Home » Eclipse Projects » Mylyn » How to customize the repository settings dialog?
How to customize the repository settings dialog? [message #37810] Mon, 03 December 2007 16:27 Go to next message
Originally posted by: googelybear.gmail.com
Hi guys,
it's me with yet another question ;-)
I want to customize the repository settings dialog in my connector in
such a way that i uses a 'user key' for authentication instead of a
username/password combination. As far as I can see there is only
createAdditionalControls() available for extension but no 'proper' way
to achieve what I want. Can you give me any advice on how to do this best?
Thanks a lot!
Dennis
Re: How to customize the repository settings dialog? [message #38163 is a reply to message #37810] Tue, 04 December 2007 17:51 Go to previous messageGo to next message
Dennis,
this use case has not come up, yet. All existing connectors use username and
password authentication. It would be great if you could file a new bug
report and outline your requirements for the authentication API and user
interface extensibility:
http://www.eclipse.org/mylyn/bugs/
Steffen
Dennis R. wrote:
> Hi guys,
> Thanks a lot!
> Dennis
Re: How to customize the repository settings dialog? [message #38461 is a reply to message #38163] Fri, 07 December 2007 05:34 Go to previous message
Hi Steffen,
ok I'll do that. Basically we just use for all external applications
(like mylyn) accessing our api a user key to authenticate the user
(instead of username/password). If needed the username can be retrieved
via an api call, so there is no need to force the user to enter this.
Dennis
Steffen Pingel wrote:
> Dennis,
> Steffen
> Dennis R. wrote:
>> Hi guys,
>> Thanks a lot!
>> Dennis
Re: How to customize the repository settings dialog? [message #585598 is a reply to message #37810] Tue, 04 December 2007 17:51 Go to previous message
Dennis,
Steffen
Dennis R. wrote:
> Hi guys,
> Thanks a lot!
> Dennis
Re: How to customize the repository settings dialog? [message #585692 is a reply to message #38163] Fri, 07 December 2007 05:34 Go to previous message
Hi Steffen,
Dennis
> Dennis,
> Steffen
> Dennis R. wrote:
>> Hi guys,
>> Thanks a lot!
>> Dennis
Previous Topic:How to connect to a Trac repository on https
Next Topic:What causes this Mylyn error?
Current Time: Tue Jul 15 12:18:09 EDT 2025
Powered by FUDForum. Page generated in 0.25064 seconds
