Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » CDO and Derby
CDO and Derby [message #40779] Mon, 24 July 2006 13:15 Go to next message
I have now tested cdo and derby:
In the cvs version of cdo the server.properties is set to use of derby.
Where are hte derby db files saved? or how are they named, so that I can
search them?
I also get the following error if I use the Client1 launch configuration.
Can anyone help me?
Re: CDO and Derby [message #40809 is a reply to message #40779] Mon, 24 July 2006 13:19 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
Chris,
The Derby DB files are usually created under the working directory.
I can't see the error you speak of. But most of the times you have to
adjust the working directory and add any required plugins.
Cheers
/Eike
> search them?
> Can anyone help me?
Re: CDO and Derby [message #40839 is a reply to message #40809] Mon, 24 July 2006 13:25 Go to previous messageGo to next message
--No Derbyfiles are created ?
Have forgotten to add the exception:
--> TEST: Create an EMF ResourceSet and associate it with a CDO
ResourceManager
[INFO] common.client.connector: Connected socketChannel:
java.nio.channels.SocketChannel[connected local=/127.0.0.1:1989
remote=localhost/127.0.0.1:2036]
[ERROR] common.client.packageManager: Error while processing
ServiceEvent START
java.lang.RuntimeException:
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: The
processing instruction target matching "[xX][mM][lL]" is not allowed.
org.eclipse.emf.cdo.client.impl.PackageManagerImpl.getMappin gProvider(PackageManagerImpl.java:174)
org.eclipse.emf.cdo.client.impl.PackageManagerImpl.addPackag e(PackageManagerImpl.java:104)
org.eclipse.emf.cdo.client.impl.PackageManagerImpl.processMa ppings(PackageManagerImpl.java:319)
org.eclipse.emf.cdo.client.impl.PackageManagerImpl.validate( PackageManagerImpl.java:329)
org.eclipse.net4j.spring.impl.ServiceImpl$ServiceStateMachin e$Transition_Start.process(ServiceImpl.java:950)
org.eclipse.net4j.spring.impl.ServiceImpl$ServiceStateMachin e$Transition_Start.process(ServiceImpl.java:1)
at org.eclipse.net4j.util.fsm.StateMachine.process(StateMachine .java:133)
org.eclipse.net4j.spring.impl.ServiceImpl.processServiceEven t(ServiceImpl.java:812)
at org.eclipse.net4j.spring.impl.ServiceImpl.start(ServiceImpl. java:204)
org.eclipse.net4j.spring.impl.ServiceImpl.afterPropertiesSet (ServiceImpl.java:225)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.invokeInitMethods(AbstractAutowireCapableBe anFactory.java:1091)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.createBean(AbstractAutowireCapableBeanFacto ry.java:396)
org.springframework.beans.factory.support.AbstractBeanFactor y.getBean(AbstractBeanFactory.java:233)
org.springframework.beans.factory.support.AbstractBeanFactor y.getBean(AbstractBeanFactory.java:145)
org.springframework.beans.factory.support.DefaultListableBea nFactory.getBeansOfType(DefaultListableBeanFactory.java:211)
org.springframework.context.support.AbstractApplicationConte xt.getBeansOfType(AbstractApplicationContext.java:596)
org.springframework.context.support.AbstractApplicationConte xt.registerListeners(AbstractApplicationContext.java:478)
org.springframework.context.support.AbstractApplicationConte xt.refresh(AbstractApplicationContext.java:310)
org.eclipse.net4j.spring.impl.ContainerImpl.<init>(ContainerImpl.java:55)
org.eclipse.net4j.spring.impl.ContainerImpl.<init>(ContainerImpl.java:70)
org.eclipse.emf.cdo.examples.client.internal.ExampleClientPl ugin.getClientContainer(ExampleClientPlugin.java:146)
org.eclipse.emf.cdo.examples.client.internal.ExampleClientPl ugin.createResourceManager(ExampleClientPlugin.java:164)
org.eclipse.emf.cdo.examples.library.ui.internal.actions.Cre ateResourceAction.createResource(CreateResourceAction.java:7 8)
org.eclipse.emf.cdo.examples.library.ui.internal.actions.Cre ateResourceAction.run(CreateResourceAction.java:64)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: org.eclipse.emf.ecore.resource.Resource$IOWrappedException:
The processing instruction target matching "[xX][mM][lL]" is not allowed.
