Home » Language IDEs » AspectJ » Is tehre a way to switch AspectJ?
Is tehre a way to switch AspectJ? [message #39496] Mon, 26 July 2004 15:37 Go to next message
I have the latest version of AJDT and find it really nice, except for a few
glitches.
I rely heavily on content assist and AJDT always complains that no
completion is available?
so suppose I hava List l, when I type l. and <CTRL>+<SPACE> I would expect
the list to drop
down, I get no completion availble. So how do I make AspectJ editor to
bypass its own logic a
nd give Java editor a chance?
Alex.
Re: Is tehre a way to switch AspectJ? [message #39527 is a reply to message #39496] Mon, 26 July 2004 18:22 Go to previous message
Originally posted by: mchapman.uk.ibm.com
> glitches.
Thanks, please raise bugs so we can make it even better :)
> the list to drop
The current limitation is that this doesn't work if your aspect is in a
..aj file, but completion of Java types does work with aspects in .java
files. You can rename .aj files to .java if you like, and configure the
New Aspect wizard to create .java files (under project properties >
AspectJ). We're hoping to fix this limitation for the next release.
Matt.
Re: Is tehre a way to switch AspectJ? [message #582350 is a reply to message #39496] Mon, 26 July 2004 18:22 Go to previous message
> glitches.
> the list to drop
Matt.
Previous Topic:Is tehre a way to switch AspectJ?
Next Topic:Compile failed
Current Time: Wed Jul 30 18:13:45 EDT 2025
Powered by FUDForum. Page generated in 0.03504 seconds
