Home » Archived » Maven Integration (M2E) » contributing to m2eclipse
contributing to m2eclipse [message #3416] Tue, 22 April 2008 20:34 Go to next message
I put some basic documentation on how to setup Eclipse workspace for
working with m2eclipse code.
http://docs.codehaus.org/display/M2ECLIPSE/Configuring+Devel opment+Environment
It may see bit lengthy, but things actually quite simple. You can
import the following Eclipse Team Project Sets (PSF) using "File /
Import... / Team / Team Project Set" wizard and it would bring all
required projects into your Eclipse workspace (this PSF is based on
Subclipse).
https://svn.sonatype.org/m2eclipse/trunk/org.maven.ide.eclip se.parent/m2eclipse-all.psf
Once you get all projects, you should be able to run m2eclipse in
self-hosted mode. Open org.maven.ide.eclipse/plugin.xml with PDE's
Plug-in manifest editor and then click "Launch an Eclipse application"
link on the Overview page. You can also use main menu "Run / Run
configurations..." to create new launch configuration using "Eclipse
Application" cofiguration type. There you can also select JRE used to
run Eclipse and what plugins should be included at runtime (use "all
workspace and enabled target plug-ins, or select them individually and
use "Validate Plug-ins" action to verify if selected configuration is
correct).
Here are few last tips for contributing patches.
http://docs.codehaus.org/display/M2ECLIPSE/Contributing+Patc hes
Happy coding
Eugene
Re: contributing to m2eclipse [message #3553 is a reply to message #3416] Sun, 27 April 2008 02:31 Go to previous messageGo to next message
Eugene, is there any additional steps to configure the local repository
or something else?
After importing the source into a blank workspace, I get a couple of
errors like:
Project 'org.maven.ide.components.pom' is missing required library:
'target/generated-classes/xmlbeans'
Project 'org.maven.ide.components.pom' is missing required source
folder: 'target/generated-sources/xmlbeans'
Project build error:Cannot find artifact for parent POM:
org.maven.ide.eclipse:parent::0.9.2-SNAPSHOT for project
org.maven.ide.components:org.maven.ide.components.pom:jar:${ maven_pom.version}
C:\Users\wmitsuda\Desktop\eclipse-m2eclipse-test\workspace\o rg.maven.ide.components.pom\pom.xml
Project build error:Cannot resolve pre-scanned plugin artifact (for use
as an extension): org.codehaus.tycho:maven-osgi-lifecycle-plugin: Failed
to resolve extension plugin:
org.codehaus.tycho:maven-osgi-lifecycle-plugin:maven-plugin: 1.0-SNAPSHOT
Re: contributing to m2eclipse [message #3586 is a reply to message #3553] Sun, 27 April 2008 14:58 Go to previous messageGo to next message
Originally posted by: igorfie.yahoo.com
Willian,
The easiest short-term solution is to remove project
'org.maven.ide.components.pom' from workspace. This project is only
needed during headless build, but is not required when running m2eclipse
from development workspace. Long term, we're looking at proper
integration between PDE and maven/m2eclipse.
> or something else?
> errors like:
> at
Re: contributing to m2eclipse (build) [message #3715 is a reply to message #3553] Wed, 30 April 2008 14:54 Go to previous message
Willian,
As Igor already mentioned, this project is not required to run
m2eclipse in self-hosted mode from PDE.
However we made several fixes in our build configuration, as well as
Maven repository we use for all external dependencies. So, you should be
able to build all projects from the command line. See instructions for
configuring development environment on the wiki [1].
regards,
Eugene
[1]
> repository or something else?
> errors like:
> at
> use as an extension): org.codehaus.tycho:maven-osgi-lifecycle-plugin:
> Failed to resolve extension plugin:
Previous Topic:Imported plugin code into eclipse. Compile problem.
Next Topic:feedback for the Maven POM editor
Current Time: Tue Nov 11 15:02:19 EST 2025
Powered by FUDForum. Page generated in 0.10230 seconds
