Home » Modeling » EMF » Proper way to add custom property editor
Re: Proper way to add custom property editor [message #390480 is a reply to message #390477] |
Sat, 15 January 2005 16:37   |
Joël Cheuoua Messages: 36 Registered: July 2009 |
Member |
Hello Eric,
I agree with you that this is not the easier part when using/customizing
EMF.
I think the answer is already somewhere in this newsgroups, but I'll try
to summarize it with what I understood, and give you my 2 cents tips.
Basically, as you already noticed, you'll need three things : The
ContentProvider, The PropertySource and The PropertyDescriptor. It may
sound cumbersome, but this is actually the finest way to control the
edition :
ContentProvider <=> provide property source for all model instances
PropertySource <=> on a model instance provide property descriptors for
all features
PropertyDescriptors <=> on an instance feature, control the
rendering/edition of the instance's feature value.
Here are the basic steps to go :
1 ) - You need to ammend your generated Editor Class : Check for the
getPropertySheetPage() method in this class, and change the
AdapterFactoryContentProvider PropertySourceProvider setted on the the
propertySheetPage to a CustomAdapterFactoryContentProvider class that
you'll create.
2 ) - Create the CustomAdapterFactoryContentProvider : It may basically be
as simple as this :
* @author Joël
* TODO To change the template for this generated type comment go to
* Window - Preferences - Java - Code Style - Code Templates
public class ModelMappingAdapterFactoryContentProvider extends
AdapterFactoryContentProvider {
* @param adapterFactory
public CustomAdapterFactoryContentProvider(AdapterFactory
adapterFactory) {
super(adapterFactory);
* @see
AdapterFactoryContentProvider#createPropertySource(java.lang .Object,
* org.eclipse.emf.edit.provider.IItemPropertySource)
protected IPropertySource createPropertySource(Object object,
IItemPropertySource itemPropertySource) {
return new CustomPropertySource(adapterFactory, object,
itemPropertySource);
3 ) Create the CustomPropertySource class that may look like this :
* @author Joël
public class CustomPropertySource extends PropertySource {
private AdapterFactory adapterFactory;
* @param object
* @param itemPropertySource
public CustomPropertySource(AdapterFactory adapterFactory, Object
object, IItemPropertySource itemPropertySource) {
super(object, itemPropertySource);
this.adapterFactory = adapterFactory;
* @see
PropertySource#createPropertyDescriptor(org.eclipse.emf.edit .provider.IItemPropertyDescriptor)
protected IPropertyDescriptor
createPropertyDescriptor(IItemPropertyDescriptor itemPropertyDescriptor) {
return new CustomPropertyDescriptor(adapterFactory, object,
itemPropertyDescriptor);
4 ) Then create the CustomPropertyDescriptor class :
* @author Joël
public class CustomPropertyDescriptor extends PropertyDescriptor {
* @param object
* @param itemPropertyDescriptor
public CustomPropertyDescriptor(AdapterFactory adapterFactory, Object
object, IItemPropertyDescriptor itemPropertyDescriptor) {
super(object, itemPropertyDescriptor);
* (non-Javadoc)
* @see
org.eclipse.ui.views.properties.IPropertyDescriptor#createPr opertyEditor(org.eclipse.swt.widgets.Composite)
public CellEditor createPropertyEditor(Composite composite) {
Object feature = itemPropertyDescriptor.getFeature(object);
if (feature == /* TODO : Some file type kind feature */) {
final String dialogLabel =
CustomEMFPlugin.INSTANCE.getString("_UI_SelectFile_label");
CellEditor cellEditor = new DialogCellEditor(composite) {
protected Object openDialogBox(Control cellEditorWindow) {
ResourceSelectionDialog resourceSelectionDialog= new
ResourceSelectionDialog(cellEditorWindow
.getShell(), ResourcesPlugin.getWorkspace().getRoot(),
dialogLabel);
resourceSelectionDialog.open();
Object[] result = resourceSelectionDialog.getResult();
if (result != null) {
for (int i = 0; i < result.length; i++) {
if (result[i] instanceof IResource) {
IResource resource = (IResource) result[i];
return resource.getFullPath().toString();
return null;
return cellEditor;
return super.createPropertyEditor(composite);
At that point, you'll probably wonder why I pass the adapter factory as a
parameter to the CustomPropertySource and CustomPropertyDescriptor whereas
I don't use them and moreover the default implementation didn't do that ?
Well this is because - to my humble opinion - here could be several right
places to simplify the whole mechanism, at least for the EMF user point of
view, and make the Customxxx classes more generic : The adapterFactory
object is an adapter factory right ? - sounds like a "lapalissade" like we
said in France ;). So the property source, the property descriptor, and/or
more simply the cell editor can be adapters returned by the
adapterFactory.adapt(Object object, Object type) method instead of
creating a static instance each time in the createXXX methods.
It's up to you to choose how you may want to use this adapterFactory. At a
first glance, the easiest way seems to use what is already done for the
generated ItemProvider classes : You can amend ItemProvider classes so
that they return cell editor descriptors for defined features, and get
access to the Item providers by calling adapt() on the adapterFactory.
Of course for now you'll have to do the custom classes creation "by hand"
at least once, and you'll have to be careful that the code generation
didn't get rid of your customizations especially for the editor class. You
can also modify the JET Templates so that the generated code will reflect
all the changes :
1 ) changes to the Editor Class (custom contentprovider)
2 ) changes to the Item Provider Classes (methods for returnin
PropertyDescriptors/CellEditors given a feature)
I hope this can help.
Joel.
Eric Giguère wrote:
> Hi all
> I've been reading for a while concerning the PropertySheet view and the
> editors. I found the EMF class responsible for the custom editors we see
> while editing an ecore model. Nice implementation but a little complex.
> So from what I've understood, the class AdapterFactoryContentProvider is
> the root of it all for EMF. This guy create an EMF specific PropertySource
> which in turn creates an EMF specific PropertyDescriptor object. The later
> is responsible for creating the right editor based on the type of item
> selected in the Properties view using the method : getEditor.
> Since I don't fully understand the mechanism through wich all these
> factories are loaded and used by the framework (but I'll get it) what
> would be the better way to add a new editor that would trig a an
> EDataType? For some context info. I'm building extended models and while
> doing so, I add attributes that will hold some specification text. Editing
> text using the default string editor is not very practical so instead, I
> want to create a simple property editor that will present a TextArea
> instead of the embedded single line string editor.
> How do we include custom PropertyDescriptors? Through the adapterFactory
> object created in our editor?
> thx for any pointers.
> Eric.
Re: Proper way to add custom property editor [message #390493 is a reply to message #390480] |
Tue, 18 January 2005 16:27  |
Eric Giguere Messages: 58 Registered: July 2009 |
Member |
eheh
Thx a lot Joel
I'll try that tonight ;)
And yes, that part is not the easiest to pick but I'm getting there.
Eclipse is a quite complexe platform... but complexity comes with power in
our work so...
thx again.
Eric.
Joel Cheuoua wrote:
> Hello Eric,
> EMF.
> edition :
> all features
> you'll create.
> as simple as this :
> * @author Joël
> adapterFactory) {
> * @see
> * @author Joël
> * @param object
> * @see
> * @author Joël
> * @param object
> * (non-Javadoc)
> * @see
> dialogLabel);
> return null;
> return cellEditor;
> all the changes :
> Joel.
> Eric Giguère wrote:
>> Hi all
>> Eric.
Current Time: Mon Mar 01 09:13:36 GMT 2021
Powered by FUDForum. Page generated in 0.02970 seconds
