Problems when vep plugin is modified. [message #37080] |
Fri, 14 May 2004 00:18  |
Originally posted by: sibin.exorindia.com
Hi Everybody,
I am trying to make some modification in
org.eclipse.ve.java.core.For this purpose I have added a jar file in the
build path of the plugin.During runtime I encountered an
NoClassfoundError.The classes inside the jar file are not detected.I have
tried ,adding the jar file under runtime in Plugin.xml.But still it is not
working.
Hoping to get some help.
sibin
Re: Problems when vep plugin is modified. [message #37182 is a reply to message #37080] |
Fri, 14 May 2004 08:30  |
Originally posted by: mendelgili.netscape.net
sibin wrote:
> Hi Everybody,
> working.
> Regards
> sibin
If you have run the work space before, eclipse is caching reg. info.
Have you tried the -clear option on the Eclipse command line and (the
last resort of) erasing the configuration directory out below the
eclipse directory?
Re: Problems when vep plugin is modified. [message #588581 is a reply to message #37080] |
sibin wrote:
> Hi Everybody,
> working.
> Regards
> sibin
eclipse directory?
FUDForum. Page generated in 0.03672 seconds
