Home » Eclipse Projects » Equinox » Removing the Basic perspective in RCP
Removing the Basic perspective in RCP [message #38660] Fri, 26 March 2004 13:46 Go to next message
I have a an RCP application that uses the same set of Eclipse plugins used
in the RCP example #3, plus all of the update plugins. When I run this
application, the Basic perspective is added to the shortcut bar. I'd like
to avoid this, as it has nothing to do with my application. Is there a
way to hide this?
Stephen
Re: Removing the Basic perspective in RCP [message #38752 is a reply to message #38660] Fri, 26 March 2004 20:28 Go to previous message
Originally posted by: pascal.ibm.canada
We are not UI litterate around here ;-)
You'd better ask that on the platform newsgroup.
PaScaL
> way to hide this?
> Stephen
Previous Topic:RCP Application Management
Next Topic:How to dynamically installation/loading of plugins from directories in the file system?
Current Time: Sat Nov 08 05:22:16 EST 2025
Powered by FUDForum. Page generated in 0.04005 seconds
