think that success 'test connection' is impossible
with current cvs (probably M1)
I debug connection and connection factory class JDBCConnectionFactory
have two method createConnection and both return null - it work nothing
There is problem with datatols cvs, too.I currently get next error
cvs checkout: cannot open
directory /home/datatools/org.eclipse.datatools.connectivity/attic:
Permission denied
cvs checkout: skipping directory org.eclipse.datatools.connectivity/attic
Peco
John Graham wrote:
> Chris wrote:
>> database.
>> connection.
>> Thanks
>> Chris
> Hi Chris:
> John Graham
Re: Installing DTP [message #3623 is a reply to message #3590] Wed, 26 October 2005 13:06 Go to previous messageGo to next message
Haris Peco wrote:
> Hello,
> Permission denied
> Peco
Peco,
Thank you for this further information. I will make the Connectivity team
aware of this, and we'll see what can/should be done in the near term.
Regarding the CVS "attic": we've moved the transitional plug-ins from the
root of Connectivity to this attic to make it easier for people to
evaluate CVS. I will check with the Web Master about why access is denied,
since you should be able to check out from this location if you want to
(The plug-ins in the attic might be removed from DTP completely or
refactored substantially, so I wouldn't pay too much attention to them at
the moment.)
John Graham
Re: Installing DTP [message #3656 is a reply to message #3623] Wed, 26 October 2005 15:25 Go to previous messageGo to next message
John Graham wrote:
> Peco,
> the moment.)
This is permission on this directory (maybe subdirectory) only - cvs program
on your server can't access to this directory
change permission and leave old plugins - old plugins work (not too good,
but work)
Re: Installing DTP [message #3689 is a reply to message #3656] Wed, 26 October 2005 14:30 Go to previous messageGo to next message
> but work)
> Thanks
Peco,
The attic has been fixed, and you should now be able to access it.
John
Re: Installing DTP [message #3720 is a reply to message #3689] Wed, 26 October 2005 19:38 Go to previous message
John Graham wrote:
>> program on your server can't access to this directory
>> but work)
>> Thanks
> Peco,
> John
yes.thanks.we wait any usable release
Re: Installing DTP [message #4087 is a reply to message #3557] Wed, 26 October 2005 18:16 Go to previous message
John Graham wrote:
> Hi Chris:
John
Thanks for your reply. I realised, after digging around, that I'd probably
jumped in a little too early in this project life-cycle.
I have to say that I like what I've seen so far so I don't have a problem
with your response. I'll see if I can use web tools platform just for the
database connectivity in the meantime.
Chris
Re: Installing DTP [message #567497 is a reply to message #3522] Wed, 26 October 2005 10:49 Go to previous message
Chris wrote:
> database.
> connection.
> Thanks
> Chris
Hi Chris:
John Graham
Re: Installing DTP [message #567525 is a reply to message #3557] Wed, 26 October 2005 14:06 Go to previous message
Permission denied
Peco
John Graham wrote:
> Chris wrote:
>> database.
>> connection.
>> Thanks
>> Chris
> Hi Chris:
> John Graham
Re: Installing DTP [message #567551 is a reply to message #3590] Wed, 26 October 2005 13:06 Go to previous message
Haris Peco wrote:
> Hello,
> Permission denied
> Peco
Peco,
the moment.)
John Graham
Re: Installing DTP [message #567569 is a reply to message #3623] Wed, 26 October 2005 15:25 Go to previous message
John Graham wrote:
> Peco,
> the moment.)
but work)
Re: Installing DTP [message #567607 is a reply to message #3656] Wed, 26 October 2005 14:30 Go to previous message
> but work)
> Thanks
Peco,
John
Re: Installing DTP [message #567635 is a reply to message #3689] Wed, 26 October 2005 19:38 Go to previous message
>> but work)
>> Thanks
> Peco,
> John
Re: Installing DTP [message #567684 is a reply to message #3557] Wed, 26 October 2005 18:16 Go to previous message
John Graham wrote:
> Hi Chris:
John
Chris
Previous Topic:Installing DTP
Next Topic:M1 Iteration 3 build available
Current Time: Fri Nov 07 03:09:54 EST 2025
Powered by FUDForum. Page generated in 0.30816 seconds
