Home » Language IDEs » AspectJ » file not found in JUnit failure trace
file not found in JUnit failure trace [message #36754] Thu, 27 May 2004 10:45 Go to next message
I was writing a few JUnit testcases for a project that contains a
couple of aspects.
One of them fails and while trying to understand why I noticed that
clicking on lines in the stacktrace, which refer to aspectj-code,
e.g.:
at foo.Log.createSignature(Log.aj:62)
yields a strange message:
"Test class not found in selected project."
I have no class called "Test" in my project. I guess JUnit has a
Test-class one, but I don't know why clicking on the above line in the
stacktrace searches for that. Shouldn't it show line 62 in file
Log.aj?
BTW: Clicking on certain other lines, e.g.
foo.Log.ajc$inlineAccessMethod$foo_Log$foo_Log$createSignatu re(Log.aj)
yields no reaction at all, i.e. it seems to be ignored completey
(which is probably OK since that seems to be some very aspect-internal
stuff...).
Michael
Re: file not found in JUnit failure trace [message #36788 is a reply to message #36754] Thu, 27 May 2004 10:58 Go to previous message
It also seems, that if one added methods to a class using an aspect
like:
public aspect Xyz {
declare parents: Foo implements Bar;
// implementing some method defined by Bar:
public String bar() {
then the line in the stacktrace erroneously points to the advised
original class anddoes not contain a line number, e.g.:
at foo.Foo.bar(Foo.java)
instead of :
at Xyz.bar(Xyz.aj:123)
I guess when it comes to stacktrace reverse translation this whole
bytecode weaving opens not just one but several cans of worms...
Michael
Re: file not found in JUnit failure trace [message #580241 is a reply to message #36754] Thu, 27 May 2004 10:58 Go to previous message
like:
public aspect Xyz {
instead of :
Michael
Previous Topic:file not found in JUnit failure trace
Next Topic:Eclipse's refactoring does not cover aspectj files
Current Time: Tue Jul 22 01:48:35 EDT 2025
Powered by FUDForum. Page generated in 2.78920 seconds
