Home » Archived » XML Schema Definition (XSD) » Create from XML document
| Create from XML document [message #3242] |
Wed, 16 October 2002 11:29  |
Originally posted by: michael.hartmeier.softwareag.com
is there any code that creates an XMLSchema instance from its XML
representation? I.e. is there a method like "public static XSDSchema
parse(InputStream src)" that reads an XML file containing an XML schema
and create the appropriate XMLSchema instance? I had a quick look at the
source code but I didn't find anything like this.
Michael
| Re: Create from XML document [message #3342 is a reply to message #3308] |
Thu, 17 October 2002 08:25   |
--------------3354C7A5B162D181E2A538C8
Content-Type: text/plain; charset=us-ascii
Michael,
The specific link I gave you is for a sample printSchema method that given the URI of a schema, i.e., the URI of a document containing a serialized XML representation of a schema, will print it, E.g.,
prototypicalSchema.print("file:/x:/myschema.xsd")
will load and print the indicated schema.
Your question implied that you had a stream already, so I showed how you could change the code in the sample to use an existing stream rather using the URI of an existing document. Didn't your question about having a stream imply that you have a serialized XML representation already? If you have a DOM node, you can create
an XSDSchema object (from the factory) and call setNode to populate the XSD model implied by that DOM. Maybe this is what you are asking?
Michael Hartmeier wrote:
> Thank you for the quick response!
> Sorry if I still don't get it ... I had a look at the class you suggested
> and the code sippet below. Doesn't this code kind of de-serialize an
> XSDSchema that has previously been saved? I'm looking for a way to create
> an XSDSchema from its XML representation.
> The class you suggested creates two example schemas by manually creating
> every XSDComponents with Java code. It's it possible to provide an XML
> file with your example schema and just load and XSDSchema from this file?
> Michael
> Ed Merks wrote:
> > --------------44E3B560501CC788C56D5520
> > Michael,
> > Did you look at this yet?
> http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String)
> > If you really need to create an instance directly from an input stream,
> > that's possible too:
> > Resource xsdSchemaResource =
> > resourceSet.createResource(URI.createDeviceURI(xsdSchemaURI) );
> > xsdSchemaResource.load(inputStream, Collections.EMPTY_MAP);
> > > Hi,
> > > Michael
> > Ed Merks
> > Content-Type: text/html; charset=us-ascii
> > <!doctype html public "-//w3c//dtd html 4.0 transitional//en">
> > <html>
> > Michael,
> > <p>Did you look at this yet?
> > <p> <a
> href=" http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String)"> http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String> <p>If
> > <blockquote> Resource xsdSchemaResource =
> > <br> xsdSchemaResource.load(inputStream, Collections.EMPTY_MAP);</blockquote>
> > <p><br>Michael Hartmeier wrote:
> > <blockquote TYPE=CITE>Hi,
> > <p>is there any code that creates an XMLSchema instance from its XML
> > <br>representation? I.e. is there a method like "public static XSDSchema
> > <br>parse(InputStream src)" that reads an XML file containing an XML schema
> > <br>and create the appropriate XMLSchema instance? I had a quick look at
> > the
> > <br>source code but I didn't find anything like this.
> > <p>Michael</blockquote>
> > <p>--
> > <br>Ed Merks
> > <br> </html>
> > --------------44E3B560501CC788C56D5520--
Ed Merks
<html>
Michael,
<p>The specific link I gave you is for a sample printSchema method that
<blockquote>prototypicalSchema.print("<A HREF="file:/x:/myschema.xsd">file:/x:/myschema.xsd</A>") </blockquote>
<p>Your question implied that you had a stream already, so I showed how
If you have a DOM node, you can create an XSDSchema object (from the factory)
<p>Michael Hartmeier wrote:
<blockquote TYPE=CITE>Thank you for the quick response!
<p>Sorry if I still don't get it ... I had a look at the class you suggested
<br>and the code sippet below. Doesn't this code kind of de-serialize an
<br>XSDSchema that has previously been saved? I'm looking for a way to
create
<br>an XSDSchema from its XML representation.
<p>The class you suggested creates two example schemas by manually creating
<br>every XSDComponents with Java code. It's it possible to provide an
XML
<br>file with your example schema and just load and XSDSchema from this
file?
<p>Michael
<p>Ed Merks wrote:
<p>> --------------44E3B560501CC788C56D5520
<br>> Content-Type: text/plain; charset=us-ascii
<br>> Content-Transfer-Encoding: 7bit
<p>> Michael,
<p>> Did you look at this yet?
