AutoGUI and deployments [message #38448] |
Tue, 01 November 2005 11:52  |
Hi Ali:
first let me say your AutoGUI documentation is truly excellent, and the tool
itself is looking really useful.
I do have a question about deployments: it appears that the hyades
deployment artifacts (e.g. the workspace location) are not currently being
used during a standard launch: I've debugged the code down to the point
where the remote process VM args are being specified:
AutoGUIExecObjAdapter.setupExecutableObject(IExecutableObjec t, CFGClass,
IImplementor, TPFDeployment) line: 61
but the "-data" flag seems to be hard-coded to a temporary location at
"TPTP-Auto-Workspace-" + System.currentTimeMillis();
Am I missing something? I'd like to fix this problem if you could point me
in the right places. I'm building from the CVS head
/cvsroot/tptp/test/org.eclipse.tptp.test.auto.gui, and have the 2005-10-18
build of eclipse/hyades installed.
Simon.
P. Simon Tuffs, D.Phil
simon@simontuffs.com
http://www.simontuffs.com
Re: AutoGUI and deployments [message #38514 is a reply to message #38448] |
Tue, 01 November 2005 13:01  |
Hi Simon,
Thanks for the complements.
You're right about users not being able to specify a workspace location
resource with a customly defined deployment file. This is something that
couldn't be contained in 4.1 and will be addressed in 4.2
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=109880). To address this
issue, you can write your own object adapter and have it registered in the
plugin.xml. You'll need to change the class attribute of the following
fragment:
<!-- Executable Object Adapter for TPTP Automated GUI Test Suite -->
<ExecutableObjectAdapter
name="AUTOMATEDGUI_EXECUTABLE_OBJECT_ADAPTER"
class=" org.eclipse.tptp.test.auto.gui.internal.runner.AutoGUIExecOb jAdapter "
id=" org.eclipse.tptp.test.auto.gui.internal.runner.AutoGUIExecOb jAdapter ">
<SupportedTestType
name="org.eclipse.hyades.test.auto.gui.testSuite">
</SupportedTestType>
</ExecutableObjectAdapter>
The purpose of the object adapter is to sepcify the VM arguments. You can
look up to see if a deployment file is specified and whether a workspace
location resource is associated with the file. We'll appreciate it if you
contribute your code to the Eclipse community by attaching it to the feature
report.
Good luck,
Ali M.
"Simon Tuffs" <simon@simontuffs.com> wrote in message
news:dk86g7$1es$1@news.eclipse.org...
> Hi Ali:
tool
me
> Simon.
FUDForum. Page generated in 0.03683 seconds