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:199)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:179)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1089)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:895)
org.eclipse.emf.cdo.client.impl.XMLMappingProviderImpl.loadM appingModel(XMLMappingProviderImpl.java:77)
org.eclipse.emf.cdo.client.impl.XMLMappingProviderImpl.<init >(XMLMappingProviderImpl.java:41)
org.eclipse.emf.cdo.client.impl.PackageManagerImpl.getMappin gProvider(PackageManagerImpl.java:158)
... 50 more
Caused by: org.xml.sax.SAXParseException: The processing instruction
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. createSAXParseException(Unknown
Source)
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. fatalError(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.rep ortError(Unknown
Source)
Source)
com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFat alError(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLScanner.scanPIDat a(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanPIData(Unknown
Source)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.scanPI(Un known
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$PrologDispatcher.dispatch(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
... 56 more
--> TEST: Create a new CDO Resource
org.eclipse.net4j.core.UnknownProtocolException: Protocol cdo is not
registered with client
org.eclipse.net4j.core.impl.AbstractConnector.findProtocol(A bstractConnector.java:289)
org.eclipse.net4j.core.impl.AbstractConnector.addChannel(Abs tractConnector.java:122)
org.eclipse.emf.cdo.client.impl.ResourceManagerImpl.getChann el(ResourceManagerImpl.java:210)
org.eclipse.emf.cdo.client.impl.CDOResourceFactoryImpl.creat eResourceFromPath(CDOResourceFactoryImpl.java:128)
org.eclipse.emf.cdo.client.impl.CDOResourceFactoryImpl.creat eResource(CDOResourceFactoryImpl.java:71)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.createRe source(ResourceSetImpl.java:410)
org.eclipse.emf.cdo.examples.library.ui.internal.actions.Cre ateResourceAction.createResource(CreateResourceAction.java:8 2)
Eike Stepper schrieb:
> Chris,
> Cheers
> /Eike
>> search them?
>> Can anyone help me?
Re: CDO and Derby [message #40870 is a reply to message #40839] Mon, 24 July 2006 13:29 Go to previous messageGo to next message
OK your right:
Working directory was in both cases Desktop, so this could not work.
Thanx for fast answer!
Have you seen my bugrequest in Bugzilla?
Re: CDO and Derby [message #40901 is a reply to message #40870] Tue, 25 July 2006 01:12 Go to previous messageGo to next message
Chris Lenz schrieb:
> OK your right:
So the exception does not occur anymore?
Yes, I've seen it ;-)
I like the idea to have a query facility for CDO.
But I fear that a server-side OCL is far beyond what I can do.
I could start with SQL as a query language and maybe I can make that
part extensible on the server side...
The other point in your request seems to be about sharing EObjects
between ResourceSets.
That's indeed one of the features I'm thinking about for the next release.
The main reason for that is the fact that only ever one transaction is
possible per ResourceSet.
The only way to conduct several transactions on the same Resources is to
create a ResourceSet for each transaction.
And in general that's only feasible if the creation of a ResourceSet is
very cheap (at least if the contents are already at the client).
My favorite solution to the problem is to move the whole state of all
EObjects into EStores.
There I can implement the sharing and the transactional bevahiour.
There it's even easier to implement a transparent object versioning (as
requested by other users).
In fact that would make CDO even less invasive to the underlying Ecore
model.
It would no longer be necessary to make all model classes inherit from
CDOPersistent and use modified JET templates.
To CDO'ish a model it would be sufficient to slightly modify the Genmodel:
Feature Delegation = Reflective
Root Extends Class = org.eclipse.emf.cdo.client.impl.CDOPersistent
In addition this would make it possible (or at least easier) to provide
a feature based lazy loading.
Or something like fetch groups...
But I'm sure that all this will take a while. At the moment I'm
investigating ways to:
a) Replace the Spring Framework by proper OSGi Services
b) Optionally replace Net4j by proper Web Services (I'm currently
playing with Hessian)
c) Provide distributed write-through caches for large deployments
d) Provide shared sessions (see above)
e) Provide time travel sessions
Cheers
/Eike
Re: CDO and Derby [message #40962 is a reply to message #40901] Wed, 26 July 2006 02:44 Go to previous messageGo to next message
Sorry have been ill for one day :-(;
yes exception does not occur any more.
Question:
Is it possible to change the structure of an emf (datastructure) and
also change the structure of the database.
Chris
> Chris Lenz schrieb:
>> OK your right:
> model.
