Home » Eclipse Projects » Eclipse Platform » Ant Runner - Console Log
Ant Runner - Console Log [message #37159] |
Sun, 18 May 2003 21:26  |
Originally posted by: ghodsian.collaxa.com
I am developing a builder extension which needs to run an ant build file.
I have found the documentation on how to configure and run AntRunner.
try
// build logic
AntRunner runner = new AntRunner();
runner.setBuildFileLocation( buildFile );
// Assign logger so that output is redirected to the console.
runner.addBuildLogger( ANT_LOGGER_CLASS );
runner.setArguments( " -verbose");
runner.run( monitor );
catch( Throwable t )
t.printStackTrace();
But I am not able to determine how to redirect the output the build into
the console.
Has anyone already solved that problem? Any pointer would be much
apreciated.
Re: Ant Runner - Console Log [message #39088 is a reply to message #38860] |
Tue, 20 May 2003 02:49   |
Jared. Thank you so much! It worked like a charm. Here is the source code
in case anyone else needs to accomplish the same time:
* Created on May 14, 2003
* To change the template for this generated file go to
* Window>Preferences>Java>Code Generation>Code and Comments
package bpelz.builders;
import java.io.File;
import java.io.IOException;
import java.util.Map;
import java.util.StringTokenizer;
import bpelz.bpelzPlugin;
import org.eclipse.ant.core.AntRunner;
import org.eclipse.ant.internal.core.IAntCoreConstants;
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IProject;
import org.eclipse.core.resources.IncrementalProjectBuilder;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.Status;
import org.eclipse.debug.core.DebugPlugin;
import org.eclipse.debug.core.ILaunchConfiguration;
import org.eclipse.debug.core.ILaunchConfigurationType;
import org.eclipse.debug.core.ILaunchConfigurationWorkingCopy;
import org.eclipse.debug.core.ILaunchManager;
import org.eclipse.debug.ui.CommonTab;
import org.eclipse.debug.ui.DebugUITools;
import
org.eclipse.ui.externaltools.internal.ant.launchConfiguratio ns.AntLaunchConfigurationMessages;
import
org.eclipse.ui.externaltools.internal.ant.launchConfiguratio ns.AntLaunchShortcut;
import org.eclipse.ui.externaltools.internal.model.IExternalToolCon stants;
import org.eclipse.ui.externaltools.internal.model.ToolUtil;
import org.eclipse.ui.externaltools.internal.model.VariableContextM anager;
* @author Edwin Khodabakchian
* To change the template for this generated type comment go to
public class BPELBuilder extends IncrementalProjectBuilder
private static final String BUILD_TYPE_SEPARATOR = ","; //$NON-NLS-1$
private static final int[] DEFAULT_BUILD_TYPES= new int[] {
IncrementalProjectBuilder.INCREMENTAL_BUILD,
IncrementalProjectBuilder.FULL_BUILD};
public IProject[] build(int kind, Map args, IProgressMonitor monitor)
throws CoreException
try
System.out.println( ">>>>>>>>>>BUILDING>>>>>>>>>>>>");
// find build find within this project
IFile selectedFile = findBuildFile();
// Create a temporary launch configuration.
ILaunchConfiguration config = createDefaultConfig(
selectedFile );
boolean runTool = false;
int[] buildKinds =
buildTypesToArray( (String)config.getAttribute(
IExternalToolConstants.ATTR_RUN_BUILD_KINDS, "")
); //$NON-NLS-1$
for (int i = 0; i < buildKinds.length; i++) {
if (kind == buildKinds[i]) {
runTool = true;
break;
if (!runTool)
return null;
// Mark the build as started
VariableContextManager.getDefault().buildStarted(getProject( ),
kind);
// Launch the external ant tool
config.launch(ILaunchManager.RUN_MODE, null);
// Mark the build as completed
VariableContextManager.getDefault().buildEnded();
forgetLastBuiltState();
System.out.println( "<<<<<<<<<<BUILDING<<<<<<<<<<<<<");
t.printStackTrace( );
return null;
* Creates and returns a default launch configuration for the given
file.
* @param file
* @return default launch configuration
public static ILaunchConfiguration createDefaultConfig( IFile file )
ILaunchManager manager =
DebugPlugin.getDefault().getLaunchManager();
ILaunchConfigurationType type =
manager.getLaunchConfigurationType(
IExternalToolConstants.ID_ANT_LAUNCH_CONFIGURATION_TYPE);
StringBuffer buffer = new
StringBuffer(file.getProject().getName());
buffer.append(" "); //$NON-NLS-1$
buffer.append( file.getName() );
String name = buffer.toString().trim();
name= manager.generateUniqueLaunchConfigurationNameFrom( name );
try
ILaunchConfigurationWorkingCopy workingCopy
= type.newInstance(null, name);
StringBuffer buf = new StringBuffer();
ToolUtil.buildVariableTag(
IExternalToolConstants.VAR_WORKSPACE_LOC,
file.getFullPath().toString(),
buf
workingCopy.setAttribute(
IExternalToolConstants.ATTR_LOCATION,
buf.toString()
// set default for common settings
CommonTab tab = new CommonTab();
tab.setDefaults( workingCopy );
tab.dispose();
return workingCopy;
catch (Throwable t)
System.out.println( "Error while creating the default
configuration" );
return null;
* Find the ant build file associated with this project.
