Home » Eclipse Projects » DTP » sql query parser plugin is not activated
sql query parser plugin is not activated [message #38550] Thu, 08 November 2007 17:02 Go to next message
Originally posted by: dmeng.rim.com
Does anybody know why in DTP1.5.1, the checkbox "Activate this plug-in
when one of its classes is loaded" on overview tab of plugin property view
is not checked for org.eclipse.datatools.sqltools.parsers.sql.query
plugin. Is it a mistake or on purpose?
David
Re: sql query parser plugin is not activated [message #39369 is a reply to message #38550] Wed, 28 November 2007 20:49 Go to previous message
David,
There is a typo in the MANIFEST.MF file for that plugin. It says
"Eclipse-LaztStart: true" instead of "Eclipse-LazyStart: true". I'll
fix it. Thanks for reporting the problem.
Brian
> view is not checked for
> org.eclipse.datatools.sqltools.parsers.sql.query plugin. Is it a
> David
Re: sql query parser plugin is not activated [message #588814 is a reply to message #38550] Wed, 28 November 2007 20:49 Go to previous message
David,
Brian
> David
Previous Topic:Edit or add column to mysql database?
Next Topic:Eclipse Data Tools
Current Time: Sat Jul 26 07:42:49 EDT 2025
Powered by FUDForum. Page generated in 0.03473 seconds
