Accessing JavaDocs via the code (F1?) [message #37066] |
Fri, 18 March 2005 04:40  |
Originally posted by: jesse-t.chello.nl
A lot of Java IDE's have F1 (button) class/methode lookups/help in the
Javadocs.
When pressing F1 above a method of class, they will automatically go to
the Javadoc in a webbrowser. For example to
http://java.sun.com/j2se/1.5.0/docs/api/java/util/regex/Matc her.html
Eclipse is able to show a small info box about the methods/classes, but I
want Eclipse to start a webbrowser with the full Javadoc descriptions.
I can't find this functionality in Eclipse. Does anybody here know
solutions for this problem? Thanks.
Jesse
Re: Accessing JavaDocs via the code (F1?) [message #37171 is a reply to message #37103] |
Fri, 18 March 2005 06:03  |
It works, thanks!
Horváth, Csaba wrote:
> Try Shift+F2 (or Navigate > Open External Javadoc). Note that you may need
> to set the javadoc path for a non-jdk library (at Project Properties > Build
> Path > Libraries).
> HTH,
> Csaba
> "Jesse" <jesse-t@chello.nl> wrote in message
> news:d1e7mq$n4l$1@www.eclipse.org...
>> Javadocs.
>> Jesse
FUDForum. Page generated in 0.10125 seconds
