Eclipse does not start ( [message #39562] |
Thu, 24 March 2005 06:08  |
Originally posted by: ljordanov.gmx.li
Hello !
I have unpacked Eclipse and am trying to start it on a WinXP plattform,
but alas to no avail yet...
Tried looking for some help on the internet, but couldn't find anything
yet so if anyone could help me out I'd be really gratefull.
It seemes that some classes cannot be found.
The following error log is generated:
!SESSION 2005-03-24 10:41:14.734
eclipse.buildId=I20050219-1500
java.version=1.5.0_02
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY
initial@reference :file:c:/!yordanov/eclipse/plugins/org.eclipse.core.runtime_ 3.1.0/
0 0 2005-03-24 10:41:14.734
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: BUNDLE_ACTIVATOR_EXCEPTION
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1014)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:327)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:349)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:962)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:588)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:499)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:276)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:459)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:186)
org.eclipse.osgi.framework.eventmgr.EventThread.run(EventThr ead.java:104)
Caused by: java.lang.NoClassDefFoundError:
org.eclipse.osgi.service.environment.EnvironmentInfo
org.eclipse.core.internal.runtime.PlatformActivator.acquireI nfoService(PlatformActivator.java:116)
org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:55)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:995)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:989)
... 10 more
Root exception:
!ENTRY
initial@reference :file:c:/!yordanov/eclipse/plugins/org.eclipse.update.config urator_3.0.0/
0 0 2005-03-24 10:41:14.750
!STACK 0
org.eclipse.osgi.framework.log.FrameworkLog
org.eclipse.update.internal.configurator.ConfigurationActiva tor.acquireFrameworkLogService(ConfigurationActivator.java:4 70)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start(ConfigurationActivator.java:70)
... 10 more
Root exception:
java.lang.NoClassDefFoundError: org.eclipse.osgi.framework.log.FrameworkLog
!ENTRY org.eclipse.osgi 2005-03-24 10:41:14.765
!MESSAGE ECLIPSE_STARTUP_STARTUP_ERROR
!STACK 1
java.lang.IllegalStateException: ECLIPSE_STARTUP_ERROR_BUNDLE_NOT_ACTIVE
org.eclipse.core.runtime.adaptor.EclipseStarter.ensureBundle sActive(EclipseStarter.java:367)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:277)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:148)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
Re: Eclipse does not start ( [message #39657 is a reply to message #39562] |
Thu, 24 March 2005 07:36  |
Originally posted by: hcs33.egon.gyaloglo.hu
This is a known issue afaik. From the Eclipse readme (Known issues section):
Invalid characters in install directory prevents Eclipse from starting
Eclipse will fail to launch if installed in a directory whose path contains
certain invalid characters, including :%#<>"!. The workaround is to install
Eclipse in a directory whose path does not contain invalid characters. (bugs
3109 and 17281)
From the log it seems that you have a ! in the Eclipse path.
HTH,
Csaba
Lyubomir Yordanov wrote:
> Hello !
> !ENTRY
initial@reference:file:c:/!yordanov/eclipse/plugins/org.eclipse.core.runtime
_3.1.0/
> !STACK 0
> at
> at
xtImpl.java:970)
> at
ava:327)
> at
e.java:349)
> at
va:962)
> at
> at
lManager.java:499)
> at
> at
> at
java:186)
> at
> at
> at
java:55)
> at
xtImpl.java:995)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 10 more
> Root exception:
> at
> at
java:55)
> at
xtImpl.java:995)
> at
> at
xtImpl.java:970)
> at
ava:327)
> at
e.java:349)
> at
va:962)
> at
> at
lManager.java:499)
> at
> at
> at
java:186)
> at
> !ENTRY
initial@reference:file:c:/!yordanov/eclipse/plugins/org.eclipse.update.confi
gurator_3.0.0/
> !STACK 0
> at
> at
xtImpl.java:970)
> at
ava:327)
> at
e.java:349)
> at
va:962)
> at
> at
lManager.java:499)
> at
> at
> at
java:186)
> at
> at
workLogService(ConfigurationActivator.java:470)
> at
> at
xtImpl.java:995)
> at
> ... 10 more
> Root exception:
> org.eclipse.osgi.framework.log.FrameworkLog at
> at
> at
xtImpl.java:995)
> at
> at
xtImpl.java:970)
> at
ava:327)
> at
e.java:349)
> at
va:962)
> at
> at
lManager.java:499)
> at
> at
> at
java:186)
> at
> !STACK 1
> at
tarter.java:367)
> at
277)
> at
FUDForum. Page generated in 0.10342 seconds
