| ADJT aspectJ does not wave aspects [message #37223] |
Fri, 04 June 2004 07:24  |
Hi there,
I have got some strange behaviour of the ADJT, I have a small
"testproject" where I test first my aspects, when I see they work I move
them to the real project where they are used.
But what it happends is that when I move them to the real project (that
has around 50 classes), then I compile the files in order to perform the
waving.
Then afterwards at the "outline view" of the aspect, under the advice
icon, does not appear where the aspect (target classes) crosscuts. Of
course if I run the application the aspect does nothing.
This works fine with the "testproject". I have check the definition files
of both projects. And there is nothing different that makes me suspect.
Anybody got the same problem? Because I have no clue how to solve it.
PS I have done the same test with eclipse 2.1 and the associated versions
of AJDT and aspectJ and it happends the same.
| Re: ADJT aspectJ does not wave aspects [message #37257 is a reply to message #37223] |
Fri, 04 June 2004 07:43  |
Sorry for the waste of space.
I solved the problem, I have created a new "Build configuration file"
using
the wizard and then when I compile the project I select this file.
Then it has worked. It is strange though, because the content of the file
is
the "same" as the default build file. And I did not have to create this
file
in the "testproject".
Is this a bug? I have not read in the ADJT doc that it is mandatory to
create
a "build configuration file"
Alfonso
Alfonso wrote:
> Hi there,
> waving.
| Re: ADJT aspectJ does not wave aspects [message #580623 is a reply to message #37223] |
using
is
file
create
Alfonso
Alfonso wrote:
> Hi there,
> waving.
FUDForum. Page generated in 0.04106 seconds
