Home » Eclipse Projects » Plugin Development Environment (PDE) » How are you writing plugins for eclipse?
How are you writing plugins for eclipse? [message #39838] Sat, 10 January 2009 02:02 Go to next message
I have spent a lot of time to wait to restart the eclipse IDE, every time I
changed a plugin(XYZ), I must:
1) quit the eclipse
2) delete the previous version of the plugin(XYZ)
3) launch eclipse, to clear the plugin cache
4) quit again
5) put the new version of the plugin(XYZ) under dropins/ folder
6) launch eclipse again, now the new plugin(XYZ) is loaded.
I don't know how you guys develop plugins, I've searched how to `reload a
plugin' but got nothing, all said must restart the eclipse and sometimes you
need to specify `eclipse -clean' for a more cleaned restart.
And I've tried wrap my plugins in a `feature', and put that `feature' in an
`update-site', then `install' the feature. And when you want to reload the
plugin, you can `uninstall' it and then `install' it, but it doesn't work!
And I even don't know what a `feature' really is, why not call it
`plugins-bundle' or `enterprise plugin' etc. And why not make the plugin
just reloadable, or even auto reload at runtime by checking the modification
time of the jar file, just as most JSP Container(tomcat, resin, etc.) did.
How are you writing plugins for eclipse? Is there any better way to reload a
plugin?
Lenik
Re: How are you writing plugins for eclipse? [message #39876 is a reply to message #39838] Sat, 10 January 2009 11:04 Go to previous messageGo to next message
Originally posted by: dev-null.knittig.de
> reload a plugin?
Use a different Eclipse installation for plugin development:
Preferences -> Plug-in Development -> Target Platform
Markus
Re: How are you writing plugins for eclipse? [message #39999 is a reply to message #39838] Mon, 12 January 2009 09:26 Go to previous message
> time I changed a plugin(XYZ), I must:
> 1) quit the eclipse
> 4) quit again
> a plugin' but got nothing, all said must restart the eclipse and
> sometimes you need to specify `eclipse -clean' for a more cleaned restart.
There is no need to test your plugin by installing it into your
development environment. Eclipse can launch a new instance of itself
that includes your plugin(s). The easiest way I know is right from the
plugin.xml editor (or manifest.mf editor) - there is a section titled
"Testing" that contains convenient links to launch your plugin.
Also, there is this page in the help:
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/firstplugin_run.htm
By the way, you will often see this mode referred to as "self-hosting."
Hope this helps,
Eric
> an `update-site', then `install' the feature. And when you want to
> reload the plugin, you can `uninstall' it and then `install' it, but it
> doesn't work!
> modification time of the jar file, just as most JSP Container(tomcat,
> resin, etc.) did.
> reload a plugin?
> Lenik
Re: How are you writing plugins for eclipse? [message #588070 is a reply to message #39838] Sat, 10 January 2009 11:04 Go to previous message
> reload a plugin?
Markus
Re: How are you writing plugins for eclipse? [message #588127 is a reply to message #39838] Mon, 12 January 2009 09:26 Go to previous message
> 1) quit the eclipse
> 4) quit again
Hope this helps,
Eric
> doesn't work!
> resin, etc.) did.
> reload a plugin?
> Lenik
Previous Topic:Feature dependency match rules
Next Topic:EclipsePDE Build Tutorial
Current Time: Wed Jul 09 09:30:47 EDT 2025
Powered by FUDForum. Page generated in 0.04770 seconds
