| Where to report bugs? Here's one... [message #3270] |
Wed, 12 December 2001 05:03  |
Originally posted by: johan.nosp.m.appeal.se
--------------080802040309050703030102
Content-Type: text/plain; charset=us-ascii; format=flowed
Where do I report CDT bugs? Is there a bugzilla category in the works?
I cannot even manage to edit a file :-(. The text editor says: "An
error has occurred when creating this editor" (in red) when trying to
open a text editor on a newly created file in a newly created C project.
Log file is attached.
I downloaded the Eclipse platform runtime binary and the JDT runtime
binary (integration build 20011211). Then downloaded the CDT 0.5.
Running this (RH72 on a PC, together with SUN's "Java(TM) 2 Runtime
Environment, Standard Edition (build 1.3.1_01)"), I open a C/C++
perspective. Create a new project. Add a file ("tabort.c" in my case,
"tabort" is Swedish for "remove") to it. Try to open the file in an
editor. The editor contains the text (in red) "An error has occurred
when creating this editor".
Also, if I restart Eclipse after this, it says "Unable to restore editor
- cannot instantiate input element:
org.eclipse.ui.part.FileEditorInputFactory" on standard error (or stdout?).
Need any more info to be able to repeat this (or tell me what I'm doing
wrong)? Let me know!
Cheers //Johan
name="cdt-log.txt"
Content-Disposition: inline;
filename="cdt-log.txt"
Log: Wed Dec 12 10:46:44 CET 2001
2 org.eclipse.core.runtime 1 Problems encountered loading the plug-in registry.
1=============<children>=============
2 org.eclipse.core.runtime 1 Unknown element description, found within a plugin / fragment, ignored.
1=============</children>=============
Log: Wed Dec 12 10:46:59 CET 2001
1 org.eclipse.core.resources 4 Unable to restore editor - cannot instantiate input element: org.eclipse.ui.part.FileEditorInputFactory
Log: Wed Dec 12 10:47:53 CET 2001
2 org.eclipse.ui 2 Problems occurred when invoking code from plug-in: org.eclipse.ui.
java.lang.NoSuchMethodError
at com.ibm.lpex.alef.LpexSourceViewer.configure(LpexSourceViewe r.java:329)
at com.ibm.lpex.alef.LpexAbstractTextEditor.createPartControl(L pexAbstractTextEditor.java:785)
at com.ibm.cpp.ui.internal.editor.CppEditor.createPartControl(C ppEditor.java:86)
at org.eclipse.ui.internal.PartPane$2.run(PartPane.java:60)
at org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:821)
at org.eclipse.core.runtime.Platform.run(Platform.java:395)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:58)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :100)
at org.eclipse.ui.internal.EditorWorkbook.createPage(EditorWork book.java:214)
at org.eclipse.ui.internal.EditorWorkbook.add(EditorWorkbook.ja va:75)
at org.eclipse.ui.internal.EditorArea.addEditor(EditorArea.java :43)
at org.eclipse.ui.internal.EditorPresentation.openEditor(Editor Presentation.java:296)
at org.eclipse.ui.internal.EditorManager$2.run(EditorManager.ja va:461)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:56)
at org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:447)
at org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:498)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:372)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:269)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:1154)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:1054)
at com.ibm.cpp.ui.internal.actions.OpenEditorAction.performGoto (OpenEditorAction.java:259)
at com.ibm.cpp.ui.internal.actions.OpenEditorAction.run(OpenEdi torAction.java:98)
at com.ibm.dstore.ui.widgets.DataElementTreeViewer.handleDouble Select(DataElementTreeViewer.java:629)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.widgetDefault Selected(AbstractTreeViewer.java:627)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:92)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :54)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:4 89)
at org.eclipse.swt.widgets.Tree.mouseDoubleClick(Tree.java:991)
at org.eclipse.swt.widgets.Tree.handleEvents(Tree.java:809)
at org.eclipse.swt.widgets.SelectableItemWidget$1.handleEvent(S electableItemWidget.java:1189)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1569)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1423)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:775)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:758)
at org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:820)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:285)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:151)
at org.eclipse.core.launcher.Main.run(Main.java:502)
at org.eclipse.core.launcher.Main.main(Main.java:362)
--------------080802040309050703030102--
| Re: Where to report bugs? Here's one... [message #3731 is a reply to message #3669] |
Wed, 12 December 2001 10:54  |
Originally posted by: c4eclipse.nospam.ca.ibm.com
Yes, and yes.
To minimize thrashing we have been working with the stable 1.0 Eclipse base,
but have done some investigation of what it will take to get onto the 2.0
track.
Some pieces work as-is, while others like the editor and debug support,
will require more effort.
In our planning for next year we'll answer the 2.0 question.
Our thinking now is that we want to provide a stable CDT 1.0 on Eclipse 1.0,
but also provide a
beta CDT compatible with Eclipse 2.0. The schedule for this, and the final
1.0 release content,
are the variables we are working with.
David Whiteman wrote:
> I am assuming (and I have no knowledge of this) that the initial base was
> part of the code IBM developed back when only 1.0 was available, and this
> was what was donated to the Eclipse community. I guess part of the
> development project would be to make it work with 2.0.
> I would also guess that any bugs found should be posted to the newsgroup
> until the bugzilla stuff is set up.
> David
> David Whiteman
> david_whiteman@oti.com
> "Johan Walles" <johan.nosp@m.appeal.se> wrote in message
> news:3C1759C9.1030302@m.appeal.se...
> > Thanks, that did the trick. Any plans for basing your development on
> > the 2.0 branch? Or do you want to create a "stable" release based on
> > 1.0 first?
FUDForum. Page generated in 0.05971 seconds
