Home » Language IDEs » Java Development Tools (JDT) » Avoiding Eclipse top-bit-set "mangling"
Avoiding Eclipse top-bit-set "mangling" [message #38342] Sun, 25 May 2003 08:50 Go to next message
The Eclipse (2.1) editor apparently "mangles" several top-bit-set
characters - if you attempt to load a text file containing them and
then save it again.
My question is if there is any chance that there's a way around
this using a plug-in editing component - instead of the default
text editor - or perhaps by marking text files as binary -
or something.
__________
|im |yler http://timtyler.org/ tim@tt1.org
Re: Avoiding Eclipse top-bit-set "mangling" [message #38474 is a reply to message #38342] Sun, 25 May 2003 11:33 Go to previous messageGo to next message
> then save it again.
> or something.
What character set do you have as your default encoding? I would have
thought if you used ISO-8859-1 as the encoding, all should be well.
Jon Skeet - <skeet@pobox.com>
http://www.pobox.com/~skeet/
If replying to the group, please do not mail me too
Re: Avoiding Eclipse top-bit-set "mangling" [message #39440 is a reply to message #38474] Mon, 26 May 2003 09:28 Go to previous messageGo to next message
"Jon Skeet" <skeet@pobox.com> wrote in message
news:MPG.193af2a4daa65b3b9897ec@news.eclipse.org...
> > then save it again.
> > or something.
I don't know how to find out what character set Eclipse is using -
or how to change it.
The hypothesis that encoding is involved seems fair - one of the
mangled characters is 0x8F - slap in the middle of the
"ASCII international danger zone".
The mangled characters are apparently all displayed by Eclipse as
rather large, empty grey rectangles - before it mangles them.
FWIW, I'm running on an international Sun 1.4.2 beta JDK.
__________
Re: Avoiding Eclipse top-bit-set "mangling" [message #41654 is a reply to message #39440] Wed, 28 May 2003 04:53 Go to previous messageGo to next message
Under Preferences, Workbench | Editors
Right. My guess is that it's using Cp-1252 at the moment then.
Re: Avoiding Eclipse top-bit-set "mangling" [message #42327 is a reply to message #39440] Tue, 27 May 2003 22:48 Go to previous messageGo to next message
Originally posted by: KingD.tmicha.net
"Tim Tyler" <tim@tt1.org> wrote in message
news:bat4o4$3es$1@rogue.oti.com...
> > > then save it again.
> > > or something.
Preferences > Workbench > Editors
It is not a danger zone, but the zone where Microsoft decided to "innovate"
and diverge from standard ISO8859-1.
What exactly did you expect it to display for an 0x8F? If your encoding is
set to Cp1252 what you describe is eactly what I would expect to happen as
0x8F (along with 0x81, 0x8D, 0x90, and 0x9D) are undefined in Cp1252 and
therefore have no meaning. When reading in it is most likely converted to
the \uFFFD replacement character which is then converted to a ? upon
writing.
While the ISO8859-1 encoding probably will not change the value, I'm not
sure what you expect it to display there as it is a non-printable control
character.
Dale King
Re: Avoiding Eclipse top-bit-set "mangling" [message #42726 is a reply to message #42327] Thu, 29 May 2003 03:35 Go to previous message
"Dale King" <KingD@tmicha.net> wrote in message
news:bb2vkg$i18$1@rogue.oti.com...
> > > > then save it again.
> > > > or something.
Got it - the problem is now solved - thanks.
> What exactly did you expect it to display for an 0x8F? [...]
I don't care what it displays - but I do care about the mangling.
The files I'm dealing with have a compressed section preceded by
a header - which is textual and (normally) editable.
__________
Previous Topic:Error state remains after a problem is fixed
Next Topic:How to import an exported project from a .zip file?
Current Time: Tue Nov 18 09:17:23 EST 2025
Powered by FUDForum. Page generated in 0.27461 seconds
