Home » Modeling » M2T (model-to-text transformation) » PDF output (JET vs XSLT)
PDF output (JET vs XSLT) [message #38227] Thu, 27 December 2007 16:52 Go to next message
I need to make a choice of JET vs XSLT, or some other M2T technology, for
creating PDF and XHTML output from an EMF model. There are advantages to
using the FO capabilities of XSLT for producing PDF output. But advantages
of JET for traversing EMF model structures. Has anyone used JET for PDF
output? More specifically, I am looking into creating Structured English
output from SBVR vocabularies and business rules.
The current release of IBM's RSx modeling tools use XSLT for creating HTML
and PDF reports, but I've found those stylesheets to be a pain to customize.
Thanks for any input,
Dave Carlson
Re: PDF output (JET vs XSLT) [message #38260 is a reply to message #38227] Fri, 28 December 2007 10:10 Go to previous message
Dave:
On JET vs XSLT:
* XSLT produces one file per invocation. JET can produce multiple files per
invocation. An XSLT stylesheet it the equivalent of a single JET template.
If you are producing more than one file from a given model, JET templates
(or any other templating language, for that matter) can be less complex.
* JET 'transformations' let you calculate values (and store them as
'temporary' attributes on the input model). This can greatly simplify
individual JET templates, which can concentrate on value substitution and
flow control. In XSLT, all calculations are directly in the stylesheet,
which can make it very hard to 'see' the structure of the generated content.
* Finally, I have trouble relating to the structure of an XLST sytlesheet.
For my taste, it is too oriented to the structure of the input at the
expense of the understanding of the output. IHMO, a good template shows the
structure of the output, with a "little bit" of markup to represent
substitutions from the model.
On generating PDF:
* I don't know of anyone generating PDF from JET. JET is primarily a tool
for generating text (which PDF is not).
* A workable solution would be to write JET templates that generate text
(HTML, RTF, postscript, ..., whatever), and then generate PDF from that
either as a separate transformation, or via a custom JET tag.
On using JET with "Structured English" and SBVR:
* I'm not familiar with this. Out of the box, JET can read/travers XML
documents, and anything that has a registered EMF resource factory. A quick
look at the SBVR spec indicates that MOF/XMI export is possible - at a
minimum, this should be usable by JET. Also, depending on how the structured
english is persisted (its unclear to me after 10 minutes with the spec), JET
may be able to read that directly.
Feel free to ask more questions.
Paul
"Dave Carlson" <dcarlson@xmlmodeling.com> wrote in message
news:fl16qe$ap1$1@build.eclipse.org...
> advantages of JET for traversing EMF model structures. Has anyone used
> JET for PDF output? More specifically, I am looking into creating
> Structured English output from SBVR vocabularies and business rules.
> customize.
> Dave Carlson
Previous Topic:is it possible to execute a transformation without jet in your TARGET eclipse platform ?
Next Topic:more jet samples
Current Time: Tue Nov 11 05:50:51 EST 2025
Powered by FUDForum. Page generated in 0.03563 seconds
