Home » Eclipse Projects » Plugin Development Environment (PDE) » Examples?
Examples? [message #37791] Tue, 16 December 2008 12:34 Go to next message
Hi all - I'm new to plug-ins and am desperately seeking examples. All I
can find is JavaDoc so far with lots of web searching. I have the
platform docs (pdfs), but they only go so far... I've been searching the
source code and that helps a bit, but a HowTo, or PDE coding FAQ or a
"CookBook" would help immensely. I'm struggling with CompositeRulers,
ContentAssist, Templates, and JavaScript formatting right now.
Bret
Re: Examples? [message #38608 is a reply to message #37791] Sat, 27 December 2008 09:55 Go to previous message
Originally posted by: marc.esher.comcast.net
"Bret Schuhmacher" <bret@lombardi.com> wrote in message
news:1720b7b6607a638a7e2793dbcfeb526a$1@www.eclipse.org...
> Bret
Hi Bret,
here are some that have helped me:
http://www.eclipse.org/swt/snippets/
http://wiki.eclipse.org/index.php/JFaceSnippets
and a great source of information is the wiki:
http://wiki.eclipse.org/Main_Page
here's a sample FAQ:
http://wiki.eclipse.org/The_Official_Eclipse_FAQs
In addition, the SWT examples plugin can be quite helpful:
http://www.eclipse.org/swt/examples.php
Finally, one sweet tool for getting into code is the "plugin spy". With any
view in focus (like the navigator view), simply hit ctrl-shift-f1. It'll pop
up a little window, and from there you can click into the source code and
then use ctrl-click to navigate around to the rest of the code.
The apis and whatnot are just one part of coding plugins though. Learning
how to contribute stuff, in the plugin.xml, is another big source of
frustration (at least, it was for me). to that end, I'll copy the links that
Paul Webster includes in his signature:
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
good luck.
marc
Re: Examples? [message #587607 is a reply to message #37791] Sat, 27 December 2008 09:55 Go to previous message
> Bret
Hi Bret,
good luck.
marc
Previous Topic:3.4 installation as a target platform
Next Topic:Build fails: Unable to find feature
Current Time: Thu Nov 06 17:49:46 EST 2025
Powered by FUDForum. Page generated in 0.04945 seconds
