| XSDSchema document question [message #39290] |
Tue, 23 March 2004 08:25  |
What is the optional Document property on an XSDSchema element intended to
be used for? I have some optional name value pair user defined properties
I'm looking for a home for and this seems like a logical place.
thanks,
Lance Phillips
| Re: XSDSchema document question [message #39414 is a reply to message #39383] |
Tue, 23 March 2004 09:51  |
Wow... what a brain cramp... sorry Ed! Please don't think I'm stupid ;)
lp
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:40604D1F.9CD0D61F@ca.ibm.com...
> Lance,
> Add to XSDSchema.getContents().
> Lance Phillips wrote:
> > Ed,
> > How do I add an annotation directly to the Schema? I only see
> > mechanisms for adding annotations directly to schema components. The
> > getAnnotations method on Schema is an infoset property, so adding to it
has
> > no effect.
> > thansk,
> > Lance
> > news:40604598.B1362C30@ca.ibm.com...
> > > Lance,
> > > This is the DOM Document of the schema. You can't reuse this. You
should
> > use
> > > annotations for additional data.
intended
> > to
> > properties
> > > > thanks,
> > > > Lance Phillips
| Re: XSDSchema document question [message #584426 is a reply to message #39290] |
Tue, 23 March 2004 09:11  |
Lance,
This is the DOM Document of the schema. You can't reuse this. You should use
> thanks,
> Lance Phillips
| Re: XSDSchema document question [message #584445 is a reply to message #39321] |
Tue, 23 March 2004 09:41  |
Ed,
getAnnotations method on Schema is an infoset property, so adding to it has
no effect.
thansk,
Lance
> Lance,
use
to
properties
> > thanks,
> > Lance Phillips
| Re: XSDSchema document question [message #584460 is a reply to message #39352] |
Tue, 23 March 2004 09:43  |
Lance,
> Ed,
> no effect.
> thansk,
> Lance
> > Lance,
> use
> to
> properties
> > > thanks,
> > > Lance Phillips
| Re: XSDSchema document question [message #584472 is a reply to message #39383] |
lp
> Lance,
> > Ed,
has
> > no effect.
> > thansk,
> > Lance
> > > Lance,
should
> > use
intended
> > to
> > properties
> > > > thanks,
> > > > Lance Phillips
FUDForum. Page generated in 0.24935 seconds
