Home » Archived » M2M (model-to-model transformation) » [ATL] Table2SVGPieChart - Extract to XML?
[ATL] Table2SVGPieChart - Extract to XML? [message #39326] Sat, 19 May 2007 07:36 Go to next message
Originally posted by: rb_account.yahoo.de
I tried the Table2SVGPieChart-Example.
However, I can't extract the output-model to an xml-File. The context-menu
only offers the following options:
- Extract KM3 metamodel to KM3 file
- Extract ecore metamodel to KM3
I use the zipped-bundle from
http://www.sciences.univ-nantes.fr/lina/atl/www/atldemo/ATLB undle_20070217.zip.
Do I need a newer version?
Rainer Bernhard
Re: [ATL] Table2SVGPieChart - Extract to XML? [message #39485 is a reply to message #39326] Mon, 21 May 2007 04:51 Go to previous message
Originally posted by: freddy.allilaire.univ-nantes.fr
Hi Rainer,
To extract your output model to an xml file, you should open the view
"AM3 Resource Navigator".
An other solution will be to use an ant script with the following code:
<am3.saveModel model="myXML" path="outputs/SavingMySample.xml">
<extractor name="xml"/>
</am3.saveModel>
Freddy.
Rainer Bernhard a écrit :
> Hello,
> context-menu only offers the following options:
> Best regards,
> Rainer Bernhard
Freddy Allilaire - ATLAS Group (INRIA & LINA)
http://www.sciences.univ-nantes.fr/lina/atl/contrib/allilair e
Previous Topic:[ATL] Conditional target element creation
Next Topic:[ATL] : problem with Sequence in Sequence
Current Time: Fri Jul 18 06:02:57 EDT 2025
Powered by FUDForum. Page generated in 0.07136 seconds