protected IFile findBuildFile()
IProject p = getProject();
return (IFile) p.findMember(
IAntCoreConstants.DEFAULT_BUILD_FILENAME );
protected void startupOnInitialize()
System.out.println( ">>>>>>>>>>BUILD ON INITIALIZE>>>>>>>>>>>>");
// builder init logic
* Converts the build types string into an array of
* build kinds.
* @param buildTypes the string of built types to convert
* @return the array of build kinds.
public static int[] buildTypesToArray(String buildTypes) {
int count = 0;
boolean incremental = false;
boolean full = false;
boolean auto = false;
if (buildTypes == null || buildTypes.length() == 0) {
return DEFAULT_BUILD_TYPES;
StringTokenizer tokenizer = new StringTokenizer(buildTypes,
BUILD_TYPE_SEPARATOR);
while (tokenizer.hasMoreTokens()) {
String token = tokenizer.nextToken();
if
(IExternalToolConstants.BUILD_TYPE_INCREMENTAL.equals(token) ) {
if (!incremental) {
incremental = true;
count++;
else if (IExternalToolConstants.BUILD_TYPE_FULL.equals(token))
if (!full) {
full = true;
count++;
else if (IExternalToolConstants.BUILD_TYPE_AUTO.equals(token))
if (!auto) {
auto = true;
count++;
int[] results = new int[count];
count = 0;
if (incremental) {
results[count] = IncrementalProjectBuilder.INCREMENTAL_BUILD;
count++;
if (full) {
results[count] = IncrementalProjectBuilder.FULL_BUILD;
count++;
if (auto) {
results[count] = IncrementalProjectBuilder.AUTO_BUILD;
count++;
return results;
Jared Burns wrote:
> ExternalToolBuilder is a builder that runs launch configs, including Ant
> configs. As you'll see in the build(...) method, it's passed the location
> of a launch config as an argument and just executes that config.
> - Jared
> Mark Ghodsian wrote:
> > Thank you for the insight. Would you happen to know if there are examples
> > out there on how to leverage the AntLaunchDelegate or the
> > AntLaunchShortcut from within a builder?
Re: Ant Runner - Console Log [message #286058 is a reply to message #39088] |
Wed, 01 June 2005 10:43   |
Originally posted by: mazloumi.uni-mannheim.de
Sorry, but I didn't understand how I can redirect the ant log to
a console view.
Has someone experience with that?
This is what id do at the moment:
final AntRunner runner = new AntRunner();
runner.setBuildFileLocation(buildFile.toString());
runner.setMessageOutputLevel(verboseLevel);
runner.setArguments(args);
runner.run();
I know I can add my own logger with:
runner.addBuildLogger("foo.FooLogger");
But how do I write out what ant logs into a console window?
nima
> import
> import
> try
> selectedFile );
> int[] buildKinds =
> ); //$NON-NLS-1$
> runTool = true;
> break;
> if (!runTool)
> return null;
> kind);
> return null;
> file.
> * @param file
> try
> buf
> buf.toString()
> tab.dispose();
> return workingCopy;
> catch (Throwable t)
> configuration" );
> return null;
> * build kinds.
> int count = 0;
> if
> if (!incremental) {
> incremental = true;
> count++;
> if (!full) {
> full = true;
> count++;
> if (!auto) {
> auto = true;
> count++;
> count = 0;
> if (incremental) {
> count++;
> if (full) {
> count++;
> if (auto) {
> count++;
> return results;
>>- Jared
Re: Ant Runner - Console Log [message #286071 is a reply to message #286058] |
Wed, 01 June 2005 16:02   |
I have pasted below a logger class that works for me (would be your
foo.FooLogger):
public class AntConsoleLogger extends DefaultLogger {
// the message console stream used to output to the console view
private MessageConsoleStream mConsoleStream = null;
public AntConsoleLogger() {
super();
MessageConsole myConsole = findConsole("Some console name");
mConsoleStream = myConsole.newMessageStream();
protected void log(String message) {
mConsoleStream.println(message);
Also in case u need it, have added method to findConsole:
public static MessageConsole findConsole(String name) {
ConsolePlugin plugin = ConsolePlugin.getDefault();
IConsoleManager conMan = plugin.getConsoleManager();
IConsole[] existing = conMan.getConsoles();
for (int i = 0; i < existing.length; i++)
if (name.equals(existing[i].getName()))
return (MessageConsole) existing[i];
//no console found, so create a new one
MessageConsole myConsole = new MessageConsole(name, null);
conMan.addConsoles(new IConsole[]{myConsole});
return myConsole;
Hope this is what u need.
