Home » Archived » M2M (model-to-model transformation) » References in iterative target model elements
References in iterative target model elements [message #39357] Sun, 20 May 2007 08:42 Go to next message
Originally posted by: priit.best.ee
Hi!
My model transformation uses iterative target pattern elements. The problem is, I am not
able to also create referenced elements iteratively and keep the references intact.
To illustrate this, I extended the example mentioned in section 4.5.2.4 of the ATL User
Manual.
I have a model of Journals, that contain 0..* Articles. I want to transform this model
into Books, that contain 0..* Chapters. In the target model I want to have 2 Books for
every Journal, that both contain the respective Chapters.
My ATL transformation looks like this:
module TestIterativeTarget; -- Module Template
create OUT : Book from IN : Journal;
rule Journal2Book {
from
j: Journal!Journal
using {
editions:Sequence(String) = Sequence {'library', 'bookshop'};
to
b: distinct Book!Book foreach (e in editions) (
title <- j.title,
edition <- e,
chapter <- j.article
rule Article2Chapter {
from
a: Journal!Article
to
c: Book!Chapter (
name <- a.name
Here is my test model:
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns="Journal">
<Journal title="Journal 1">
<article name="a_2_1"/>
<article name="a_2_2"/>
<article name="a_2_3"/>
</Journal>
</xmi:XMI>
I'd like to transform it into something like this:
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns="Book">
<Book title="Journal 1" edition="library">
<chapter name="a_2_1"/>
<chapter name="a_2_2"/>
<chapter name="a_2_3"/>
</Book>
<Book title="Journal 1" edition="bookshop">
</Book>
</xmi:XMI>
But instead, I only get this:
</Book>
</Book>
<Chapter name="a_2_3"/>
</xmi:XMI>
I have tried creating the Chapters also in the iterative way, but so far have
not yet reached the goal.
Do you have any ideas what I should change?
Thanks in advance for your help,
Priit
[ATL] Re: References in iterative target model elements [message #39390 is a reply to message #39357] Sun, 20 May 2007 15:34 Go to previous messageGo to next message
Priit,
Could you prefix yor subject by the [ATL] prefix?
thanks,
Jean
"Priit" <priit@best.ee> a
Re: References in iterative target model elements [message #39422 is a reply to message #39357] Mon, 21 May 2007 04:16 Go to previous messageGo to next message
Originally posted by: rchevrel.sodius.com
--------------050806080506070303000003
Hi Priit,
Your problem is completly normal with ATL: an element is matched only
one time, so you obtain only tree chapters after transformation because
you have only tree Article in input. The containment are unpredictable
in relation with the execution order (which cannot be considered in
declarative form).
You need to use called rules or lazy rules to do what you want here
(here, I use called rules with an iterate, but someone have perhaps an
idea in order to stay in declarative form :) ):
rule Journal2Book {
from
j: Journal!Journal
using {
to
title <- j.title,
edition <- e,
chapter <- thisModule.Article2ChapterIterator(j.article);
helper def: Article2ChapterIterator(articles :
Sequence(Journal!Article)) : Sequence(Book!Chapter) =
articles->iterate(anArticle ; chapters : Sequence(Book!Chapter) =
Sequence{} |
chapters->includes(thisModule.Article2Chapter(anArticle))
rule Article2Chapter(article : Journal!Article) {
to
c: Book!Chapter (
name <- article.name
do {
c;
I have not tested the code but I think it will work :)
*R
[ATL] Re: References in iterative target model elements [message #39454 is a reply to message #39422] Mon, 21 May 2007 04:38 Go to previous messageGo to next message
--------------030102010504020301050803
I have forgot to re-prefix with ATL
Sorry Jean :)
*R
[ATL] Re: References in iterative target model elements [message #39765 is a reply to message #39422] Mon, 21 May 2007 14:33 Go to previous messageGo to next message
Hi Régis,
I'm sorry to say, but it still doesn't work as expected. The number of Chapters created was
correct, but only the first chapter was linked to the Book:
<chapter name="a_1_1"/>
</Book>
<chapter name="a_1_2"/>
</Book>
<Chapter name="a_1_2"/>
<Chapter name="a_1_3"/>
<Chapter name="a_1_1"/>
</xmi:XMI>
What am I still doing wrong?
If you are interested, you can see all the relevant files here: http://priit.eu/ATL/
PS. I changed includes() for including() in the helper function, I guess it was a typo...
Priit
Régis wrote:
> Hi Priit,
> declarative form).
> rule Journal2Book {
> from
> j: Journal!Journal
> using {
> to
> title <- j.title,
> edition <- e,
> Sequence{} |
> to
> c: Book!Chapter (
> do {
> c;
> *Régis CHEVREL* <mailto:rchevrel@sodius.com>
> SODIUS*
> *6, rue Cornouaille
> 44319 Nantes - France
> Phone: +33 (0)2 28 23 54 34
> ***www.mdworkbench.com* <http://www.mdworkbench.com/>* *
> Draw more value from your model
Re: [ATL] Re: References in iterative target model elements [message #39796 is a reply to message #39765] Mon, 21 May 2007 15:38 Go to previous message
> rule Journal2Book {
> from
> j: Journal!Journal
> using {
> to
> title <- j.title,
> edition <- e,
Because of the way iterative target pattern elements (i.e.,
"distinct"-"foreach") work, you have to write something like:
chapter <- editions->collect(e | j.article)
This is because when the value of the right-hand part is a collection,
each of its element is assigned to a separate target element. Therefore,
by building a collection of collection, we solve the problem.
This is also probably the reason why Régis' solution did not work as
expected.
Note that the outer collection should contain the same number of
elements as in the iterated collection (i.e., "editions" here).
The behavior of the iterative target pattern element is definitely not
very intuitive, which is why it has been deprecated in favor of lazy rules.
The most elegant declarative solution I can think of would require the
editions to come from a model (i.e., the IN source model, or another
model). Note that this somehow makes sense: you may want to extend your
transformation to support more kinds of editions later, and it is
simpler to change a source model than a hard-coded value in the
transformation.
Here is what it could look like:
-- @atlcompiler atl2006
create OUT : Book from IN : Journal, editions : Edition;
rule Journal2Book {
from
j : Journal!Journal,
e : Edition!Edition
to
b : Book!Book (
title <- j.title,
edition <- e.name,
chapter <- j.article->collect(e |
thisModule.Article2Chapter(e)
lazy rule Article2Chapter {
from
a: Journal!Article
to
c: Book!Chapter (
name <- a.name
Frédéric Jouault
Priit wrote:
> Hi Régis,
> </Book>
> </Book>
> </xmi:XMI>
> it was a typo...
> Priit
> Régis wrote:
>> Hi Priit,
>> because you have only tree Article in input. The containment are
>> unpredictable in relation with the execution order (which cannot be
>> considered in declarative form).
>> rule Journal2Book {
>> from
>> j: Journal!Journal
>> using {
>> to
>> title <- j.title,
>> edition <- e,
>> Sequence{} |
>> to
>> c: Book!Chapter (
>> do {
>> c;
>> Regards,
>> SODIUS*
>> *6, rue Cornouaille
Previous Topic:getting EMF model handler
Next Topic:[ATL] Modeling with KM3: How to model an enumeration that uses numeric values.
Current Time: Thu Jul 31 12:54:06 EDT 2025
Powered by FUDForum. Page generated in 0.08390 seconds
