Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] Materializing workspace using PDEMapProvider
Re: [buckminster-dev] Materializing workspace using PDEMapProvider [message #3434] Wed, 13 February 2008 15:08
Todd_Lee@amis.com wrote:
> Thanks for the reply Thomas,
> I did see your dogfood2 rmap, and I'm using that as a template. I'm trying
> to understand the nature of the matching though.
> We have only one map directory, with many .map files. So if I create a top
> level buckminster.cspec that declares dependencies on my top level features
> (and as you said, lower level features/plugins will be handled
> transitively) does buckminster check all of the .map files in the map
> folder as specified in the provider uri?
Yes. The PDEMapProvider will start by loading all of the map files that
it finds in the designated folder and build an in-memory catalog of all
the components.
> eg
> - my cspec declares a dependency on 'my.com.platform-feature'
> (componentType eclipse.feature)
> - I have the following map files: platform.map (which actually includes the
> above feature and it's required plugins etc) along with feature2.map and
> feature3.map.
> Is there any regex matching to find a particular map file for my declared
> dependency on my.com.platform-feature (ie - do I have to somehow 'map' the
> component name to the correct map file?) or does buckminster just check
> *.map in the maps directory to find an appropriate match?
The only regexp mapping that occurs is when the resolver determines what
searchPath that should be use. Once that has been determined, each
provider found in that search path is consulted. If a PDEMapProvider is
encountered, and if any of the maps that resides in the folder that it
appoints contains the desired component, then that provider has found a
match. It will then delegate to the provider that the actual map entry
is pointing to (typically cvs).
Thomas Hallgren
Previous Topic:Re: [buckminster-dev] Materializing workspace using PDEMapProvider
Next Topic:[buckminster-dev] Help to buckminster
Current Time: Wed Jul 30 08:51:26 EDT 2025
Powered by FUDForum. Page generated in 0.06845 seconds
