| BPEL-Editor in RCP app - dependencies? [message #3249] |
Tue, 21 February 2006 05:12  |
Originally posted by: Peter.Peherstorfer.jku.at
I am very interested to use the BPEL plugin in my RCP app. For the time
being i need to visualize BPEL files (no editing, etc. necessary at the
moment, but very welcome nonetheless).
On the BPEL Model webpage, in the "Support for non-Workbench scenarios"
section, it is mentioned that the use for non-workbench scenarios is
supported. However, i found quite a few dependencies on org.eclipse.ide
and org.eclipse.core.resources which are not supposed to be included in
RCP apps (am i right in this assumption?).
My question: how to best make the bpel-editor available in RCP apps?
Tha,
Peter Peherstorfer
| Re: BPEL-Editor in RCP app - dependencies? [message #3283 is a reply to message #3249] |
Tue, 21 February 2006 14:29   |
peterJKU wrote:
> Tha,
> Peter Peherstorfer
Hi Peter,
This sounds like a very interesting project!! Just to clarify the
statements you found on the model web page, the *EMF Model* for BPEL
will run in a non-Workbench scenario (such as in a BPEL runtime, for
example). However, the BPEL *Editor* is very heavily dependent on many
Workbench concepts:
1. The editor operates on IResources and listens for resource deltas for
a number of reasons.
2. The editor is, well, an editor. I'm not up on the latest in RCP but I
assume workbench editors (i.e. IEditorParts) are out for RCP apps
(correct me if I'm wrong).
3. It provides global actions and is dependent on the global selection
framework in the workbench.
4. It is heavily dependent on the workbench Properties view being
available. Details for selected objects are displayed and edited in this
properties view, and the actual properties page framework is now part of
the workbench (as of Eclipse 3.2M5).
I'm not sure how these four items (and possibly others) can be easily
overcome, as they are fairly central to the design of the editor, but we
welcome discussion on any of these. Some education (for me) may be
necessary as well since I haven't looked at the details of RCP in a while.
james
| Re: BPEL-Editor in RCP app - dependencies? [message #3581 is a reply to message #3283] |
Fri, 03 March 2006 16:07   |
Hi James,
I am working on UML and OWL editors deployed as RCP via JavaWebStart. I use
pretty much all four of the items you list below in RCP without any problem.
IEditorPart is also central to RCP apps, and properties view is easily
integrated. I also use the very cool tabbed properties view from WTP (now
in Eclipse platform as of 3.2M5) in my RCP app.
I am also interested in BEPL edit and view within RCP so will study your
dependencies in more detail and reply again later to this newsgroup. There
may be some relatively small changes required to the editor to avoid
IFileEditorInput, which is from IDE plugin. Also Problems view is from IDE.
Dave Carlson
www.xmlmodeling.com
"James Moody" <James_Moody@ca.ibm.com> wrote in message
news:dtfpm6$gsl$1@utils.eclipse.org...
> statements you found on the model web page, the *EMF Model* for BPEL will
> run in a non-Workbench scenario (such as in a BPEL runtime, for example).
> However, the BPEL *Editor* is very heavily dependent on many Workbench
> concepts:
> 1. The editor operates on IResources and listens for resource deltas for a
> number of reasons.
> assume workbench editors (i.e. IEditorParts) are out for RCP apps (correct
> me if I'm wrong).
> james
| Re: BPEL-Editor in RCP app - dependencies? [message #3613 is a reply to message #3581] |
Thu, 09 March 2006 14:19  |
Dave Carlson wrote:
> Hi James,
> Cheers,
> Dave Carlson
> www.xmlmodeling.com
Hi Dave,
This sounds better than I thought. If you're interested in tracking down
any specific areas where we can make improvements, we'd be happy to
evaluate each of them to see if they are feasible - as I mention, this
isn't really in our milestone plan, but if you're interested in helping
out, patches are always welcome.
james
FUDForum. Page generated in 0.04571 seconds
