[Xtext] OAW Check/Xtend in Eclipse [message #36911] |
Sat, 04 April 2009 11:58  |
I was just wondering how these components related to Xtext specifically and
the Eclipse Modeling Project in general. My current (limited) understanding
is:
At the moment Xpand and Xtext and MWE seem to be official Eclipse components
which came from OAW. (Is this everything brought from OAW so far?) Check and
Xtend seem to be used in Xtext (and maybe also used in Xpand, I did not
check). Maybe the 'Expressions Framework' (as it is referred to in the OAW
docs) could also be thought of as a subcomponent since it seems
Check/Xtend/Xpand rely on it too. The Expression Framework seems to be a
practical/pragmatic subset of OCL syntax and a nice way to interface with it
which could be more desirable than Eclipse OCL in some cases.
What is the status of Check, Xtend and the Expressions Framework? Will they
become their own Eclipse components? Should users consume them directly?
Will they be phased out/replaced or adopted/improved?
It seems like much of the OAW work is going into Eclipse which is really
great since it is very mature.I searched a bit regarding this but did not
find much detail.
If this is not the right place to ask the question, maybe someone can direct
me to the right place.
Thanks in advance.
Derek
Re: [Xtext] OAW Check/Xtend in Eclipse [message #38229 is a reply to message #37286] |
Mon, 06 April 2009 17:21   |
Hi Sven,
I asked this over on oAW forum a while back, but I'm wondering if we
could consider eclipse versions of all of this close to production
ready. In other words, would it make sense for oAW consumers with
mature projects to begin migrating now?
thanks,
Miles
On 2009-04-06 01:50:12 -0700, Sven Efftinge <sven.efftinge@itemis.de> said:
> Hi Derek,
> as Xpand, Xtend and Check are technically one language (with just a
> couple of different coarse-grained concepts and file extensions) they
> are all part of M2T/Xpand.
> Cheers,
> Sven
> Derek Palma schrieb:
>> and the Eclipse Modeling Project in general. My current (limited)
>> understanding is:
>> components which came from OAW. (Is this everything brought from OAW so
>> far?) Check and Xtend seem to be used in Xtext (and maybe also used in
>> Xpand, I did not check). Maybe the 'Expressions Framework' (as it is
>> referred to in the OAW docs) could also be thought of as a subcomponent
>> since it seems Check/Xtend/Xpand rely on it too. The Expression
>> Framework seems to be a practical/pragmatic subset of OCL syntax and a
>> nice way to interface with it which could be more desirable than
>> they become their own Eclipse components? Should users consume them
>> directly? Will they be phased out/replaced or adopted/improved?
>> really great since it is very mature.I searched a bit regarding this
>> but did not find much detail.
>> direct me to the right place.
>> Thanks in advance.
>> Derek
Re: [Xtext] OAW Check/Xtend in Eclipse [message #38625 is a reply to message #38229] |
Tue, 07 April 2009 03:39  |
Hi Miles,
we don't state, that you can savely migrate now.
Officially you should wait till June.
There'll be some minor changes in TMF Xtext until June, which might
force people to change their projects accordingly.
Also Xpand is not yet migrated completely. It seems that we missed some
fixes from the oAW 4.3.1 stream, but we'll have the migration completed
for M7. Note that we of course already use Xpand, Xtend and Check in TMF
Xtext.
Moreover we find TMF Xtext to be much more solid and flexible and it
even now has more documentation.
So if you want to give it a try, be sure that we'll help you. :-)
Sven
Miles Parker schrieb:
> Hi Sven,
> ready. In other words, would it make sense for oAW consumers with mature
> thanks,
> Miles
>> Hi Derek,
>> Cheers,
>> Sven
>>> Hi,
>>> specifically and the Eclipse Modeling Project in general. My current
>>> (limited) understanding is:
>>> so far?) Check and Xtend seem to be used in Xtext (and maybe also
>>> used in Xpand, I did not check). Maybe the 'Expressions Framework'
>>> (as it is referred to in the OAW docs) could also be thought of as a
>>> subcomponent since it seems Check/Xtend/Xpand rely on it too. The
>>> Expression Framework seems to be a practical/pragmatic subset of OCL
>>> syntax and a nice way to interface with it which could be more
>>> Will they become their own Eclipse components? Should users consume
>>> them directly? Will they be phased out/replaced or adopted/improved?
>>> Thanks in advance.
>>> Derek
FUDForum. Page generated in 0.03995 seconds
