Home » Eclipse Projects » DTP » DataTypeMapping synchronization issue
DataTypeMapping synchronization issue [message #39739] Mon, 10 December 2007 19:52 Go to next message
Originally posted by: edeshayes.gmail.com
I have a strange issue with an ODA plugin.
Basically, it looks like a synchronization issue as it works well when I
have only one query at a time.
When my project starts with two queries, I have an exception:
<Dec 10, 2007 01:47:46 PM> <SEVERE> <Joe> Cannot process the
net.appl.jrisk.report.oda.multiplepntmarketdata driver's configurations.
The ODA driver plugin.xml has an invalid odaScalarDataType value (String)
in the <dataTypeMapping> (String).
org.eclipse.birt.data.engine.core.DataException: Cannot process the
org.eclipse.birt.data.engine.odaconsumer.Driver.throwConfigE xception(Driver.java:176)
org.eclipse.birt.data.engine.odaconsumer.Driver.doGetDriverM anifest(Driver.java:165)
org.eclipse.birt.data.engine.odaconsumer.Driver.findDataSour ceExtensionConfig
(Driver.java:123)
org.eclipse.birt.data.engine.odaconsumer.Driver.getDriverExt ensionConfig(Driver.java:78)
org.eclipse.birt.data.engine.odaconsumer.Driver.getExtension Config(Driver.java:60)
at org.eclipse.birt.data.engine.odaconsumer.Driver.getDriverHel per
(Driver.java:93)
org.eclipse.birt.data.engine.odaconsumer.DriverManager.getDr iverHelper(DriverManager.java:87)
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o penConnection(ConnectionManager.java
:132)
org.eclipse.birt.data.engine.executor.DataSource.newConnecti on(DataSource.java:134)
org.eclipse.birt.data.engine.executor.DataSource.open(DataSo urce.java:121)
org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiD ataSource
(DataSourceRuntime.java:214)
org.eclipse.birt.data.engine.impl.QueryExecutor.openDataSour ce(QueryExecutor.java:265)
org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecu tion(QueryExecutor.java:210)
org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQuery.java:500)
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:161)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute
(PreparedOdaDSQuery.java:142)
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:141)
org.eclipse.birt.data.engine.impl.PreparedJointDataSourceQue ry.populatePreparedQuery
(PreparedJointDataSourceQuery.java:512)
org.eclipse.birt.data.engine.impl.PreparedJointDataSourceQue ry.populatePreparedQuery(PreparedJointDataSourceQuery.java:4 72)
org.eclipse.birt.data.engine.impl.PreparedJointDataSourceQue ry.access$2
(PreparedJointDataSourceQuery.java:469)
org.eclipse.birt.data.engine.impl.PreparedJointDataSourceQue ry$JointDataSetQueryExecutor.createOdiQuery(PreparedJointDat aSourceQuery.java:555)
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecu tion
(QueryExecutor.java:217)
:161)
net.appl.jrisk.report.extractor.AbstractBIRTReportExtractor. createReport(AbstractBIRTReportExtractor.java
:112)
net.appl.jrisk.rtblotter.model.dataextractor.AbstractRTBlott erDataExtractor.processBIRTRequest(AbstractRTBlotterDataExtr actor.java:216)
net.appl.jrisk.rtblotter.model.dataextractor.AbstractRTBlott erDataExtractor.processBatch
(AbstractRTBlotterDataExtractor.java:171)
net.appl.jrisk.rtblotter.model.dataextractor.AbstractRTBlott erDataExtractor.fastQASLoad(AbstractRTBlotterDataExtractor.j ava:164)
net.appl.jrisk.rtblotter.model.dataextractor.AbstractRTBlott erDataExtractor.extractReportData
(AbstractRTBlotterDataExtractor.java:296)
net.appl.jrisk.report.extractor.AbstractReportDataExtractor$ DataExtractor.run(AbstractReportDataExtractor.java:156)
Caused by: org.eclipse.datatools.connectivity.oda.OdaException : The ODA
driver plugin.xml has an invalid odaScalarDataType value (String) in the
org.eclipse.datatools.connectivity.oda.util.manifest.DataTyp eMapping.sanityCheckOdaScalarType(
DataTypeMapping.java:100)
org.eclipse.datatools.connectivity.oda.util.manifest.DataTyp eMapping. <init>(DataTypeMapping.java:66)
org.eclipse.datatools.connectivity.oda.util.manifest.DataSet Type.init
(DataSetType.java:71)
org.eclipse.datatools.connectivity.oda.util.manifest.DataSet Type. <init>(DataSetType.java:45)
org.eclipse.datatools.connectivity.oda.util.manifest.Manifes tExplorer.getDataSetElements
(ManifestExplorer.java:520)
org.eclipse.datatools.connectivity.oda.util.manifest.Extensi onManifest.init(ExtensionManifest.java:106)
<init>(ExtensionManifest.java:55)
org.eclipse.datatools.connectivity.oda.util.manifest.Manifes tExplorer.getExtensionManifest(ManifestExplorer.java:239)
(ManifestExplorer.java:205)
org.eclipse.datatools.connectivity.oda.util.manifest.Manifes tExplorer.getExtensionManifest(ManifestExplorer.java:157)
at org.eclipse.birt.data.engine.odaconsumer.Driver.doGetDriverM anifest
(Driver.java:147)
... 29 more
I looked into the code and I suspect that class
org.eclipse.datatools.connectivity.oda.util.manifest.DataTyp eMapping to
be the source of my issue, in the static private method:
* Returns the cached table that maps each ODA data type name
* to its corresponding data type code.