> Cheers
> /Eike
Re: CDO and Derby - Model Save Exception (BadSqlGrammarException) [message #41116 is a reply to message #40779] Wed, 26 July 2006 03:46 Go to previous messageGo to next message
But If I now save my Organizational Model to CDO(Derby) I get the
following exception? Do you have an IDE
Initializing container cdo (net4j)
HIT ENTER FOR SHUTDOWN!!!
[INFO] net4j.slave-1: Connected socketChannel:
java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036
remote=/127.0.0.1:2356]
Exception in thread "pool-1-thread-2"
org.springframework.jdbc.BadSqlGrammarException:
PreparedStatementCallback; bad SQL grammar [INSERT IGNORE INTO USER VALUES(?,
?)]; nested exception is SQL Exception: Syntax error: Encountered "USER"
at line 1, column 13.
ERROR 42X01: Syntax error: Encountered "USER" at line 1, column 13.
at org.apache.derby.iapi.error.StandardException.newException(U nknown
Source)
at org.apache.derby.impl.sql.compile.ParserImpl.parseStatement( Unknown
Source)
at org.apache.derby.impl.sql.GenericStatement.prepMinion(Unknow n Source)
at org.apache.derby.impl.sql.GenericStatement.prepare(Unknown Source)
org.apache.derby.impl.sql.conn.GenericLanguageConnectionCont ext.prepareInternalStatement(Unknown
Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement20.<init>(Unknown
Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement30.<init>(Unknown
Source)
at org.apache.derby.jdbc.Driver30.newEmbedPreparedStatement(Unk nown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.prepareStatement( Unknown
Source)
Source)
org.springframework.jdbc.core.JdbcTemplate$SimplePreparedSta tementCreator.createPreparedStatement(JdbcTemplate.java:1134 )
org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTempl ate.java:470)
at org.springframework.jdbc.core.JdbcTemplate.update(JdbcTempla te.java:691)
at org.springframework.jdbc.core.JdbcTemplate.update(JdbcTempla te.java:753)
at org.springframework.jdbc.core.JdbcTemplate.update(JdbcTempla te.java:757)
at org.eclipse.emf.cdo.server.impl.MapperImpl.sql(MapperImpl.ja va:665)
org.eclipse.emf.cdo.server.protocol.CommitTransactionIndicat ion.receiveObjectsToAttachAttributes(CommitTransactionIndica tion.java:585)
org.eclipse.emf.cdo.server.protocol.CommitTransactionIndicat ion.receiveObjectsToAttach(CommitTransactionIndication.java: 178)
org.eclipse.emf.cdo.server.protocol.CommitTransactionIndicat ion.access$1(CommitTransactionIndication.java:155)
org.eclipse.emf.cdo.server.protocol.CommitTransactionIndicat ion$1.doInTransactionWithoutResult(CommitTransactionIndicati on.java:79)
org.springframework.transaction.support.TransactionCallbackW ithoutResult.doInTransaction(TransactionCallbackWithoutResul t.java:33)
org.springframework.transaction.support.TransactionTemplate. execute(TransactionTemplate.java:114)
org.eclipse.emf.cdo.server.protocol.CommitTransactionIndicat ion.indicate(CommitTransactionIndication.java:74)
org.eclipse.net4j.core.impl.ChannelImpl$SignalTask.processSi gnal(ChannelImpl.java:853)
org.eclipse.net4j.core.impl.ChannelImpl$SignalTask.run(Chann elImpl.java:789)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unkno wn Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Re: CDO and Derby - Model Save Exception (BadSqlGrammarException) [message #41178 is a reply to message #41116] Wed, 26 July 2006 04:24 Go to previous messageGo to next message
> Source)
> Source)
> at
> Source)
> Source)
> Source)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
on mysql it is still working
Re: CDO and Derby - Model Save Exception (BadSqlGrammarException) [message #41334 is a reply to message #41178] Wed, 26 July 2006 09:56 Go to previous messageGo to next message
Chris,
I assume, that on Mysql "USER" is not a reserved word, on Derby it seems
to be.
Maybe the Derby SQL statements can be enriched with quotes. You can have
a look into org.eclipse.emf.cdo.dbgen.derby (.mysql respectively).
You could avoid suspicious identifiers in your model.
Or you can modify the generated mapping file and rename the table or column.
Cheers
/Eike
>> Source)
>> Source)
>> at
>> Source)
>> Source)
>> Source)
>> Source)
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: CDO and Derby [message #41395 is a reply to message #40962] Wed, 26 July 2006 10:01 Go to previous messageGo to next message
Chris,
I'm not sure what you want to achieve.
