Home » Archived » Visual Editor (VE) » VE 1.0 M1 on Mac OS X
VE 1.0 M1 on Mac OS X [message #39462] Thu, 27 May 2004 15:43 Go to next message
Hi there,
today I tried to get the Eclipse VE running on OS X. I tried all the
official combinations listed on the VE
download page (that is 1.0M1 and 0.5) with all the right combination of
the libraries.
I also did this install for at least 3 times on Windows with no problem so
I don't think I missed
something.
My problem is that the visual editor is able to start (somehow) but it
cannot draw the interface in the
upper pane of the editor and the adjustement controlls for the split-pane
don't work. Also Eclipse
hangs and eventually (after about 5 minutes) crashes if I try to access
the prefs page of the Visual-
Editor. (This behaviour is the same with both VE versions that I tried)
Is this an expected behaviour? I couldn't find anything in the FAQ, Google
or the archive of this group
so I figured I should ask...
Does anybody use the VE successfully on OS X? If so, which versions do you
use or what did you do to
get this running?
Thanks a lot,
cu Martin
Re: VE 1.0 M1 on Mac OS X [message #39493 is a reply to message #39462] Thu, 27 May 2004 15:11 Go to previous messageGo to next message
Hi Martin,
Unfortunately, the Visual Editor isn't supported on Mac OS X yet. This
is stated in the project's FAQ:
http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /vep-home/WebContent/faq.html#general_os
You can add yourself to the CC list on bug 47716 to watch for updates on
this effort:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=47716
Sorry,
- Jeff
Martin Häcker wrote:
> Hi there,
> the libraries.
Re: VE 1.0 M1 on Mac OS X [message #39552 is a reply to message #39493] Sat, 29 May 2004 14:17 Go to previous message
Hi Jeff,
faq.html#general_os
Sad to hear this.
> this effort:
[x] Done
> Sorry,
Thanks for the heads-up! I'l be watching closely. :)
cu Martin
Re: VE 1.0 M1 on Mac OS X [message #591028 is a reply to message #39462] Thu, 27 May 2004 15:11 Go to previous message
Hi Martin,
this effort:
Sorry,
- Jeff
> Hi there,
> the libraries.
Re: VE 1.0 M1 on Mac OS X [message #591057 is a reply to message #39493] Sat, 29 May 2004 14:17 Go to previous message
Hi Jeff,
faq.html#general_os
Sad to hear this.
> this effort:
[x] Done
> Sorry,
cu Martin
Previous Topic:Wiki updates
Next Topic:Eclipse3 M9 and VE
Current Time: Tue Nov 25 21:28:59 EST 2025
Powered by FUDForum. Page generated in 0.05410 seconds