<p>>
<br><a href=" http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String"> http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String</a>)
<p>> If you really need to create an instance directly from an input stream,
<br>> that's possible too:
<p>> Resource xsdSchemaResource =
<br>> resourceSet.createResource(URI.createDeviceURI(xsdSchemaURI) );
<br>> xsdSchemaResource.load(inputStream,
<p>> Michael Hartmeier wrote:
<p>> > Hi,
<br>> >
<br>> > is there any code that creates an XMLSchema instance from its XML
<br>> > representation? I.e. is there a method like "public static XSDSchema
<br>> > parse(InputStream src)" that reads an XML file containing an XML
schema
<br>> > and create the appropriate XMLSchema instance? I had a quick look
at the
<br>> > source code but I didn't find anything like this.
<br>> >
<br>> > Michael
<p>> --
<br>> Ed Merks
<br>> Content-Type: text/html; charset=us-ascii
<p>> <!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<br>> <html>
<br>> Michael,
<br>> <p>Did you look at this yet?
<br>> <p> <a
<br>href="<a href=" http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String"> http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String</a>)"><a href=" http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String"> http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String</a>>
<p>If you really need to create an instance directly from an input stream,
<br>> <blockquote> Resource xsdSchemaResource =
<br> resourceSet.createResource(URI.createDeviceURI(xsdSchemaURI) );
<br>> <br> xsdSchemaResource.load(inputStream, Collections.EMPTY_MAP);</blockquote>
<p>> <p><br>Michael Hartmeier wrote:
<br>> <blockquote TYPE=CITE>Hi,
<br>> <p>is there any code that creates an XMLSchema instance from its
XML
<br>> <br>representation? I.e. is there a method like "public static
XSDSchema
<br>> <br>parse(InputStream src)" that reads an XML file containing
an XML schema
<br>> <br>and create the appropriate XMLSchema instance? I had a quick
look at
<br>> the
<br>> <br>source code but I didn't find anything like this.
<br>> <p>Michael</blockquote>
<p>> <p>--
<br>> <br>Ed Merks
<br>> <br> </html>
<p>> --------------44E3B560501CC788C56D5520--</blockquote>
<p>--
<br>Ed Merks
<br> </html>
--------------3354C7A5B162D181E2A538C8--
| Re: Create from XML document [message #3374 is a reply to message #3342] |
Fri, 18 October 2002 08:41   |
I finally manged to read and print my schema from an InputStream :-)
However, it didn't work with Resources, probably because my Classpath is
incomplete (plus: my code has to run outside of Eclise). As a work-around,
I just loaded the DOM tree and used the schema's setElement method:
doc = readDOM(inputStream); // use xerces to load DOM tree
schema = XSDFactory.eINSTANCE.createXSDSchema();
schema.setElement((Element) doc.getFirstChild());
Here's my next problems: how can I get ElementDeclaration objects for this
schema? I tried
schema.getElementDeclarations()
which returned an empty list ...
Thank you for you patience!
Michael
> Michael,
> > Michael
> > > Michael,
> > > > Hi,
the
> > > > Michael
> > > Ed Merks
> > > <html>
> > > Michael,
> > > <p> <a
<p>If
schema
> > > the
> > > <p>--
> > > <br>Ed Merks
> > > <br> </html>
> Ed Merks
> <html>
> Michael,
serialized
HREF="file:/x:/myschema.xsd">file:/x:/myschema.xsd</a>") </blockquote>
> create
> XML
> file?
> <p>Michael
> <p>> Michael,
> <p>>
> <br><a
> <p>> > Hi,
> <br>> >
> schema
> at the
> <br>> >
> <br>> > Michael
> <p>> --
> <br>> Ed Merks
> <br>> <html>
> <br>> Michael,
> <br>> <p> <a
> <br>href="<a
> XML
> XSDSchema
> an XML schema
> look at
> <br>> the
> <p>> <p>--
> <br>> <br>Ed Merks
> <br>> <br> </html>
> <p>--
> <br>Ed Merks
> <br> </html>
| Re: Create from XML document [message #3408 is a reply to message #3374] |
Fri, 18 October 2002 13:34  |
Michael,
The xsd.test plugin is designed to be a complete working example that demonstrates both headless execution and standalone execution. It includes scripts in the test subdirectory to drive the tests. The script xsd-standalone-test.bat will be relevant to you, since it drives a main method via a CLASSPATH. Getting the CLASSPATH
right is very important, including the xsd.resource.jar, since it contains the schema for schemas, and nothing works without it. The file XSDMainTest.java has more details (maybe too many). It's best to start with something that's already working and slim it down from there...
You really need to use a ResourceSet if you want imports and includes to resolve; they work by demand loading new resources into the set...
> schema? I tried
> Michael
> > Michael,
> > > Michael
> > > > Michael,
> > > > > Hi,
> the
> > > > > Michael
> > > > Ed Merks
> > > > <html>
> > > > Michael,
> > > > <p> <a
> href=" http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String)"> http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String<p>If
> schema
> > > > the
> > > > <p>--
> > > > <br>Ed Merks
> > > > <br> </html>
> > Ed Merks
> > <html>
> > Michael,
> serialized
> > create
> > XML
> > file?
