Home » Modeling » M2T (model-to-text transformation) » Re: JUnit Test on JET Transform
Re: JUnit Test on JET Transform [message #39196] Thu, 10 January 2008 19:21 Go to next message
Roshan,
Please use the M2T newsgroup for JET2 questions. I've added it to the
"to" list of the reply so there's no need to repost.
Roshan Soni wrote:
> I want to run a JUnit test on a JET2 template by running the
> transform, but whenever I try to run the transform inside of my test i.e.
> -JET2Platform.runTransformOnObject(...)
> -Compare results with expected output
> -assertTrue
> The problem is that the transformation is not being run. I tried to
> run it within a Job, but I still had no luck. Any ideas would be
> greatly appreciated:
> Job job = new Job("SD .NET Generation") {
> protected IStatus run(final IProgressMonitor monitor) {
> Map variablesMap = initializeInputs();
> JET2Platform.runTransformOnObject("project.transform", null,
> variablesMap, monitor);
> return Status.OK_STATUS;
Re: JUnit Test on JET Transform [message #39814 is a reply to message #39196] Tue, 15 January 2008 09:42 Go to previous messageGo to next message
Roshan:
JET runs some JET transformations as part of its JUnit suite. Take a look
at.
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2t/org .eclipse.jet/tests/org.eclipse.jet.tests/src/org/eclipse/jet /tests/parser/resources/ResourceTemplateInputTest.java?revis ion=1.1&root=Modeling_Project&view=markup
.... and then ask more questions ;-)
Paul
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fm6ctg$hl8$2@build.eclipse.org...
> Roshan,
> Roshan Soni wrote:
>> I want to run a JUnit test on a JET2 template by running the transform,
>> -assertTrue
>> The problem is that the transformation is not being run. I tried to run
>> it within a Job, but I still had no luck. Any ideas would be greatly
>> appreciated:
Re: JUnit Test on JET Transform [message #40300 is a reply to message #39814] Thu, 17 January 2008 18:06 Go to previous messageGo to next message
Thanks Paul,
This is the type of test I want to run, but cannot get it to work. I have
a test class that runs this code as the test (I'll make it more robust
once I can get the transformation working in the test). When I run this
test I get the exception below. If I run my transform normally through my
launch file I do not receive any errors and I have output generated.
public void testTransform() throws Exception
IStatus status = JET2Platform.runTransformOnObject("com.tools.transform",
null, variablesMap, new NullProgressMonitor());
assertTrue("setUpAllTests", status.isOK());
try {
ResourcesPlugin.getWorkspace().run(new IWorkspaceRunnable() {
public void run(IProgressMonitor monitor) throws CoreException {
// TODO Auto-generated method stub
}}, new NullProgressMonitor());
} catch (CoreException e) {
fail(e.getMessage());
java.lang.ExceptionInInitializerError
at com.tools.test.AttachEventTest.testTransform(AttachEventTest .java:26)
at junit.framework.TestCase.runTest(TestCase.java:164)
at junit.framework.TestCase.runBare(TestCase.java:130)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:120)
at junit.framework.TestSuite.runTest(TestSuite.java:230)
at junit.framework.TestSuite.run(TestSuite.java:225)
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:130)
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
Caused by: java.lang.NullPointerException
at org.eclipse.jet.JET2Platform.<clinit>(JET2Platform.java:76)
... 19 more
Re: JUnit Test on JET Transform [message #40485 is a reply to message #40300] Mon, 21 January 2008 11:12 Go to previous messageGo to next message
Roshan:
A quick look at the NPE suggests it happens if the JET plug-in has not been
started by Eclipse. How are you launching your JUnits?
You should be using an Eclipse launch configuration of type "JUnit Plug-in
Test".
Paul
"Roshan Soni" <roshan.soni1@gmail.com> wrote in message
news:7a10174e4db0877148ecce9616b7be55$1@www.eclipse.org...
> Thanks Paul,
> public void testTransform() throws Exception {
> try {
> at
> at
> at
> at
> at
> at
> ... 19 more
Re: JUnit Test on JET Transform [message #40761 is a reply to message #40485] Tue, 22 January 2008 14:28 Go to previous messageGo to next message
You're right it was a problem with my launch configuration and when I
properly setup my launch to run the correct plugin. I was orignally
running the same transform as my project and so my unit tests were not
running, but changing it to run the org.eclipse.sdk.ide product runs my
transformation and test.
Now I have a different question. On the basis of unit testing I want to
test my xpath. what would you say is a good test for the xpath in the
template snippet below? I was want to use XMLUnit to test because all of
my output is xml.
<c:when test="string($someControl/@attribute1) != 'true'">
<c:setVariable select="$composite_widget/@attribute1" var="myParent" />
</c:when>
Roshan
Re: JUnit Test on JET Transform [message #41011 is a reply to message #40761] Thu, 24 January 2008 11:30 Go to previous message
Roshan:
I'm not an XMLUnit expert, but here's a suggestion on JUnit testing JET
transformation results...
1) Run the JET transformation using a TestSetup extension. See:
http://junit.sourceforge.net/javadoc/junit/extensions/TestSe tup.html
JET uses this technique in some if its JUnits:
2) With a TestSetup, individual tests in the JUnit class can than verify
individual file contents. If you have XML content to verify, the XMLUnit
would be a handy tool.
3) For Unit testing your XPath expressions, one possibility is to create a
template (and a ws:file action) that writes calculated values, and then
write a JUnit test to verify these values. If you don't want this template
run in normal circumstances, you could run it only if a particular XPath
variable is defined, and define that variable when you run the JUnit test.
Paul
news:288c21f6c2cc29d097162f4a2fafe771$1@www.eclipse.org...
> my output is xml.
> </c:when>
> Roshan
Previous Topic:Run generate method for a single JET2 template
Next Topic:minimal jet plugin
Current Time: Wed Nov 05 06:49:02 EST 2025
Powered by FUDForum. Page generated in 0.04738 seconds