-matt
> a console view.
> runner.run();
> nima
>> import
>> import
>> try
>> selectedFile );
>> int[] buildKinds =
>> ); //$NON-NLS-1$
>> runTool = true;
>> break;
>> if (!runTool)
>> return null;
>> kind);
>> return null;
>> file.
>> * @param file
>> try
>> buf
>> buf.toString()
>> tab.dispose();
>> return workingCopy;
>> catch (Throwable t)
>> configuration" );
>> return null;
>> * build kinds.
>> int count = 0;
>> if
>> if (!incremental) {
>> incremental = true;
>> count++;
>> if (!full) {
>> full = true;
>> count++;
>> if (!auto) {
>> auto = true;
>> count++;
>> count = 0;
>> if (incremental) {
>> count++;
>> if (full) {
>> count++;
>> if (auto) {
>> count++;
>> return results;
>>>- Jared
Re: Ant Runner - Console Log [message #286092 is a reply to message #286071] |
Thu, 02 June 2005 06:28   |
Hi Matt,
thank you very much. I works now.
Greetings,
Nima
> foo.FooLogger):
> super(); MessageConsole myConsole =
> mConsoleStream = myConsole.newMessageStream(); }
> return myConsole;
> -matt
>> a console view.
>> runner.run();
>> Thanks,
>> nima
>>> code
>>> import
>>> import
>>> import
>>> import
>>> public class BPELBuilder extends IncrementalProjectBuilder {
>>> monitor)
>>> throws CoreException {
>>> try
>>> selectedFile );
>>> int[] buildKinds = buildTypesToArray(
>>> ); //$NON-NLS-1$
>>> runTool = true;
>>> break;
>>> if (!runTool)
>>> return null;
>>> kind);
>>> return null;
>>> file.
>>> * * @param file
>>> file ) {
>>> try {
>>> name);
>>> buf
>>> workingCopy.setAttribute( IExternalToolConstants.ATTR_LOCATION,
>>> buf.toString()
>>> tab.dispose();
>>> return workingCopy;
>>> } catch (Throwable t) {
>>> configuration" );
>>> return null;
>>> * Find the ant build file associated with this project. */
>>> protected void startupOnInitialize() {
>>> * build kinds.
>>> int count = 0;
>>> if
>>> if (!incremental) {
>>> incremental = true;
>>> count++;
>>> else if
>>> if (!full) {
>>> full = true;
>>> count++;
>>> else if
>>> if (!auto) {
>>> auto = true;
>>> count++;
>>> count = 0;
>>> if (incremental) {
>>> results[count] =
>>> count++;
>>> if (full) {
>>> count++;
>>> if (auto) {
>>> count++;
>>> return results;
>>>> Ant configs. As you'll see in the build(...) method, it's passed the
>>>> location of a launch config as an argument and just executes that
>>>> config.
>>>> - Jared
>>>>> examples
Re: Ant Runner - Console Log [message #286093 is a reply to message #286092] |
Thu, 02 June 2005 06:33  |
Matt,
have you experience with setting ant home programmatically
instead of manually using the preferences?
Nima
> Hi Matt,
> Greetings,
> Nima
>> foo.FooLogger):
>> return myConsole;
>> -matt
>>> a console view.
>>> runner.run();
>>> Thanks,
>>> nima
>>>> code
>>>> import
>>>> import
>>>> import
>>>> import
>>>> monitor)
>>>> try
>>>> selectedFile );
>>>> int[] buildKinds =
>>>> ); //$NON-NLS-1$
>>>> runTool = true;
>>>> break;
>>>> if (!runTool)
>>>> return null;
>>>> kind);
>>>> return null;
>>>> file.
>>>> * * @param file
>>>> file ) {
>>>> name );
>>>> try {
>>>> name);
>>>> buf
>>>> buf.toString()
>>>> tab.dispose();
>>>> return workingCopy;
>>>> configuration" );
>>>> return null;
>>>> * build kinds.
>>>> int count = 0;
>>>> if
>>>> if (!incremental) {
>>>> incremental = true;
>>>> count++;
>>>> else if
>>>> if (!full) {
>>>> full = true;
>>>> count++;
>>>> else if
>>>> if (!auto) {
>>>> auto = true;
>>>> count++;
>>>> count = 0;
>>>> if (incremental) {
>>>> results[count] =
>>>> count++;
>>>> if (full) {
>>>> count++;
>>>> if (auto) {
>>>> count++;
>>>> return results;
>>>>> including Ant configs. As you'll see in the build(...) method, it's
>>>>> passed the location of a launch config as an argument and just
>>>>> - Jared
>>>>>> examples
Current Time: Thu Jul 17 20:04:26 EDT 2025
Powered by FUDForum. Page generated in 0.12253 seconds