CDO can't automatically adapt its repository to new Ecore models.
Other users have successfully copied whole CDOResources into another
repository.
I could imagine, that you can load a resource with its old model,
manually copy/adjust and then save into a new resource.
Cheers
/Eike
> Question:
> Chris
>> Chris Lenz schrieb:
>>> OK your right:
>> model.
>> Cheers
>> /Eike
Re: CDO and Derby - Model Save Exception (BadSqlGrammarException) [message #41576 is a reply to message #41334] Thu, 27 July 2006 03:05 Go to previous messageGo to next message
If I change something in the code, i it possible to check it in.
How does this work.
Chris
> Chris,
> to be.
> column.
> Cheers
> /Eike
>>> at
>>> Source)
>>> at
>>> Source)
>>> Source)
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Source)
>>> Source)
Re: CDO and Derby - Model Save Exception (BadSqlGrammarException) [message #41634 is a reply to message #41576] Thu, 27 July 2006 08:24 Go to previous message
Chris,
You can attach a patch to a newsgroup message or to a bugzilla.
I will review it and apply it if appropriate.
Cheers
/Eike
> How does this work.
> Chris
>> Chris,
>> to be.
>> column.
>> Cheers
>> /Eike
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> Source)
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Source)
>>>> Source)
Re: CDO and Derby [message #583054 is a reply to message #40779] Mon, 24 July 2006 13:19 Go to previous message
Chris,
Cheers
/Eike
> search them?
> Can anyone help me?
Re: CDO and Derby [message #583069 is a reply to message #40809] Mon, 24 July 2006 13:25 Go to previous message
ResourceManager
ServiceEvent START
... 50 more
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
... 56 more
> Chris,
> Cheers
> /Eike
>> search them?
>> Can anyone help me?
Re: CDO and Derby [message #583081 is a reply to message #40839] Mon, 24 July 2006 13:29 Go to previous message
OK your right:
Re: CDO and Derby [message #583104 is a reply to message #40870] Tue, 25 July 2006 01:12 Go to previous message
Chris Lenz schrieb:
> OK your right:
model.
Cheers
/Eike
Re: CDO and Derby [message #583138 is a reply to message #40901] Wed, 26 July 2006 02:44 Go to previous message
Question:
Chris
> Chris Lenz schrieb:
>> OK your right:
> model.
> Cheers
> /Eike
Re: CDO and Derby - Model Save Exception (BadSqlGrammarException) [message #583195 is a reply to message #40779] Wed, 26 July 2006 03:46 Go to previous message
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Re: CDO and Derby - Model Save Exception (BadSqlGrammarException) [message #583235 is a reply to message #41116] Wed, 26 July 2006 04:24 Go to previous message
> Source)
> Source)
> at
> Source)
> Source)
> Source)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: CDO and Derby - Model Save Exception (BadSqlGrammarException) [message #583319 is a reply to message #41178] Wed, 26 July 2006 09:56 Go to previous message
Chris,
to be.
Cheers
/Eike
>> Source)
>> Source)
>> at
>> Source)
>> Source)
>> Source)
>> Source)
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: CDO and Derby [message #583354 is a reply to message #40962] Wed, 26 July 2006 10:01 Go to previous message
Chris,
repository.
Cheers
/Eike
> Question:
> Chris
>> Chris Lenz schrieb:
>>> OK your right:
>> model.
>> Cheers
>> /Eike
Re: CDO and Derby - Model Save Exception (BadSqlGrammarException) [message #583466 is a reply to message #41334] Thu, 27 July 2006 03:05 Go to previous message
How does this work.
Chris
> Chris,
> to be.
> column.
> Cheers
> /Eike
>>> at
>>> Source)
>>> at
>>> Source)
>>> Source)
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Source)
>>> Source)
Re: CDO and Derby - Model Save Exception (BadSqlGrammarException) [message #583494 is a reply to message #41576] Thu, 27 July 2006 08:24 Go to previous message
Chris,
Cheers
/Eike
> How does this work.
> Chris
>> Chris,
>> to be.
>> column.
>> Cheers
>> /Eike
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> Source)
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Source)
>>>> Source)
Previous Topic:CDO Open Resource Q
Next Topic:"OCL Error" posting lost in space?
Current Time: Sat Nov 08 13:28:59 EST 2025
Powered by FUDForum. Page generated in 0.06903 seconds
