ObjectCollectedException [message #38159] |
Fri, 13 December 2002 13:19  |
Originally posted by: robin.rosenberg.dewire.kom.s/k/c/
I get ObjectCollectedException from time to time (M3, Mandrake 9). These seem to occur in
every edition, but M3 is (seems) worse. Along with these exceptions the debugger
in eclipse hangs. Screen refresh works, but I can't do anything.
-- robin
!ENTRY org.eclipse.jdt.debug 4 5010 dec 13, 2002 18:53:33.570
!MESSAGE com.sun.jdi.ObjectCollectedException occurred retrieving thread name.
!STACK 0
at org.eclipse.jdi.internal.MirrorImpl.defaultReplyErrorHandler (MirrorImpl.java:234)
at org.eclipse.jdi.internal.ThreadReferenceImpl.name(ThreadRefe renceImpl.java:271)
at org.eclipse.jdt.internal.debug.core.model.JDIThread.getName( JDIThread.java:827)
at org.eclipse.jdt.internal.debug.ui.JDIModelPresentation.getTh readText(JDIModelPresentation.java:269)
at org.eclipse.jdt.internal.debug.ui.JDIModelPresentation.getTe xt(JDIModelPresentation.java:216)
at org.eclipse.debug.internal.ui.LazyModelPresentation.getText( LazyModelPresentation.java:68)
at org.eclipse.debug.internal.ui.DelegatingModelPresentation.ge tText(DelegatingModelPresentation.java:121)
at org.eclipse.jface.viewers.TreeViewer.doUpdateItem(TreeViewer .java:82)
at org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:353)
at org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:1132)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:833)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:847)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:816)
at org.eclipse.jface.viewers.StructuredViewer$4.run(StructuredV iewer.java:744)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:684)
at org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:742)
at org.eclipse.debug.internal.ui.views.launch.LaunchViewer.refr esh(LaunchViewer.java:62)
at org.eclipse.jface.viewers.AbstractTreeViewer.add(AbstractTre eViewer.java:141)
at org.eclipse.jface.viewers.AbstractTreeViewer.add(AbstractTre eViewer.java:162)
at org.eclipse.debug.internal.ui.views.AbstractDebugEventHandle r.insert(AbstractDebugEventHandler.java:74)
at org.eclipse.debug.internal.ui.views.launch.LaunchViewEventHa ndler.doHandleDebugEvents(LaunchViewEventHandler.java:82)
at org.eclipse.debug.internal.ui.views.AbstractDebugEventHandle r$1.run(AbstractDebugEventHandler.java:49)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 1)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:94)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:1424)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1275)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1435)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1418)
at org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:831)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:462)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
at org.eclipse.core.launcher.Main.run(Main.java:703)
at org.eclipse.core.launcher.Main.main(Main.java:539)
Re: ObjectCollectedException [message #38389 is a reply to message #38356] |
Sat, 14 December 2002 12:10  |
Originally posted by: jared-eclipse.mn.rr.com
Robin Rosenberg wrote:
> I also had an error message about failing to initialize drag and drop when
> I left the hanging session for a while. I am quite sure I did not try to
> do drag-n-drop at the time. Does that give a clue?
Not to me. :-/ Sorry.
- Jared
Re: ObjectCollectedException [message #587579 is a reply to message #38159] |
Fri, 13 December 2002 14:37  |
I think the stack trace is a red herring. The code in JDIModelPresentation
handles the exception gracefully and writes the stack trace to the log.
I run on Mandrake 9 and I just had the debugger hang this morning.
Fortunately, it happened while I was debugging the debugger, so I was able
to suspend the Main thread and see what was going on. In my case, the Main
method was stuck in a call to java.io.File#exists() which is called by the
launch config framework to validate the config file before launching.
I don't know why this call would block.
- Jared
> seem to occur in
> debugger in eclipse hangs. Screen refresh works, but I can't do anything.
> -- robin
Re: ObjectCollectedException [message #587594 is a reply to message #38193] |
Fri, 13 December 2002 15:24  |
Do you have any information about what file was being accessed?
-- robin
> - Jared
>> seem to occur in
>> -- robin
Re: ObjectCollectedException [message #587614 is a reply to message #38226] |
Fri, 13 December 2002 21:10  |
Yep. The file was a launch configuration file in the workspace metadata -
something like Hello.launch.
- Jared
<snip>
>> able to suspend the Main thread and see what was going on. In my case,
>> the Main method was stuck in a call to java.io.File#exists() which is
>> called by the launch config framework to validate the config file before
>> launching.
<snip>
Re: ObjectCollectedException [message #587635 is a reply to message #38290] |
Sat, 14 December 2002 10:37  |
Ok, that seems irrelevant. I got it back to a working state by replacing
most stuff I have updated from cooker the last two days. Among the
last libraries removed before the thing started working was libglib2 and
libgk+-x11+.
I left the hanging session for a while. I am quite sure I did not try to do
-- robin
> - Jared
> <snip>
>>> launching.
> <snip>
Re: ObjectCollectedException [message #587647 is a reply to message #38356] |
- Jared
FUDForum. Page generated in 0.05553 seconds