> > <p>Michael
> > <p>> Michael,
> > <p>>
> > <br><a
> href=" http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String"> http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String> <p>> If
> > <p>> > Hi,
> > <br>> >
> > schema
> > at the
> > <br>> >
> > <br>> > Michael
> > <p>> --
> > <br>> Ed Merks
> > <br>> <html>
> > <br>> Michael,
> > <br>> <p> <a
> > <br>href="<a
> href=" http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String"> http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String</a>href=" http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String"> http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String</a>>
> > XML
> > XSDSchema
> > an XML schema
> > look at
> > <br>> the
> > <p>> <p>--
> > <br>> <br>Ed Merks
> > <br>> <br> </html>
> > <p>--
> > <br>Ed Merks
> > <br> </html>
Ed Merks
| Re: Create from XML document [message #562943 is a reply to message #3242] |
Wed, 16 October 2002 14:14  |
Michael,
> Michael
Ed Merks
<html>
Michael,
<p> <a href=" http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String)"> http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String)</a>
<blockquote> Resource xsdSchemaResource = resourceSet.createResource(URI.createDeviceURI(xsdSchemaURI) );
the
<p>--
<br>Ed Merks
<br> </html>
| Re: Create from XML document [message #562974 is a reply to message #3274] |
Thu, 17 October 2002 03:57  |
Michael
> Michael,
> > Hi,
> > Michael
> Ed Merks
> <html>
> Michael,
> <p> <a
> the
> <p>--
> <br>Ed Merks
> <br> </html>
| Re: Create from XML document [message #563000 is a reply to message #3308] |
Michael,
> Michael
> > Michael,
> > > Hi,
> > > Michael
> > Ed Merks
> > <html>
> > Michael,
> > <p> <a
> > the
> > <p>--
> > <br>Ed Merks
> > <br> </html>
Ed Merks
<html>
Michael,
create
XML
file?
<p>Michael
<p>> Michael,
<p>>
<p>> > Hi,
<br>> >
schema
at the
<br>> >
<br>> > Michael
<p>> --
<br>> Ed Merks
<br>> <html>
<br>> Michael,
<br>> <p> <a
XML
XSDSchema
an XML schema
look at
<br>> the
<p>> <p>--
<br>> <br>Ed Merks
<br>> <br> </html>
<p>--
<br>Ed Merks
<br> </html>
| Re: Create from XML document [message #563031 is a reply to message #3342] |
schema? I tried
Michael
> Michael,
> > Michael
> > > Michael,
> > > > Hi,
the
> > > > Michael
> > > Ed Merks
> > > <html>
> > > Michael,
> > > <p> <a
<p>If
schema
> > > the
> > > <p>--
> > > <br>Ed Merks
> > > <br> </html>
> Ed Merks
> <html>
> Michael,
serialized
> create
> XML
> file?
> <p>Michael
> <p>> Michael,
> <p>>
> <br><a
> <p>> > Hi,
> <br>> >
> schema
> at the
> <br>> >
> <br>> > Michael
> <p>> --
> <br>> Ed Merks
> <br>> <html>
> <br>> Michael,
> <br>> <p> <a
> <br>href="<a
> XML
> XSDSchema
> an XML schema
> look at
> <br>> the
> <p>> <p>--
> <br>> <br>Ed Merks
> <br>> <br> </html>
> <p>--
> <br>Ed Merks
> <br> </html>
| Re: Create from XML document [message #563057 is a reply to message #3374] |
Michael,
> schema? I tried
> Michael
> > Michael,
> > > Michael
> > > > Michael,
> > > > > Hi,
> the
> > > > > Michael
> > > > Ed Merks
> > > > <html>
> > > > Michael,
> > > > <p> <a
> schema
> > > > the
> > > > <p>--
> > > > <br>Ed Merks
> > > > <br> </html>
> > Ed Merks
> > <html>
> > Michael,
> serialized
> > create
> > XML
> > file?
> > <p>Michael
> > <p>> Michael,
> > <p>>
> > <br><a
> > <p>> > Hi,
> > <br>> >
> > schema
> > at the
> > <br>> >
> > <br>> > Michael
> > <p>> --
> > <br>> Ed Merks
> > <br>> <html>
> > <br>> Michael,
> > <br>> <p> <a
> > <br>href="<a
> > XML
> > XSDSchema
> > an XML schema
> > look at
> > <br>> the
> > <p>> <p>--
> > <br>> <br>Ed Merks
> > <br>> <br> </html>
> > <p>--
> > <br>Ed Merks
> > <br> </html>
Ed Merks
Current Time: Tue Nov 04 13:40:29 EST 2025
Powered by FUDForum. Page generated in 0.15761 seconds