* The data type name serves as the key in the cached table.
private static Hashtable getOdaTypeCodes()
if( sm_odaTypeCodes == null )
sm_odaTypeCodes = new Hashtable( 10 );
sm_odaTypeCodes.put( toOdaTypeKey( "String" ), //$NON-NLS-1$
new Integer( Types.CHAR ));
sm_odaTypeCodes.put( toOdaTypeKey( "Integer" ), //$NON-NLS-1$
new Integer( Types.INTEGER ));
sm_odaTypeCodes.put( toOdaTypeKey( "Double" ), //$NON-NLS-1$
new Integer( Types.DOUBLE ));
sm_odaTypeCodes.put( toOdaTypeKey( "Decimal" ), //$NON-NLS-1$
new Integer( Types.DECIMAL ));
sm_odaTypeCodes.put( toOdaTypeKey( "Date" ), //$NON-NLS-1$
new Integer( Types.DATE ));
sm_odaTypeCodes.put( toOdaTypeKey( "Time" ), //$NON-NLS-1$
new Integer( Types.TIME ));
sm_odaTypeCodes.put( toOdaTypeKey( "Timestamp" ), //$NON-NLS-1$
new Integer( Types.TIMESTAMP ));
sm_odaTypeCodes.put( toOdaTypeKey( "Blob" ), //$NON-NLS-1$
new Integer( Types.BLOB ));
sm_odaTypeCodes.put( toOdaTypeKey( "Clob" ), //$NON-NLS-1$
new Integer( Types.CLOB ));
sm_odaTypeCodes.put( toOdaTypeKey( "Boolean" ), //$NON-NLS-1$
new Integer( Types.BOOLEAN ));
return sm_odaTypeCodes;
I suspect that it may happen that two thread are going to access that
static method at the same time.
The first one is going to instantiate an empty hashmap that the second
will get before the first thread starts popluating it.
The second thread will not see any entry for the String datatype and I
have my exception.
Does that make sense or am I missing something?
Eric
Re: DataTypeMapping synchronization issue [message #39770 is a reply to message #39739] Mon, 10 December 2007 23:56 Go to previous messageGo to next message
Eric,
Which version of DTP and BIRT are you using? There is a known multi-thread
synchronization issue with getting an ODA driver's manifest
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=204972), which is fixed in
DTP 1.6 M4, and latest 1.5.2 nightly build (used by latest BIRT 2.2.2 stable
build).
Linda
Re: DataTypeMapping synchronization issue [message #39830 is a reply to message #39770] Tue, 11 December 2007 14:35 Go to previous message
Hi Lisa,
sorry for not having mentioned that earlier.
I ma using BIRT 2.2.1 that comes with DTP 1.5.1.
The bug you sent me seems to be the one I've noticed!
Thanks for your help!
Eric
Re: DataTypeMapping synchronization issue [message #589292 is a reply to message #39739] Mon, 10 December 2007 23:56 Go to previous message
Eric,
build).
Linda
Re: DataTypeMapping synchronization issue [message #589321 is a reply to message #39770] Tue, 11 December 2007 14:35 Go to previous message
Hi Lisa,
Eric
Previous Topic:Eclipse Data Tools
Next Topic:[Announce] Joint Eclipse/OMG Symposia
Current Time: Mon Nov 03 20:31:05 EST 2025
Powered by FUDForum. Page generated in 0.06796 seconds
